Question about THQ Company of Heroes for Windows
Compagny of heroes
We've got a new computer for my son run vista 32 bits, after installing error code 10028:80004005. Whats the problem
    Scholar:
  • 59 Answers
Hello sir... The game is having some known issues with Vista. One way to overcome this error is, Install the game to a different directory other than the default.The default is "c:/programfiles/THQ/COHOF". U better create a subdirectory like "C:/programfiles/games/THQ/COHOF". If this fails, install it in another drive like D:/ or E:/.
Let me know if this helps.
Posted on Nov 01, 2008
I have recently bought a new computer and i installed the software, but the machine will not recognise the computer, can it be installed on computer with the new windows 7 or do i need an update??
Yes, it can be installed on Windows 7. Check the Futura support sight at www.Futura-support.com and look on the right hand side under downloads. There's a download listed for CE150/250/350, etc, that applies to XP 32 & 64 bit, Vista and Windows 7 32 & 64 bit. Follow the directions CAREFULLY! If this doesn't work for you, I've posted a set of instructions under CE100 solutions for running the CE100 software on Windows Vista/7 by installing a Virtual Machine software on Windows 7 that works regardless of the situation.
The update should work for you perfectly, however. Just make sure you uninstall the Futura software and reboot your machine BEFORE you do anything else and follow the instructions from the website carefully! Good luck!
Jul 29, 2010 | Singer CE350
Windows Vista: I cannot install anything at all.
Is your Vista a 32 bit or 64 Bit O/S
open this link and run the Windows readiness tool, This will help the PC unblock any failed updates for Windows and help you install the new updates.
http://www.microsoft.com/downloads/details.aspx?FamilyId=b4d90b06-c27d-4483-bc1f-04d43fa7b293&displaylang=en
Windows installer for Vista is Installer version 4.5, so the updates should fix the issue.
Jun 29, 2010 | Computers & Internet
Kodak wont install >>
i just installed my old kodak easyshare disc onto my new computer but when i am in the installation process it coimes up with the error code 11-84-32 ande it says that it cannot complete the installation. whats wrong?
Apr 14, 2010 | Kodak EasyShare C330 Digital Camera
Can i convert a 32 bit to a 64 bit
You can use the Upgrade option during Windows 7 installation, which preserves your files, settings, and programs, only if you're currently running a 32-bit version of Windows Vista and you want to upgrade to the 32-bit version of Windows 7. Similarly, if you are running a 64-bit version of Windows Vista, you can only perform an upgrade to a 64-bit version of Windows 7. For more information, go to Upgrading to Windows 7: frequently asked questions on the Windows website.
If you want to move from a 32-bit version of Windows to a 64-bit version of Windows 7 or vice versa, you'll need to back up your files and choose the Custom option during Windows 7 installation. Then, you'll need to restore your files and reinstall your programs. For more information about performing a custom installation, see Installing and reinstalling Windows 7‍.
gl_ico.png Notes
  • To install a 64-bit version of Windows 7 on a computer running a 32-bit version of Windows, you'll need to start, or boot, your computer using a 64-bit Windows 7 installation disc or files.
  • If you start your computer using a 64-bit Windows 7 installation disc or files, but your computer isn't capable of running a 64-bit version of Windows, you'll see a Windows Boot Manager error. You'll need to use a 32-bit Windows 7 installation disc or files instead.
  • Windows Easy Transfer can't transfer files from a 64-bit version of Windows to a 32-bit version of Windows. If you're running a 64-bit version of Windows Vista but you plan to install a 32-bit version of Windows 7, you can move your files to an external location manually or use Backup and Restore in Windows Vista. For more information, go to Back up your files and
Apr 08, 2010 | Dell Precision Workstation 490 - MT -...
I am trying to install AutoCAD 2004 on my new computer with windows 7 and wont install. Any ideas?
AutoCAD 2004 and Windows 7 are NOT compatible. You will need to upgrade to AutoCAD 2010 either 32-bit or 64-bit. Even with the upgrade, there are known limitation issues.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14056444&linkID=9240617
Jan 03, 2010 | Autodesk AutoCAD 2004 for PC
Installing Adobe Photo Deluxe 2.0 on Visat
You may need new software, you might want to look for it on the web. Is your Vista 32 bit or 64 bit version? If 32 bit, you might be able to run it in compatibility mode.
Oct 03, 2009 | Microsoft Windows Vista Ultimate Edition
Epson stylus photo r340 can't connect!
It shows on Epson's website that it supports Windows Vista 32-bit but it did not tell if it support SP2. It only means that it doesn't since you are encountering error on your computer.
Try to install it on another computer that is running Vista 32-bit SP1. If it works then it only means that the drivers are working but not compatible with Vista 32-bit SP2 yet.
Hope this helps. Thank you and goodluck on your troubleshooting.
Jul 24, 2009 | Epson Stylus Photo R220 InkJet Printer
When I tried to initially install the software on my new Dell computer for my new and not connected Epson NX110 printer I encountered the following error message: Epson.EXE: Epson.EXE-Bad image Epson Xtra...
the new dell pc comes with vista operating system . the printer drivers u were trying to install is not compatible with the operating system : follow the link or copy paste to download the drivers for vista operating sysytem .
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=128284&infoType=Overview
note :
1. make sure u leave no traces of old printer drivers on ur new pc .
2. make sure if u have windows vista 32 bit or 64 bit os ?
3. still having trouble ..
reach me @ http://www.crossloop.com/ironcross
Jul 20, 2009 | Epson Office Equipment & Supplies
O s
The four things that make 64-bit Vista inadvisable for ordinary users are:
1: No compatibility with old 16-bit Windows apps. This means ancient Windows 3.x software, which most people don't run any more, but 16-bit code can still pop up in the darndest places. Like, for instance, in the installer programs for other apps.
2: No automatic registry and file redirection, which is what 32-bit Vista uses to allow existing software to work with Vista's better user account security, even if the software wants to do admin-rights stuff to the registry and Program Files directory. Many apps still break in 32-bit Vista, but many more break in the 64-bit version.
3: No compatibility with existing 32-bit drivers. Everything on your computer will need a new driver. 64-bit WinXP is the same, and there aren't many 64-bit computers on which Vista won't at least install, but 64-bit Windows also has...
4: No support for unsigned drivers.
Jan 28, 2008 | Computers & Internet
THQ Company of Heroes for Windows Logo
424 people viewed this question
Top THQ Video Game Consoles & Games Experts
Jimmer_9
Level 1 Expert
James Wishart
Sandeep Kumar
Are you a THQ Video Game Console and Game Expert? Answer questions, earn points and help others
