Question about Miller RENEGADE 180 WELDER GENERATOR MIG 907395
Renegase 180 my wire keeps bunching up before it gets into the liner, if everything is not perfecely streight. why dose it do that, my miller 250 dosn't have this problem
  • malma21 May 11, 2010
    What size wheels are on it and size is the liner? also have you tried to adjust the tension?
  • 92 Answers
This fault is typical in most MIG/MAG Units. the feed roller/s need slackening off, pull the trigger so the rollers spin wire the wire not moving, turn the tensioning 1 turn check to see if the wire feeds, if not give a half turn on the tentioner repeat this half turn untill the wire feeds, bend the wire to the torch and pull the trigger, If the wire feeds then thats the correct setting. be awear of all safety rules. use gloves
Posted on Dec 25, 2008
I have a IRON MAN 250 Mig Welder. that the wire don't feed, with regularty. I have a miller with the same tourch that dose the same thing. If you pull about 4 or 5 inches of wire out, with trigger...
Hi:
If you see rust on the wire then you should stop and change the gun's liner, change the contact tip and clean the feed rolls. Rust can accumulate inside the gun and make the wire feeding a problem.
Aug 21, 2011 | Hobart Welding Tools
I have a millermatic 130 and the wire keeps getting wound up around the wire assembly
First thing to check is that you still have an inlet guide (plastic funnel like) before the drive rolls. This one can be dirty or have enough build up inside that makes the wire feed imposible. Change this one if possible, it will cost you around 5 bucks at your near welding shop. If everything looks ok, then make sure you have the right drive rolls size, 023 or 030 in this case. Then ckeck you liner if it has a kink or dirty in the inside (use compressed air to blow the inside of the gun) then it's useless, change it. Final will be the contact tip just replace it for the right size according to the wire size.
Jan 09, 2011 | Miller matic 140 Mig Welding Package W/As...
Millermatic 180 wire don't feed lights won't come on fan keeps running
Machine will run only on 220V, check your braker nust be at lest 20Amp.
Dec 18, 2010 | Miller MATIC 180 MIG w/cart/AND SPOOLMATE...
How do i disconnect the main electrical lines from the liftgate? I need to replace the entire gate. I can get everything off, but i dont see any electrical connector. just a bunch of wires??
On the head liner, all the way to the back, remove upper trimming, pull down on head liner, you'll see connection, and also pull the rubber through the frame, to pull harness out.
Aug 05, 2010 | Ford Explorer Sport Cars & Trucks
What is the correct gas for miller renegade 180 weder generator mig
Depends on the application and type of wire you are using. If you are using flux cored wire you want Co2. If you are using mig wire 75/25 blend (Argon/Co2) would be my choice. Your wire should also give you a recommendation of which type to use.
May 07, 2010 | Miller RENEGADE 180 WELDER GENERATOR MIG...
Spool wire starts to melt while on the spool
1] Switch off the mains power,remove the torch from the machine,ther should be a button or switch on the unit to feed the wire, push or switch these and observe that the wire feeds and dose not heat up, if ok then you have a short in the torch, a new torch assembly is required,if the wire heats up with the torch removed, the wire spool is shorting out, remove the spool and check wiring in and around the feed motor, if you can't see anything check for a voltage from a good earth and on the rollers, if you have a voltage then the motor is faulty.(earthing out) a P.A.T test should show exactly where this is.
Feb 16, 2009 | Miller RENEGADE 180 WELDER GENERATOR MIG...
Mig proplem
Check the feed wheels at the wire spool make shure they are installed properly tight them if needed >>change tip >>
liner may need replaced.>
Dec 25, 2008 | Miller RENEGADE 180 WELDER GENERATOR MIG...
I have a miller 180 autoset that does not feed the wire
If your welder is less than 3 years old your local Miller authorized service center will repair it for FREE. They can also check the serial number of your welder over the phone to see if it is still in warranty. For goodness sake DON'T tell them you've been mucking around inside the welder or they won't be able to help you.
That said, if the welder spins the feed wheels without any wire between them it probably isn't the board. There is the switch in the gun, the board, and the motor and brake assembly all needed to feed the wire.
Oct 18, 2008 | Miller MATIC 180 MIG w/cart/AND SPOOLMATE...
Miller RENEGADE 180 WELDER GENERATOR MIG 907395 Logo
259 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
hubiam
hubiam
Level 1 Expert
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
