Question about Sentry Fireproof Safe
My sentry safe is locked and the key won't open it.
The safe in my business accidentally got locked and the key will not open it. I know the combo also and nothing will work.
SOURCE: Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
Posted on Mar 23, 2009
ginko
  • 19396 Answers
SOURCE: can't open combo/key sentry safe.
You need to contact Sentry, they will send you an emergency unlock code.
Number in US is 1-800-828-1438.
See also:
Lost combination or keys
Replacement Keys and Combinations
Sentry Safes Key: 2 Replacement keys for sentry fire safe
Posted on Apr 27, 2009
jyackle5
  • 8197 Answers
SOURCE: I have a Sentry safe A3860.. I have the combo and
1. Insert a paper clip or pen point into
the small hole of the battery cover located
directly below the keypad. Push in while
sliding cover to the right (Fig. B).
2. Disconnect and remove battery holder.
• Insert 4 new AA batteries (not included)
to power this lock.
• Reconnect the battery holder and put back into proper
position. Slide battery cover back in place.
NOTE: The yellow LED will light when the batteries need
to be replaced.
You can also get the manual here on link below. page 1 tells you how to replace battery.
http://www.sentrysafe.com/pdfs/OwnersManuals/506218.pdf
Posted on Dec 22, 2009
SOURCE: cannot open sentry safe, model 1230, have combo
cannot open sentry safe, model 1230, do not have combination
Posted on Mar 15, 2010
  • 76 Answers
SOURCE: i bought a S 3417 SENTRY SAFE S/N Z 583159* AT A
To order replacement keys, for small chests and files, you will need to know the key numbers which can be found right around where the key goes in. It should be a stamped number, letters, or both located around the keyhole. For Personal, Home and Home/Office Safes, you will need the model number and serial number. I think that the most economical place to buy keys is from www.SentrySafeShop.com. You can do a search for "lost keys" and it will give you a screen where you can enter your model number and key number. (It is a very easy screen to use. They just need 1.)Model # and 2.)Serial or Key #.)
In Summary:
For Small Chests or Files: A lock reference number is required. It will be a letter, a number, a letter and number, or "blank" (no letter or number), engraved/located on the silver cylinder of the lock. These are model numbers 0500, 1100, 1170, etc...
Combinations can also be ordered from the same website.
For Personal, Home and Home/Office Safes: (model numbers will begin with: S0, S3, S4, S5; I0, I3, I4, I5; A3, A4, A5; J3, J4, J5; L0, L3, ,CS,CSW,DA,DS,KS,KSW,MS,MSW,OA,OS,and SC): Indicate your model number and the safe serial number found on the front right-hand side of the door, between the hinges.
Here is the direct link to the key replacement screen: http://www.sentrysafeshop.com/Keys-Sentry-Safe-Replacement-Keys-p/keys.htm
Posted on Jul 02, 2010
Don't want anybodythat might know my original safe combo to get in it door open cover off know original safe combo have all other info of ownership can I change combo of 1250 sentry safe
If the door is opened..Then you would need to remove the cover to the lock at the back..You will see a screw on the last wheel of the lock..Move that screw into a different hole on the wheel..Then you can dial the wheels to the lever..Each wheel is a number..This will give you a new combination..My advice to you would be to locate a Safe Tech/Locksmith..Have them do it for you..
Apr 18, 2017 | Sentry Home Security
HAVE SENTRY SO410 SAFE WITH KEY BUT NO COMBO. HOW DO I OPEN IT?
All you have to do is find your owners manual the sentry safe combination was posted in. Unless you locked it the safe as happens all the time. After all that is the safest place for it right. Or you can just call a locksmith service tech
Feb 23, 2012 | Sentry Fireproof Safe
I have a Sentry safe S5741. I have the electronic combo and the key. The door to the safe was locked with the door open. Now the door will not unlock to shut the door. Is there trip to reset the door? Is...
Try changing the batteries first. No the electronic combo would not be erased unless someone previously changed the combination. There is probably something causing the bolts to not retract. The lock may fail if there is any pressure on the bolts and or the door of the safe. Hopefully this information helps.
Jul 12, 2011 | Sentry Fireproof Safe
I have a sentry s0410. I have lost the key and combination - how do I open the safe?
Sledge Hammer :)
Side note: In all sentry documentation it clearly states that if you lock your posessions in the safe and lose the key/combination, there is no master key or combo that will open your safe. You could try to write the good people at sentry but I haven't heard a success story from that yet.
My advice would be to befriend a firefighter and somehow convince him to let you borrow the jaws of life. Or get a hold of some explosives.
Good luck to you.
May 04, 2011 | Sentry Fireproof Safe
How do I open the combination lock to my sentry home safe?
Locksmiths advise these Opening instructions for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
sentry safes opening instructions for 4 # combo locks
Turn the dial to zero.
Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the third time).
Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
Turn the dial to the right to the last number (stop the first time on your last number).
Pull the handle down to crack the sentry safe open.
Oct 28, 2009 | Sentry Fireproof Safe
Can't open combo/key sentry safe.
See also:
Apr 18, 2009 | Sentry Fireproof Safe
I have sentry safe that i bought with keys need reset combo
If there is a reset combination it's unlikely anyone is going to tell you otherwise you would have free access to any other locked Sentry safe. A locksmith who deals with the brand or Sentry themselves will probably be able to do it for you if it's possible.
Nov 25, 2017 | Sentry Fireproof Safe
Small floor safe Sentry Model 3877 electronic lock and key
This manual will answer both of your questions.
http://www.sentrysafe.com/pdfs/OwnersManuals/501664.pdf
Feb 21, 2008 | Sentry Fireproof Safe
My sentry safe
https://www.sentrysafe.com/customerCare/retrieveCombination.aspx
Feb 06, 2008 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
74 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Hannah Johnson
Level 1 Expert
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
