Question about Sony Walkman D-EJ360 Personal CD Player
IN DASH SONY CD PLAYER
I HAVE A SONY CD PLAYER IN MY JEEP. MODEL NUMBERCDXM8810 THE RADIO WILL PLAY WHEN YOU GIVE IT POWER BUT WHEN PUT A CD IN NO SOUND COMES OUT. BUT THERE IS SOUND WHEN YOU HAVE THE TUNER ON. THE CD PLAYS BUT NO SOUND
5 Suggested Answers
SOURCE: No AM or FM yet cd player works
Friend,
Maybe, there is a problem from the detector of you radio function to the amplifier. Try to check on it first or try resoldering from the detector section
Posted on Mar 10, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Installing a CD player in '08 Aveo in plac eof stock AM/FM radio
You should check with Car Toys or Best Buy but you will probably need an adaptor and a wiring harness. If your doing it yourself your going to need to know how to get the stock radio out and the wiring diagram for the Aveo. Sometimes you can find the wiring diagram on Google by searching for it but usually finding diagrams for 2008 vehicles takes a year or two before it becomes available.
If your CD player has a tuner in it already you shouldn't need one. If it doesn't have one, that presents some other options.
Posted on Jun 22, 2008
SOURCE: no sound from cd but stereo works no problem
there are 2 blue wires........dont hook the blue to blue!!!!!!!!!!!!!!!!!!!!!! hook blue to the blue/white wire!!!!!!!!!!! problem solved. so e-z huh? lol i did the same thing.
Posted on Feb 28, 2009
SOURCE: SONY EXCD-206 December 1996
I have the same radio, the radio's harrness has a red wire ignition 12 volt,yellow battery 12 volt, black ground, and a blue Iam not positive it can be the amp, or illumination.
Posted on Mar 08, 2009
Th3_uN1Qu3
  • 47 Answers
SOURCE: The CD player on my Sony Dream Machine FM/AM CD
The laser has gone weak. If you feel confident taking it apart, unplug it and look for a small potentiometer on the CD reading pickup. Turn it to the right to about 700 ohms, it should start reading again. If you don't have a multimeter to measure it then get one, a basic $10 meter will do fine.
Posted on Jun 26, 2009
My Sony CDX-M610 will play radio but not CDs
THE CDX-M610 LIKE ALL OF THE CDX-M630, M800, M850MP SHOULD ALL SIMPLY START TO PLAY THE CD WHEN INSERTED. BECAUSE YOU ARE ABLE TO TUNE RADIO STATIONS AND HEAR THEM PLAY SHOWS THAT YOU HAVE EVERYTHING IN PLACE AND ARE DOING EVERYTHING RIGHT. SO IF IT IS NOT PLAYING, THEN IT WILL NEED TO BE SERVICED. AS FOR THE REMOTE, IT IS NOT REQUIRED OF ANY OF THE CD PLAYERS IN ORDER TO PLAY CD OR TUNE RADIO STATIONS. RATHER THAN INVEST IN REPAIRING, I WOULD LOOK FOR ANOTHER MODEL ON EBAY USED AS IT WILL PROBABLY GO PRETTY CHEAP. ALSO HAVE CHANCE TO GET A HIGHER MODEL LIKE THE ONES I MENTIONED ABOVE. I HAVE SEVERAL OF EACH IN MY COLLECTION AND THERE ARE NICE PLAYERS. OK. HOPE THIS HELPS.....V
Jan 04, 2017 | Sony CDX-M610 CD Player
Replaced the battery & now the radio/cd player
Your radio will need a code to reactive it because the power has been lost.
You need to post up the serial and part number of the radio - found on a label at the back so you will need to remove the radio from the dash to find this.
Make and model of radio and car also required. Then we can advise further.
Thanks for using fixYa.
Aug 26, 2011 | Car Audio & Video
Hello, umm my CDX-GT200 sony player in my jeep as been working great.. however just the other day I was driving home with it playing the radio and all of a sudden it just powered off.. and now when I try...
hi firstly check your fuses ,remove the player from dash check all wirering especially the positive + and - negative ,should be black and red ,check with multimetre for current at these wires you can disconnect the power block from the radio if you like and check for power this way .hope this helps you goodluck
Mar 18, 2011 | Sony XPLOD CDX-GT200 CD Player
Sony xplod am/fm cd model cdx-m610 will play cds but the radio want play. i have tried to reset radio still will not play
Make sure that you have the antenna plugged in and if you have a power antenna make sure that you hook up the solid blue antenna wire behind on the radio harness to the power antenna wire from the car plug.
May 21, 2010 | Sony CDX-M610 CD Player
Jeep radio w/cd player
begin with the easy one. code is for battery disconnect.(if you had the battery disconnected while installing that will explain it) if you ground the antenna wire to the chassis does it still spark? Is it a power antenna? I'd make sure that somehow the clock and radio wiring is not reversed and that the radio is well grounded (you can add a ground from the case to the main dash rail if you need to. As with any used item, there is a possibility also that there is just something wrong with the radio, but I don't think that yet!
Feb 13, 2010 | 1994 Jeep Grand Cherokee
My radio/CD deck just went blank and will not operate
There are fuses mounted on the rear of aftermarket radios but not for factory ones..
Nov 05, 2009 | Car Audio & Video
Car radio/cd player cuts off radio will not play cd will not play ,hit the power button and will come back on some times it wil not. its seems like there is static sound when the music does not play on the...
Hello pinkperry,
It sounds like the wiring between the cdplayer and the dash has come loose. When the wires are not making proper connections some of the speakers or functions of the radio cut on and off.
This is just my first thought and the easiest thing to fix. You will have to remove the cd player from the dash. After which you will want to check the wiring. Chances are your cd player has a harness if it's an aftermarket cd player installed in your car. If it does there will be two sets of wires to double check.
Just make sure all the wires are securely twisted together (the sets of wires) and taped up with electrical tape.
Try that and post back if you have any further questions. Thank you for choosing Fixya!
Aug 25, 2009 | Car Audio & Video
Cd player in 2003 Jeep Liberty will not play or eject cds. This is factory radio with 6 cd changer.Radio works. Cd players makes clicking noise but does not play or release cds.
you might want to just take the factory cd player out and put a after market one in cause thats what i had to do on mine casue it costs way to much to get the original one replaced
Jul 31, 2009 | Car Audio & Video
Jeep 10 disc changer; now only error message on dash.
I had this same problem on my 2000 Jeep GC Limited. Today I decided to open it up after looking all over the net and found no help, but spend $500.00 on a new unit. I removed the unit and used canned air inside all the areas I could. I hooked it back up and was finally able to make the CD cleaner disc work. Once that was done I loaded it with 10 cd's and it is working again. I'm so happy! I saved my hubby 500 big ones.
Oct 26, 2007 | Cherokee Jeep Grand CD Changers - 10-Disc
Sony Walkman D-EJ360 Personal CD Player Logo
20 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
