Question about Philips DVDR520H DVD Player/HDD
PHILIPS DVDR5520H REGION UNLOCK CODE
I have tried to unlock the dvdr5520h with the prescribed solution , but i am unable to do so ,,maybe i am doing somthing wrong ,,could you please advise ...thankyou .....
  • 4 more comments
  • keaneo16 Jan 13, 2009
    when i load dvd on the right hand side of the screen 'invalid region code' appears. The funny thing is that the day before iwas watching the same dvd without any problems.
    thanks
  • Anonymous Jan 29, 2009
    I have the same problem, I have tryed to fix it no luck
  • pixierme Mar 22, 2009
    Hi. I also have a Philips DVDR model DVDR5520H/75. It is locked to Zone 4 (Australia). How can I convert this unit to read Multi Zone please.
    Thanks.
  • Anonymous Apr 19, 2009
    Hello wazbrad
    Did the solution work psted by faliraki69?
    Hello wazbrad
    Did the Solution above work?
  • Anonymous May 11, 2009
    i want to unlock my dvdr5520h to multiregional. i have tried the one with the codes 159 12 12 12 005 255 but when i press hdd list i have no response to start to enter the numbers
- No disk in tray.
- Tray closed.
Press: [HDD LIST] (don´t select a file)
Press: [Play]
Press: 159 12 12 12 005 255 (numbers appear in the display)
Press: [Play]
You get no feedback that it works, but test with any region now. The player is now region free.
Posted on Apr 17, 2009
UNLOCK REGION CODE FOR PHILIPS DVP3268K DVD PLAYER
You maybe able to get a region free code for your player from these WEB sites.
Unlock DVD Players - Region Free Code
www.dvdexploder.com/ www.download-info.com/dvd/index_new.htm
Feb 22, 2013 | Televison & Video
How do i unlock my region code for my dvd player
Feb 16, 2013 | Philips Audio Players & Recorders
I have a Philips HTS 3371 DVD home theatre and can not play many DVD's as it give wrong region error. Can you please provide the unlock code and how/where to enter it to get it fixed?
Hi -
Please follow the instructions below for unlocking your Philips HTS 3371
Please note: Unlocking a DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
1. Switch the DVD player ON
2. OPEN the disc tray
3. Key 9 9 9 9 0 using the Philips remote control supplied with the player
4. Press PLAY. The disc tray will close.
5. Switch the player OFF then switch ON again.
6. To test, play a disc from a region which was previously locked.
If it does not work the first time, switch the player off and back on, then try again.
This is a verified unlock method, but I was unable to confirm whether it works for players sold locked to Region 1 (North America). If you have a Region 1 player and the method above does not work, you will not be able to unlock your player.
Regards,
BElectric
Mar 26, 2011 | Philips HTS3371D Theater System
Unlock code for my Philips MCD 177
I need a region unlock code for my Philips Micro Theatre MCD290 DVD
Nov 17, 2008 | Philips MCD288/37 DVD Micro Theater System...
I have a Phillips DVDR5520H and would like to unlock it so it can play dvds from all regions
1- Go into the main menu
2- Highlight the exit button
3- Type 2960
This should give you access to a hidden menu form where you can change the region code
Aug 10, 2008 | Televison & Video
Phililps DVDR5570H only plays zone 4.Is there an unlock code for multizone playback?
Try this:
Models supported:
DVDR3570H
DVDR3575H
DVDR3577H
DVDR3590H
DVDR3595H
DVDR3597H
DVDR5520H
DVDR5570H
  1. Power on the recorder
  2. Wait for player to initialise.
  3. Press [HOME] on the remote control.
  4. Press [PLAY / PAUSE]
  5. Key in 1 5 9 1 2 1 2 1 2 0 0 5 2 5 5 – The numbers will appear in the display of the recorder.
  6. Press [PLAY / PAUSE]
If the recorder goes into browser mode during the procedure, then it will need to be re-started from the beginning.
If at any point the recorder is reset to factory settings, then the procedure will need to be carried out again.
Jul 27, 2008 | Televison & Video
No sound on scart 1 to tv . on model:DVDR5520H
seems your scart is not plugged in all the way -- ie U have a weak connection. try a new scart lead-my regards
Jun 25, 2008 | Philips DVDR520H DVD Player/HDD
Philips DVDR520H DVD Player/HDD Logo
985 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
