Question about LG Computers & Internet
DVD drive When I push the DVD drive to open, it won't. The computer is less than 3 years old. I have had this problem for sometime now.
  • 189 Answers
Good day!
Let's try to open your dvd manually. Look at your dvd drive you will find a small hole just beside the push botton, find a long pin push that pin side the hole, it will open you dvd. Push the dvd botton and try to open it again.
Thanks.
Posted on Nov 01, 2008
Ejecting a cd from a computer that has crashed
Method 3 - Force Eject Next, you can try to to force eject the CD/DVD tray to open. Not all drives and burners have this feature. To check to see if yours does, look near the face of the CD/DVD drive and you should see a small hole.
Use a toothpick, bent paperclip, or needle to push the button. This may or may not pop open the drive. Many people have reported that this does not work. But some have reported that it does.
or try this link.
CD or DVD Drive Won Eject or Open
Nov 03, 2017 | Computers & Internet
HOW DO I OPEN THE DVD ON MY ACER ASPIRE E1-472P-6860 OPEN DVD DRIVE
On the DVD drive door there is a very small rectangular push button. It is about 5/32 inch wide by 3/8 inch long. it may take several several attempts at pushing the button but it should open the drive. If it does not open up the My Computer icon of your computer and left click on the DVD icon. When the drop down box appears select eject and right click on it. That should open your drive. I hope info this helps you.
Jun 28, 2014 | Acer Aspire 5610-4648 Notebook
Brand new ASUS desktop DVD/CD R-W drive won't open.
hold the faceplate open, get a paper clip. There is a small hole in the front of the DVD/CD drive, place the paperclip in it and push slowly until the device drawer opens.
Jan 21, 2012 | ASUS Essentio Desktop with Intel Pentium...
The button on my DVD driver sticks or won't
You can find a new one on Amazon or Ebay for less than $40.00. But if you look very closely at the cd or dvd drive there should be a small hole that a paperclip will go in. Push the paper clip in about 1/2 inch and the drive should release and open. If not a replacement may be necessacery. YOU can actually find a Youtube video to show you how. Very Easy.
Jul 22, 2011 | HEWLETT-PACKARD Compaq Presario CQ61412NR...
Why do xbox say open tray on every game i put in an it wont play
Hi the problem is with your laser the chances are it needs adjusting so it will read the games again now the problem with this is that their are 5 or 6 different dvd drives for the xbox and only a couple can be adjusted but you wont know this till you find out what drive you have.
if the xbox is less than 3 years old its covered by warranty even if you dont have the receipt so have a look on the back of your xbox and check the date if its less than 3 years old go onto the xbox website and log a repair claim they will then come out and give you a working console and take yours back with them.
if its more than 3 years old or it has been opened before then you have got no warranty and you will either need to do the work yourself which involves taking the case off and taking the dvd drive out to find out what make it is, to do this you will need special screw drivers to undo the screws to find out what you need use google and search for xbox 360 repair guide, dont pay for a guide their are loads of free ones on the net, then once you have the case off you need to remove the dvd drive and check the make then using google again type in the following how to adjust the laser on a (give make here) then hit search.
if it can be adjusted you will need a multimeter to do this so you can get the reading off the pots you need to adjust,
now with the dvd once you have it out undo the 4 screws in the bottom then pull the top and bottom case off it, then if the laser is right at the other end and not by the middle of the disk then all you need to do to solve the problem is slide the laser back down the shaft so that its in the middle again near the part that spins the disk round, sometimes the laser moves to far up its runner and gets jammed so this may be the case with yours if the laser is right up the other end far away from the middle then just push it back to the middle and put it all back together and it will then work.
if how ever the laser is at the middle when you take it off then this means either it needs adjusting if it can be adjusted or it needs replacing.
if it cant be adjusted then this means you need to get another dvd drive you need to get one thats the same make as the one you have all ready got,
once you have got another drive you need to swap over the control board off your faulty dvd drive and put this onto the new one without doing this the new drive wont work at all.
your dvd drive is programmed to only work with your xbox so just fitting a whole new drive wont work you need to take the casing off your dvd drive and look at the bottom and you will see a small circuit board this is the control board you then need to unclip the wires and ribbons and remove the board from your dvd drive, now on the new drive you need to take the control board off that as its no good to you at all and put your old control board onto the new dvd drive then put it all back together and it will then be fully working.
if you are unsure what you are doing then please dont try it as you can cause more damage if you break any of the data ribbons,
i fix these for £25 so if you need someone else to do it just shop around and see what price you can get.
let me know how you get on or if you need further assistance ok
please rate this solution and leave testimonial as i have pages of unrated posts, as people forget to leave a response and rating, thanks
just ask if you need further assistance ok
Dec 11, 2010 | Microsoft Xbox 360 Console
I put a Hitach DVD-ROM/CD-RW drive into my computer. This was to replace a a DVD-ROM drive. Windows XP seems to have found a driver for it without my intervention (unfortunately I have various system...
Restart your computer.
When you see "Press DEL to enter SETUP",
press the 'DEL' key.
Stay in 'SETUP' mode.
Now, insert a disk into the tray, and close the tray.
If it stays closed, then your DVD-drive is working OK.
If it re-opens the tray, you have a hardware problem with the DVD drive. If your drive is less than one year old, it's probably still under "warranty". Exercise the warranty, and get it replaced.
May 26, 2010 | Office Equipment & Supplies
DVD Rom malfunction
welcome to fixya
if your computer is that old and you use the drive alot this could be you need a new drive but i would try tu update all the drivers first might just be a glitch in the driver ....
hope this helps you out
Aug 09, 2008 | Computers & Internet
Dvd drawer
If this device is less than a year old, still under manufacturers warranty.
I do not think many technicians will like to fix these devices due to the high cost in labor and sometimes even for newer devices is hard to find service parts.
Try unplugging the DVD recorder and plug it back in after a couple of hours, hopefully that resets the memory; sometimes it works.
Apr 25, 2008 | Lite On LVW-5115GHC+ DVD Recorder
Shw-160p6 problem with tray
CHANGE THE PIN SETTING JUMPER TO SLAVE AND PUT DRIVE BACK INTO COMPUTER
Jan 16, 2008 | Lite On (  SOHW1213SRETAIL)...
Dvd stuck
Open up a paper clip until as straight as possible,
On the drive for the dvd you will see a very small hole,
With the power off, Insert the paperclip in the hole GENTLY push when you feel a resistance, and the drive will open slightly, pull gently open and remove dvd,
Happy new Year
Jan 05, 2008 | Toshiba 14DLV75 14 in. TV/DVD Combo
Computers & Internet Logo
105 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
