CD ROM DRIVE
MY CD ROM DRIVE IE NOT WORKING ERROR CODE 39 RUNNING WINDOWS XP
  • Anonymous Dec 12, 2008
    my laptop is old IBM ThinkPad T40. after i format it, the cd drive can't read any kind of cd. and also the left click event is lost. i work only by right click event. the other problem is after it restarts unless i pressed DEL + CTRL+ALT i can't open any file. And now i have got a virus and i have to reformat the laptop. But my cd drive doesn't work.how can i handle all my problems?
    please help me
I have problems our laundry machine model:W3400H it come up an "error rippel on dc bus"
could you please help me verify is problem.
Posted on Nov 01, 2008
My daughters Asus eee pc MK90H notebook says windows could not start because system 32 is missing or corrupt. It says to use the original CD Rom, which obviously we dont have. Help what do we do?
To restore a missing or corrupt ntfs.sys file you must have the Windows XP CD and follow the below steps.
Insert the Windows XP CD into the computer and restart the computer.
As the computer is starting make sure to press a key to boot from the CD.
In the Windows XP setup screen press the 'R' key to run the Windows Recovery Console.
If prompted enter the number of Windows installation you're repairing.
At the command prompt type the below command.
copy x:\i386\ntfs.sys c:\windows\system32\drivers
* In the above example you would replace x: with the letter of your CD-ROM drive. Many computers have the CD-ROM drive configured as the D: drive.
If ntfs.sys is still on the computer you'll be prompted if you wish to overwrite the file. If prompted, press the Y key for Yes to overwrite the file.
Once the file has been successfully copied remove the CD and reboot your computer.
Do NOT use an OEM "Recovery Disc". Only a valid Windows XP media will work or a disc from the OEM that says "Operating System" may sometimes work depending on how the manufacturer labeled the CD.
Hope this helps. Let me know if you need more information Thanks
May 11, 2011 | ASUS Eee PC 1000HE Netbook
Tip
Error code 7
To resolve this issue:
  1. If you are upgrading Windows 98 or Windows Millennium Edition, follow the troubleshooting steps that are described in the following Microsoft Knowledge Base article: 310064 (http://support.microsoft.com/kb/310064/ ) HOW TO: Troubleshoot Windows XP Problems During Installation When You Upgrade from Windows 98 or Windows Me Test to determine if the issue is resolved. If the issue is resolved, do not complete the remaining steps. If the issue is not resolved, go to the next step.
  2. Perform a clean installation of Windows XP:
    1. Insert the Windows XP CD-ROM into your CD-ROM or DVD-ROM drive.
    2. If Windows automatically detects the CD-ROM, click Install Windows to start the Windows XP Setup Wizard. If Windows does not automatically detect the CD-ROM, click Start, click Run, type CD-ROM drive letter:\setup.exe, and then click OK.
    3. Press ENTER.
    4. Click New Installation, and then click Next.
    5. Follow the instructions on your screen.
  3. When you receive the "Press F6 to load SCSI/Raid Drivers" prompt, press F7 to bypass Advanced Configuration and PowerInterface (ACPI) detection.
  4. Finish the installation of Windows XP.
on Mar 16, 2010 | Computers & Internet
Running Windows XP Home Edition Error code
The diags code was a failed response from the floppy drive. Most system didn't ship with one.
Boot to the XP CD, go to recovery console, run bootcfg /rebuild
http://support.microsoft.com/kb/330184
May 18, 2010 | Dell Dimension 8400 PC Desktop
Can not install windows xp in my system send error code 7
try this one:
    3. Press ENTER.
Mar 13, 2010 | Computers & Internet
Can not install windows Xp
What error messages are you seeing ?
Have you any codes given ?
Without knowing this it could be alot of things ie...
Could be bad memory, Bad CD or CD Rom Drive and so on...
Gaz
Jun 01, 2009 | HP Compaq Presario v3000z Notebook
Drive not showing in WinXP (error code 39)Liteon Combo SOHC-5236v
After loading the Windows, the DVD/CD-ROM drives work properly, but we can not see the drives in “My Computer” (System can not recognize the drives.). When try to run the drives, it shows up a notice “Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code39).” Before solving this error, check the drives connection correctly, then follow the steps below:
Delete Device Manager. Most people will firstly think of Windows “Find New Hardware” when drives missed, but it does not always work out. To fix the problem: open “My Computer”’ “Control Panel” ’“System”’“Device Manager”’ “HDC(Hard Disk Controller) ”, then click “Delete”. Follow the note to reboot computer. After rebooting, the computer will find the Primary IDE Controller and Secondary IDE Controller again and install the drivers. Restart the computer again while the installation is completed. In this, we can get back our CD/DVD-ROM Drives.
The other way is by editing the registry to return the missed CD/DVD-ROM drives (Code 39 error.). Obviously, it is too risky to edit the registry if you are not familiar with it. To fix the error from the registry, carry out the following steps:
Exit and close all applications currently running on your PC.
Step1. Click Start > Run and type in Regedit, press Enter.
Step2. Look for the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\ {4D36E965-E325-11CE-BFC1-08002BE10318}
Delete any of the following registry entries under this key directory:
LowerFilters
LowerFilters.bak
UpperFilters
UpperFilters.bak
Step3. Reboot your PC and open My Computer to check that the CD-ROM drive is visible.
Also, have a look at the Device Manager to see if the yellow exclamation mark and the error code 39 are gone.
System errors are not welcome guests that bring up unhappy computing experience. Registry Easy (www.registryeasy.com) is a professional troubleshooting system maintenance tool that can help you to solve this error and many more.
Article Source: How to fix DVD/CD-ROM drives (Code 39 error) in Windows XP or Vista
Posted on 2 January '09 by , under TECH NEWS.
This worked for me.
Feb 12, 2009 | Lite On (SOHC5236V) CD-RW/DVD-ROM Combo...
LG CD-ROM CRD-8521B driver
go http://www.cdrom-drivers.com/drivers/77/77204.htm (thats driverguide: name temp; pass 512)
but that CD reader does not need drivers if you use windows98 Me 2000 XP 2003 or Vista... if its not working and your computer is ok you surely have connected something the wrong way.
Mar 15, 2008 | LG CRD 8521B Internal 52x CD-ROM Drive
CD-ROM Driver Problem
CD-ROM error codes cdr101, cdr102, cdr103 Test the CD-ROM drive.
Device Manager information and help Later versions of Microsoft Windows renamed this category to DVD/CD-ROM
Installing a IDE/EIDE CD drive Ensure you have a working bootable floppy diskette with CD-ROM drivers.
Click on the above links, Follow instructions.
Should get ya back in/ Please dont for get to Vote.Thank you.
Dec 14, 2007 | Compaq Presario R3000 Notebook
Computers & Internet Logo
202 people viewed this question
David Payne
David Payne
