Question about Goodmans GPDR40 Digital Media Player
Goodmans x-pro gpdr1 the screen doesnt light up when i turn it on whats wrong
  • 1 more comment
  • g1221es Dec 31, 2008
    i have the same probs, i press start, u can feel the hard drive vibrate, and blue light lights up, but no pic or sound, but am unable to switch off unless i press the restart button!!!!!!!!!!!!! could it be battery? if so, where can i get one from? any help be greatful, cheers.
  • samnii
    samnii Jan 06, 2009
    screen problem
  • samnii
    samnii Jan 06, 2009
    THE SCREEN DOES NOT COME
Have a Goodman GDH8 that the heat is not coming on, what do I need to do to get it running?
depress button for 2-3 sec light pilot manually then turn valve to on if it doesnt stay light u need to clean thermocoupler or replace it
Oct 05, 2016 | Goodman Heating & Cooling
Nothing working when thermostat turned on.checked voltage at transformer 110 at top and 24 v at bottom,cant figure out whats wrong .any ideas
Be the thermostat. Kill the power to the air handler so you do not burn the transformer. Remove the thermostat from the wall. Twist the red and white wires together and turn the power back on to the transformer. The heat should come on. If it does, the thermostat is bad. If it doesnt, do the same thing but twist the red, yellow, and green wires together and power the transformer up. The air should come on in cool mode.If it does come on then we know what to check next
Oct 27, 2013 | Goodman Manufacturing Goodman GMS81005CN...
37IN TV FLAT SCREN HAS SOUND BUT NO PICTURE WHATS WRONG
you lcd tv maybe have problem in inverter board if black screen? & maybe t-con board bad if lcd screen come on light up. maybe that could help? good luck!
Sep 07, 2012 | Goodmans GTVL19W17HDF 19 in. LCD TV
I was watching my Goodmans LCD TV when my picture went off but I still have sound any ideas whats wrong
you have no back light , the invertor pcb may be faulty or worse still the screen may have failed.
This needs a service engineer to diagnose properly
Feb 01, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
My goodman furnace lights runs for 15 seconds and
There is no way to guess what the problem is. I am a HVAC tech, I use a meter to troubleshoot the problem, you need to use a meter and troubleshoiot the problem
Oct 13, 2009 | Goodman Furnace Draft Inducer Blower ...
Goodmans TW28D11, Flashing green light, screen blank
well, if you have access to the owners manual, the flashing green light may be an error code. check the manual! if no manual, try their web-site, they may have a faq section for that model, or even an error code listing!
good luck!
Oct 08, 2009 | Televison & Video
Goodmans GPDR40 problem
I had the same problem like everybody else since 2005 . GOODMANS GPDR40 X-Pro personal Media Centre. After Initialise the screen freezes - MASS STORAGE
DIRECT PRINT.
I have suspected that was the battery at fault or something to do with the power.
Why?.Because i have managed to let the Goodmans work, but only for a long time when
connected to the main adaptor.
I use it to record Video from sky,Or to use the unit as a storage drive.
Here are the steps to regain possession of the Unit.
First discharge the unit by leaving the screen on when in direct print mode,
(Move the cursor down to access this mode, normally it does this automatically.)
Make sure the screen display stays on in order to help the discharging of the battery.
Having the screen on will not switch the unit off until the battery is flat.
To have the screen on press the top button again if the display revert to a blank screen.
Once the unit is discarged the the unit will turn itself off.
Now we can connect the power lead to the unit and start the unit once more.
It normally last a couple of hours or more,but it will stop again eventually.
My suspicion is that the battery charger control is not working right and
after a period of time, may be a year ore less, will cause this problem
to all these units.
I hope it works for you too, even if not as before.
Ciao a tutti!
You can contact me at this email address:
messinasergio@yahoo.com
Apr 10, 2008 | Goodmans GPDR40 Digital Media Player
Goodmans GPDR40 Digital Media Player Logo
190 people viewed this question
Top Goodmans Audio Players & Recorders Experts
Pavel Pranovich
Pavel Pranovich
Tom Chichester
Larry
Are you a Goodmans Audio Player and Recorder Expert? Answer questions, earn points and help others
