Question about MPC Computers ClientPro 414 All-In-One PC Desktop
Mpc all in one computer 414 power light shows but the screen is black
I bought used online, 512 mb,40gb, but nothing is showing on the screen, I think the video card might be missing is that the reason?
  • 1 more comment
  • Anonymous Nov 17, 2008
    I have the same problem on a similar machine. If I plug an external monitor into it, it works fine.
  • brdstf40 Jan 02, 2009
    I'm having the same problem. On start up, however, I can see a brief MPC logo.
  • Anonymous Feb 05, 2009
    I have had the same problem with three units and contacted MPC who replaced them. Now that they have filed for bankruptcy and have no support left I have two more All-In-Ones w/ same prob. That's right a total of five out of 10 in just the past year. Granted they were all 4+ years old when the issue occurred
I have a couple hundred MPC 414 and 424, 95% have been great machines lasting almost 4 years in a constant "on" work environment. However 5% have experienced the "black out" issue this is caused by the power inverter located inside of the monitor housing next to the LCD display. The 414 and 424 have different model inverters and are not interchangable. A company name Chingawa makes them, but like everything else only made a minimum amount and replacements are very hard to come by. Good luck with your search. Plug a external monitor in and see what happens.
Posted on May 19, 2010
    Problem Solver:
  • 10 Answers
It sounds like you are having 1. A hardware conflict 2. System Setup could have the Montior turned off 3. Bad Video Card With an external monitor plugged up and it working it doesn't sound like a video card it sounds like the actual monitor has died
Posted on Mar 18, 2009
    Scholar:
  • 44 Answers
In short, no -- the video card is probably not missing. The video card in this device is fairly easy to remove (or check if it is installed/reseat). The following assumes you have the "boomerang" stand:
#1: Lay the system "face down" so that the LCD panel is resting on a flat surface (preferably soft/clean surface)
#2: Remove the two chrome-plated hinge caps on the stand (you have about a 50% chance of breaking them, so don't feel bad if you do)
#3: remove the plastic hinge cover - you should be able to remove it by applying gentle pressure with your fingers. Just wiggle it up and down and it will pop off.
#4: remove the boomerang stand. This will require removing 4 or 6 screws.
#5: Remove the metal door that covers the VGA card - this is held in with 4 screws
#6: The VGA card should be installed in the "cavity" you just exposed. The card is completely covered by a heatsink, and won't be visible, but it will fill the "cavity" completely. If you just see 3 big connectors, you're missing a video card. The card itself is probably held in with 3 screws. You can remove it if you want (using the handle) to reseat it, but it shouldn't be necessary.
Does your computer make any POST beep? It should make some sort of beep when powered on. If not, you might have bad RAM, a bad CPU, bad motherboard, or corrupt BIOS. I don't know if the CP414 has a built-in BIOS recovery mechanism (I don't think it does, but I know the 424 and 434 do). The easy way to determine if it does requires a floppy drive. If you have a floppy drive, and the system tries to access it every few seconds after powering on, then you have a good chance of recovering it (search google for "AMI bios recovery floppy"). Otherwise, you need a miniPCI POST diagnostic card to do much testing. You can buy one on ebay for under $10. Just make sure it fits into a MiniPCI connector. There is a door on the back of your system that covers two miniPCI slots. Either one will work with a debug card.
A few people have mentioned that it could be an actual LCD problem. I agree that it could, but only if your system boots with no display. Your description of the original problem doesn't provide enough detail to draw a real conclusion. Does it boot into Windows? What happens if you connect an external monitor? Do you have the 17" display or the 19" display (or the 17" touchscreen for that matter)?
Posted on Jul 01, 2009
MPC Pro 414 all in one. The power led lights up on the computer when pressed and the hard drive spins up but computer does not boot and the dvd tray will not open. I also cannot get into the bios as the...
check to see if all the power supply to the PC are present and of proper voltages, if not change out the power supply and try again, if OK, try removing and inserting all the support PC boards, there may be a connection problem, also try disconnecting the DVD drive as there may be a fault there , let me know how you did with that, i have other possible solution's, but these are the first to try
Jan 27, 2010 | MPC Computers ClientPro 414 All-In-One PC...
Where can I find a power supply cord for an MPC 414 All-ion-one
From what I've read MPC declared bankruptcy last year which makes finding those parts somewhat difficult. However, ECS manufactured MPC and its associated parts. Therefore, if you visit their website, choose your location, browse to their support section, then contact them (via email or phone) they will be able to get you information on the power unit and, possibly, where to purchase it.
http://www.ecs.com.tw/ - ECS Website
NOTE: From my initial research, the power cords for the MPC 414 does not seem to be inexpensive.
Let us know how things turn out.
Dec 29, 2009 | MPC Computers ClientPro 414 All-In-One PC...
I need IDE adapter for MPC 414. Hard drive to MB,fits in caddy. Appears to be an edge connector?
You can contact Patrick Albright at Tangent, 1-800-342-9388 x1772 they are carrying the MPC parts these days. I just talked to him.
Aug 21, 2009 | MPC Computers ClientPro 414 All-In-One PC...
1 GB RAM showing 512 MB
That can be taken by The onboard graphics card. please have a look on oi on your bios menu.
Apr 04, 2009 | Intel Computers & Internet
Computer wallpaper changes automatically on reboot
dear sir
it's windows genune software earror first of all when i start yr pc it's show some counting 5 to 1 and then yr windows start if it's show as i say u have to register yr windows with online regration other wise after some days it's loked if u have a windows product key then try to register by telephonic support... it's help u...:)
Thanks
please vote
jo_Chinmay
Jan 03, 2009 | Computers & Internet
Coby mpc-854 512 mb
My coby c888 says No Files so therefore there is no music.
What do it do?
Aug 25, 2008 | Coby MPC-848 MP3 Player
When i add a memory in damaged DIMM slot showing black screen?
Try moving the working DIMM to other slots, it should work in any slot, if it does, the other ram u have is incompatible or bad
Install a matched pair of DIMMs (equal in speed: DDR266, DDR333, or
DDR400; density: 64 MB, 128 MB, 256 MB, 512 MB, or 1 GB; and
technology: 128 Mb, 256 Mb, or 512 Mb) in DIMM 0 in both Channels A and
B. If additional memory is to be used, install another matched pair of DIMMs
in DIMM 1 in both Channels A and B.
Mar 25, 2008 | Intel D865GBF Motherboard
512 Mb memory upgrade
well sounds like compatible issue make sure it is ddr,sdr,ddr2 then check the speed and then checkto make sure that it is pushed in all the way in
Oct 18, 2007 | Acer Aspire 3610 Notebook
MPC Computers ClientPro 414 All-In-One PC Desktop Logo
1,471 people viewed this question
Top MPC Computers Computers & Internet Experts
Lee Durbin
Lee Durbin
Joe Goldman
Joe Goldman
orangeupstag
Level 1 Expert
Are you a MPC Computers Computer and Internet Expert? Answer questions, earn points and help others
