Question about HP Compaq Presario V2000 Notebook
Installaton of bios under dos or any kind.
I have a hp dv2025nr not detecting hard drive (100gig seagate).Per check out with hp. i found out that the updated bios is F.39. while my laptop were only f.7.
What will i do to to reload the new bios without any windows.
  • HP Master
  • 4,338 Answers
Very carefully. Go to :
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3193478&lc=en&cc=us&dlc=en&lang=en&cc=us
Choose your operating system from the list. Then on the next window , near the bottom of the list you will find the Win Flash firmware. Click on it and follow the instructions very carefully. I stress carefully.
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 01, 2008
I am not able to instal OS in my home PC. Asking me to install scsi drive. my hard disk seagate. where download this flopply disk bios drive software
hi
Checked the Bios Setting and check whether the Hard drive is recognizing or not -
Check the Boot sequence
Check Boot from the CD Drive
Format the Hard drive
it will work
Feb 23, 2010 | Seagate 500GB Maxtor Diamondmax21 SATA2...
HP pavilion dv2025nr do not boot
Hi
please press DEL to set the bios settings then choose the Bios set up! then click the bootable device SCSI.
Thanks!
Jun 07, 2009 | HP Pavilion dv2000t Notebook
Harddrive is not detecting bios
get a hard drive kit that will connect it via usb or get a PCI card that will allow you to install the PCI card into a PCI slot and then attach the hard drive to the PCI card ( ensuring you select the correct PCI card ) ie if its a sata drive then get a sata PCI controller card and if its IDE then get an IDE PCI controller card.
Also check for motherboard updates for your computers motherboard and also check in the bios to ensure LBA is enabled and that its detecting the hard drive.
Apr 10, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Boot won't read
Operating system not found. Check hard drive for loose connection power and interface. Reseat it to be sure (power cord disconnected and unit totally turn off before you reseat it).
Go to Bios setting check whether hard drive is been detected or re-detect it to refresh. If harddrive is not detected. Check again for loose wiring. If now detected, reboot it should until the end of operating system loading.
If it say again " requires sytem disk" ,corrupted OS --- repair or reinstall.
Apr 08, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
My bios doesn't recognize my hard drive
Do the neccesary jumper cable settings. then manually detect it through your bios. If not detected, try to replace the ide cable. if still not detected, try to feel the hard drive if it spins, if not, the had drive is damage.
Mar 03, 2009 | Seagate Barracuda 7200.7 200 GB Hard Drive
Hard drive reported at zero bytes
see after teh utility named Partition Magic, It will solve these typoe of errors. Another cheap option is to try to format it with a vintage computes BIOS, HDD Formattion option, Not available in newer BIOS.
Tyr aldo Fdisk /mbr in the DOS PROMPT , booting with D.O.S. Ver. 6.0 Anyone remember this Operating system?
And the last option is to format the drive undel LINUX and thern get it back to Windows XP.
Jan 01, 2009 | Seagate Computers & Internet
Bios says no ide device found (hard frive missing?)
If the BIOS is not detecting your hard drive, then there are two possible suspects here. Could just be your hard drive or it also be your motherboard.
If you have already reseated your hard drive and memory and the symptoms are still the same, then go to the nearest local computer shop that sells HP. Have them try a known-good hard drive on your system. If it works, purchase a new hard drive. If it doesn't work, your mobo needs to be replaced.
Jan 01, 2009 | HP Compaq Presario v3000z Notebook
Seagate 20GB SATA hard disk not detected
Ok, look at the hard disks circuit board, look for rust or something suspicious.
Jun 19, 2008 | Seagate Barracuda 7200.7 40 GB Hard Drive
Disk error
repartition ur drive with xp bootable cd...... all data will be lost..
Jan 26, 2008 | Seagate Barracuda 7200.7 40 GB Hard Drive
Hard Disk Drive Not Detected
Does your hard drive get detected in the BIOS? If yes then you can recover data by plugging that hard drive as secondary and running a recovery application like Recover My Files.
Dec 23, 2007 | Seagate (ST3160827AS) 160 GB Hard Drive
HP Compaq Presario V2000 Notebook Logo
60 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
