it's sure that the hp j4580 entries are still existing in the computer
if the installation was done with the cd-rom then please do the following steps:
insert the cd-rom into the computer
do not auto-run the cd
go to the hp cd icon in my computer
right click on cd icon
then click on open
then look for folder named util
under util right click and open folder ccc
then under ccc you will look for a file l3 uninstall or uninstall.l3
right click on it and click on open
then disconnect the usb cable from the printer(in case it is a wired installation)
go on selecting the files that the uninstaller will show
then do not restart
then go to the control panel
go to add or remove programs
remove the hp softwares if exists(hp j4580 required software,hp solution centre,hp imaging device,hp customer participation program,shop for hp supplies,etc.. )
then go the start icon
go to the run option
enter "regedit"
then registry opens up
click on h-key local machine
select software
then select hp printer entires that are highlighted
then delete them from the registry
restart the computer
then download the fresh version of j4580 from hp.com
then install the software
the issue will be resolved
for a software download install:
go to the folder where the downloaded version is saved
then right click on the software and click on `run
then close the folder
then go the temp folder
by writing the command in the run box
%temp%
then look for a folder that starts with the name"7z........."
open that folder then look for util folder
then the steps mentioned above will be done
please try this and the issue will be resolved
if the issue remains unresolved
please revert back
Go to printers an uninstall, or remove that printer. Then Go to HP.com, and download the correct software and follow those directions exactly, specifically do not use Plug and Play.
DONT CONNECT PRINTER WHILE INSTALLING PRINTER SOFTWARE....IN THE MIDDLE OF INSTALLATION IT ASKS TO CONNECT PRINTER............. THEN ONLY INSTALLED PROPERLY
I've seen this a few times with Vista but each time it seems to be something different. The first thing to be done is make sure you have all the current Vista updates and including SP1. Once that is done I would completely uninstall the HP software. Then download the latest version of software from HP and install. Vista has alot of qwerks that sometimes defy answers.
Please do the following
1. Go to Control Pannel then sellect Add/Remove Programs and uninstall all HP Software.
2. Disconnect all Prinetrs
3. Go to Control Pannel then sellect Printers and Faxes make sure there is no Printers in there if there is delete them
4. Install Psc 2210 software and follow instructions on when to connect printer.
Your computer crashing several times a day is the bigger issue here. You need to resolve this first. Update your OS software, your disk probably should be wiped, reformatted and reinstalled cleanly. After that, I suspect that your printer problems will go away.
