Question about Logitech QuickCam Pro 5000 Webcam
Not working ive down loaded drivers for my pro 5000 and it wont work ive done mic test and its ok but no web cam
    New Friend:
  • 109 Answers
Unplug your web cam then restart your computer after then when computer loaded all programs and stable plug your web cam when pc recognizing it and ask for driver then put cd and follow the wizard instruction guide.
Posted on Nov 01, 2008
Sir my computer was formatted and now web cam is not working
Download the driver for the web-cam from Logitechs website.
Mar 05, 2011 | Logitech QuickCam Pro 5000 Webcam
Installed Philips SPC630NC web cam will not display picture on Msn Messnger live just a green screen, all drivers have been checked and software but just a green pictur, it wont work on any other cam site...
Set your mic as default
Vista
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
If it fails to work here concentrate on your webcam drivers and software before moving forward.
Set your webcam mic (if it has one as default)
Vista -
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - (if not - make sure the webcam is set as default - restart MSN)
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Jun 15, 2010 | Philips SPC 630NC Webcam Fun - Web camera...
My create web cam VF0470 microphone is not working for skype
make sure its set as default on your computer
TEST SPEAKERS
Restart computer
CONFIGURE TO SKYPE
Not working ? - troubleshoot your drivers and software - get your cam working before moving on
Working OK ?
CONFIGURE TO SKYPE
Connect webcam
Its good practice to disconnect and re-connect your webcam before you start (To reboot the webcam software) - if you have been using it elsewhere the SKYPE software may have difficulty in locating it, even if you exited the previous program correctly.
Start Skype.
On the 'Tools' menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Run down the list setting your defaults
Select your webcam as the default microphone.
Make a free test call
Click 'Save'
In the navigation pane of the Skype Options window, click Video Settings.
This will launch your webcam
Adjust quality of picture in 'Settings'
Check the correct webcam is shown as default
Click Save
Test your webcam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site:
http://support.skype.com (http://support.skype.com)
Jun 14, 2010 | Creative Labs Live! Cam Notebook Pro...
Mic trouble
I have installed software, web Cam works fine.
Down loaded SKYPE ,but when speaking with another person ,I could see them and hear them OK, but they were unable to see me although sound communication was fine. Is this a web cam setting problem or Skype problem.
Oct 12, 2008 | Logitech QuickCam for Notebooks Deluxe
Web Cam Mic
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Desk Mike or Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Jul 26, 2008 | Labtec Webcam Pro
Logitec Pro 5000 not being recognised by USB Port
Hi .
Had same problem:
uninstall quickcam 5000 v11.50 drivers.
install quickcam 4000 v10.51 .
There is few files missing ( /removed) from version 11.50.
rob
Aug 28, 2007 | Logitech QuickCam Pro 5000 Webcam
Usb extention lead doesn't work with webcam
So you know the cam is ok and the cable, so you will have to point to the usb port not being able to push enough power through the cable to the camera as it must take a higher voltage than the other cam. Make sure that the other cam software is uninstalled and you have done registry clean in case of conflicts and also try using a different usb port but install the camera with the driver again using the extension in it, aplogies if you did, i am assuming you may have installed the camera directly without the extension cable.
Apr 29, 2007 | Logitech QuickCam Pro 5000 Webcam
Sound
they may need to increase the mic volume in the sound settings, and even better if they are using a laptop it may well have mic boost in the settings. Tell them also to make sure they set the cam up in the relevant im programme they are using.
Feb 09, 2007 | Logitech QuickCam Pro 5000 Webcam
Logitech QuickCam Pro 5000 Webcam Logo
71 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
