Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore Elite Side by Side Refrigerator
The motor in the Ice depenser has stopped working. I have the new motor but I can not determine how to get to the old motor. Can you help
  • 59 Answers
If you open the freezer door you will find a panel on the top side of the first self under the ice container. It has two 1/4 inch screws securing it and there are four 1/4 inch screws holding the motor. You cant see the panel while standing so you'll have to get down and look up at it. If you have any more questions just let me know. Good Luck!
Posted on Nov 02, 2008
Kenmore Elite model # 795.77564600 refrigerator stops cooling; display on left side door reads ER FF
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 15, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The ice maker works perfectly in my Sears Kenmore Elite Refrigerator, but the ice crusher doe snot work. When i put the glass under or I push the lever, no ice comes out. I have removed all the ice sevral...
Push the lever to dispense ice and listen for a small click sound,(the micro switch). If you hear a click you will have to determine if there is a broken wire to the dispenser motor or if the motor itself is defective, This will not be a visual diagnosis unless you fine a broken wire in the hinge area.
Eric
Nov 19, 2009 | Frigidaire FRS-26DR7D Side by Side...
I have a Kenmore Elite side by side refrigerator/freezer and just had the ice dispenser motor replaced a month ago when we first moved in our new house. However, our daughter left the freezer door ajar...
It would not hurt the motor as they are built to be exposed to some degree of moisture if the defrost does not work i would check and see if something is jamming the actual mech. up. In my ice dispenser i had stuff fall in from the shelf's and seized up the motor. Any how if the thaw does not work check out a motor at repairclinic.com (http://www.repairclinic.com/SSPartDetail.aspx?s=t-106.53769202-%3d%3dc203i1057785&PartID=1057785)
Jun 06, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice tray freezing
the water inlet valve may not be closing properly due to dirt or some mechanical problem in it. u can clean and try
Mar 10, 2009 | Kenmore 50522 / 50524 Side by Side...
Replacing the Ice dispenser motor on Kenmore elite refrigerator?
There is a small door under neath ice maker shelf (literally) w/ 2 small screws that keep it in place,or a button that can release ice maker on the rt. side of machine. Good luck!!
Dec 30, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker in a Kenmore Elite Side by side refrigerator
check the head of the icemaker and see if the gear is broken on the module
Nov 26, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
New Kenmore Elite ice dispenser not working but water is
Should be no longer than 24hrs. Is the freezer good and cold.. has to reach a certain temp before icemaker activates. Might take little longer if you put a lot of warm things in freezer or refrig. when you made the change. Is there any water or ice in the icemaker itself? Water may not be getting to icemaker call them back out if it dont work soon thats what warrantys for :0)
Sep 02, 2007 | Whirlpool ED2FHEXN Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
55 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
