Question about Cameras
Nikon D70 The flash won't pop up and a clicking sound when I push the shutter. Also get r03 error. Jenean Stone
  • Jenean31 Nov 01, 2008
    Thank you, but the flash still won't pop up.
    Master:
  • 763 Answers
Ma'm, try to check the settings mode of your camera it must have been flash disable. see also the bulb of your camera must be the flash bulb got defect.
Posted on Nov 01, 2008
  • Charris Suaybaguio
    Charris Suaybaguio Nov 01, 2008
    thank you for using fixya
    CHARCOIS
    Genius:
  • 1,011 Answers
Dear Sir/madam,
That's not an error, that's the space remaining in the buffer.The R03 or R04 message relates to the amount of shots you can take before the buffer is full. Try the camera on the Fine Jpeg setting and see what you get. Smaller file = more pictures before the buffer is full. Then you need to go into your CSM Menu, and scroll down to CSM #4, and turn LONG EXP. NR to "OFF".
thanks
good luck
    Genius:
  • 3,422 Answers
HI,
Remove lense, replace
Remove battery, replace
Change shooting mode - try full auto, jpeg not raw
Reset camera to factory defaults
Replace/format CF card
  • Priya darshan Nov 01, 2008
    one more thing to try ...
    put the camera in M (manual)
    set for a high shutter speed
    set for single shot mode (NO TIMER)
    remove the lens completely
    then try the shutter
Speedlight SB-600 TTL Flash: When I set my SB600 (mounted on D70) to TTL or TTL...
the sync speed for the sb-600 is onlt 1/200 on most cameras i think so if your shutter is faster then that then all you will see is black/ the curtans behind the shutter.
basicly just try again with a slower shutter speed
May 07, 2010 | Nikon Speedlight SB-600 TTL Flash
I can't seem to turn the flash on my Nikon D70 on! I've been playing around with it for hours and have read through the manual. I've followed the steps clearly, but nothing is working. The previous...
If nothing else it should pop up when you put the camera in A or M or S and then press the flash button on the side. It might or might not fire, depending on the light available, but it should for certain pop up. When you do this, you should hear a click and the flash should pop up. If you hear the click and it doesn't pop up, then it's jammed or glued or somehow being mechanically prevented from coming up.
In Auto modes, you can select the flash to off with the side button and the back rotary selector. This is where the flash symbol with the slash through it tells you the flash is off. If you push the flash button in Auto modes with the flash selected off, it won't pop up.
There are also some things the D70 can do to control external flash units that may be set abnormally.
The best way to make sure those aren't messing you up is to select "reset to default". That will take the camera back to a base setup that should work.
If none of these things gets it going, take it in to the Nikon dealer in town.
Sep 01, 2009 | Nikon D70s Digital Camera
Nikon D70 lens won't let me shoot
Remove the lens being careful not to get dirt/dust in the camera(very important).
Clean the metal contacts around the lens and on the camera where the lens and camera meet. Your error sounds like a lens communication error.
Again!!! Do Not Get dust/dirt/moisture/ anything in the camera.
Apr 03, 2009 | Nikon D70s Digital Camera with 18-200mm...
Nikon D70 Shutter Problem
I have a Nikon D70 which failed completely but exhibited similar symptoms.
I was fortunate in that I had taken out 3 years free warranty at the point of purchase and therefore saved the £90 (sterling) repair cost.
Nikon cameras are designed to be robust and should give a lifetime's service. Most should give 150,000 shutter actuations.
There is a piece of free software available on the Web that will tell you how many actuations were recorded on your recent photos.
Unfortunately, in the fast moving world of digital cameras, the value of a 2nd user older camera is very low.
You need to decide if you were outgrowing this camera body and want to replace it with something better or whether you would be lost without it. My repair took more than 1 month and I was not able to take any photos during his time.
I hope this helps.
Jan 15, 2009 | Nikon D70s Digital Camera
Nikon D70 Flashing
ERR is i think an error message generated when the camera can not read the cf card ? have you had an problems with corrupted images ?
Sep 24, 2008 | Nikon D70 Body Only Digital Camera
D70 and SB800 sync issue
On the D70 custom menu (Pencil icon), there is an option to Synchronise shutter speed below 1/60 second (the default).
See 21 Shutter spd.
You can select anything from 1/60th to 30".
Aug 26, 2008 | Nikon D70s Digital Camera
Error Code
No, it's not an error. What this display indicates, is the availability of the total number of photos you want to take. If the display says, "r06", then you are in JPEG Mode. If it says "r03", then you are either 1) in RAW Mode, or 2) have your Noise Reduction on (see FAQ #2). As you take a few photos in succession, you will notice the indicator drops by how many photos you took.
Mar 01, 2008 | Nikon D100 Digital Camera
Images not downloading
Hi, Have you ran disk utilities to repair disk permissions on the Mac lately? The app is usually in the Applications folder in Utilities.
Jan 09, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Nikon D70 - err - won't take picture
Today I was taking photos and the camera quit...the top display says err. The book says release shutter, but I push the shutter and it does nothing but make a little click and the err stays. I took the lens off, and the camera does look like the shutter is open or something.
Sep 28, 2007 | Nikon D70s Digital Camera
Cameras Logo
285 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
