Question about HP Office Equipment & Supplies
I keep getting the same message on my printer "the following printhead(s) has a problem: black/yellow (k/y)." I was on the phone with one of your techs in India and he could not help. He said he would have to do research and call me back Tuesday. I'm wondering if I need to replace the printhead.
  • HP Expert
  • 141 Answers
Yes
Posted on Nov 01, 2008
I am getting message "the
More black/yellow print head failure we observed in this series, no remidy for this issue replace the print head..
Sep 23, 2011 | HP Officejet Pro L7680 All-In-One Printer
Indicator says "Printhead Problem". The
You do not say what your make and model is. So follow the screen prompt and replace the black/yellow print head.
Jul 04, 2011 | Office Equipment & Supplies
Message on printer screen says "The following printhead(s) has a problem: black/yellow (K/Y).
This probably could be defective Printhead ( black/yellow )
Follow the steps below and it should resolve the issue, if not, you need to replace the K/Y Printhead. You can purchase it from any nearest departmental store like bestbuy or costco or walmart etc or Call HP and order one.
Open the front access door. ( printer must be power on )
Remove the Latch of the Printheads
Remove the Printhead
Clean the Contacts with lint free cloth ( golden contacts or electrical contacts / not the nozzles )
Re-install the Printhead back in its position and close the front access door.
The printer usually goes thru initialization process. or Turn off the printer and turn on.
If you still get the error message, Replace the K/Y Printhead.
Regards,
Ron
// Rate this solution with 4 Thumbs to help us improve the support
Jul 02, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
My office jet L7590 printer suddenly quit on me. It keeps playing a message that says the printhead has a problem
Did you let one of your inks run dry? If so, you need to replace the effected printhead. This model has two, one for black and yellow, and a second for cyan and magenta. If you let the yellow run dry but have tons of black, it still effects the black/yellow printhead. Same with the other, either color going dry makes its printhead go bad. Either printhead will set you back about $75. Easy to remove and replace once you get the new printhead.
Bottom line with this model of printer...DON'T let you inks run dry. A new ink cartridge is $20 vs. $75 for a new printhead.
FYI - This is the most common mistake/problem with this printer. The Inkheads are built to last at least 40,000 prints. That's several years for most of us, that is unless you let the inks run dry.
Feb 09, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
How do i solve printhead problems>
Clean the printheads. Follow the steps below to clean the printheads.
  1. Make sure the printer is loaded with unused white paper.
  2. Press Setup on the device control panel and select the Tools menu.
  3. Press 3 on the Tools menu to begin the cleaning process.
May 19, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
My HP officejet Pro L7580 says the printhead has a problem
Re-insert the print cartridges. It is also possible that the heads are burnt. Get a new set of print heads (black/yellow) and install to the printer. If problem persists, clean the contacts on the printers. Use acetone + cotton swabs.
Mar 16, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
The following printhead(s) has a problem Black/Yellow[K/Y].
Simple solution is:
Replace the Black and Yellow Print Catridges. The print heads are mounted to the bottom of the catridges and these, depending on whther they're from HP or not. can have a hard time conducting electricity properly, and in turn.. spitting ink out properly.
Also happens often with aftermarket Catridges because HP puts chips on the catridge. be sure to put an HP catridge. Sometimes you get what you pay for :)
Oct 31, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
153 people viewed this question
Seeker5211
Seeker5211
