Question about Sherwood AVR-525 Receiver
Sherwood R 525 memory loss
My receiver looses the tuned FM channels when switched off. It also at times loosed the display that indicated the inputs...
Help
Mark Dewey
mark@mct.co.za
    Problem Solver:
  • 5 Answers
Same thing happened on my R-925RDS. The memory backup capacitor in this case is C322 on the front panel PCB, over on the far left hand side by the mains power button.
In the case of the 925 it's a 0.047F 5.5V capacitor, a small black block approx. 10mm high with 10x5mm footprint. In the service manual it's referred to as 0.047uF, but this is incorrect. Replaced it with a 0.1F 5.5V memory back up capacitor, all's well.
If replacing the capacitor, BE CAREFUL where you mount it! Putting a standard (round) backup capacitor in the exact location of the old one may bring it very close to the mains switch. What I did instead was mount mine about 2 inches closer to the centre of the board, using double-sided tape, and ran wires back to its connection points.
Posted on Jan 03, 2010
  • Sherwood Master
  • 5,444 Answers
I have a Sherwood R925 it lost all programmed inputs like that. It turned out to be a Memory Retention Capacitor that had failed. Look on the display board inside. They are often small and low value. If you are no good at repairs it would only cost less than 1.00 for the part, so worth repairing.
Posted on Jan 21, 2009
I want to hook a amplified antenna to my sherwood receiver what kind of cable or wire should i use?
You can use standard TV cable (RG-59/U) or for a long run the white RG-6/U which has lower signal loss
Feb 18, 2013 | Sherwood RX-4105 2-CHANNEL...
Lost all radio stations on my Sherwood RX4030R
It certainly sounds like the main tuner has failed, if IC301 does that function I would replace it and see what happens.
May 25, 2017 | Sherwood Audio Players & Recorders
Every time the machine is switched off, it looses all the tuned channels. The on screen display shows 'No Signal' so I have to retuneeach time
You did not specify the make and model number..in general ,like computers this units have Built in MEMORY BATTERY ..( some times CAPACITOR ) ..How old the machine ? your battery/capacitor may have failed and than cause such symptoms.
Oct 09, 2011 | Televison & Video
Brookstone SLCDv2.0 The device clearly has a Memory capability since there is a "Set" button and the display shows "Memory" when the button is pressed at a particular FM station. ...
Hi, The receiver does have an in built memory to store upto 6 channels.Please follow the steps below to set up the radio memory:- Up to six favorite radio stations (3 AM and 3 FM) may be stored in memory. the following are steps to set radio memory: 1. Press tUnInG/bAnD to select the band. 2. turn tUnInG/bAnD to locate the desired station. 3. Press the M button. the "M" indicator flashes on the LCD Display. 4. Press 1, 2 or 3 to store the selected station. 5. Press the M button again to confirm. 6. repeat steps 1-5 to set other memory stations.
Incase you would require any information do refer the below web site where you could find picture representation of the same. http://www.brookstone.com/linkedassetservlet?assetId=71937&languageId=EN
Thank you for your time and best wishes for your effort.
Jan 11, 2011 | Audio Players & Recorders
I have a lg 52lg50 lcd tv,everytime i turn tv back on,i lose all my channel memories and re auto tune,its not the cable because if i disconnect tv while on and hook back up channels are there .only when i...
This memory loss issue sounds like a problem with the main board inside the TV. The channel memory should not erase after a power cycle.
You are probably loosing other custom programming like your Display and Audio settings. That is if you had modified something in these menus.
You may want to check to see if this is also happening by making a change in like the Display menu, and then turn the unit off and back on.
The TV has a one year warranty on parts and labor.
May 20, 2010 | LG 52LG50 52 in. LCD HDTV
Memory troubleshooting on sherwood RV 5080 R
Hi Francois,
i own the same receiver with the same problem, but solved it according the following (german language) instuction with photos:
http://ekkart.de/rauhesitten/?p=198
I changed the broken capacitor against a gold cap.
regards, Bernd
Aug 24, 2009 | Sherwood AVR-525 Receiver
FM Tuner in Sherwood RX-4105 stopped working
Check your antenna connections. Make sure your FM antenna is hooked up to the FM antenna terminal or jack on your Sherwood receiver. If you have the antenna hooked through the coaxial cable, check your coaxial cable with an ohmmeter for continuity. You can buy a volt-ohm meter as little as $12. Usually bad connection occur between coaxial cable and the the coax cable connectors. If that doesn't solve the problem, then there may be something wrong with your tuner card inside of your Sherwood receiver.
If you receivers display does not change channels or frequencies or AM or FM mode, when you try to change the channel or frequencies, or AM or FM mode, there may be something wrong with the front board of your receiver.
If there is something internally wrong your Sherwood receiver, you need to take it to a qualified technician that can fix it. Do not try to repair it yourself. If you don't know what you're doing, you can do far more damage to that Sherwood receiver to the point that would be very costly to repair.
Before you take your Sherwood receiver to a technician, try to unplug the receiver, and leave it unplugged for several minutes, and then plug it back in. If that doesn't solve the problem, then you need to take your Sherwood to a qualified technician.
Dec 02, 2008 | Sherwood RX-4105 Receiver
Onkyo TX-DX838
I went back and found a loose cable/coax. Re-attached and now the receiver works as good as ever.
Sep 02, 2008 | Onkyo TX-DS838 Receiver
Sherwood AVR 525 Receiver
If it is just a 2 pin "figure of 8" type plug(shaver plug) they are available most any electronics hobby shop, or an appliance retailer. If you have trouble identifying the socket on the amp... get back to me here. Good luck:)
regards
Graeme
Feb 15, 2008 | Sherwood AVR-525 Receiver
Sherwood AVR-525 Receiver Logo
714 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
