Question about Nikon Coolpix 5700 Digital Camera
Flash pops up, but flash closed warning stays
In low light conditions the flash pops up correctly, but the warning message that the flash is in closed position stays on.
When taking the picture anyway the flash does not fire and the resulting photo is to dark.
    Novelist:
  • 100 Answers
My E5700 did this a couple of times. The fix for my flash was that the unit wasn't actually popping all the way open. I closed it, then manually poppped open the flash and gave it a gentle upward tug. The flash seemed to lock into position -- and has worked fine since. I hope your fix is as simple as with my E5700.
I hope this helps!
Regards,
CharlieJ
[Please rate this solution, if it helps you.]
Posted on Nov 17, 2008
Why does " service brake booster" light always on??
SERVICE BRAKE BOOSTER
Refer to Brake Warning System Description and Operation in Hydraulic Brakes
The SERVICE BRAKE BOOSTER message will be displayed when the supplemental brake assist signal circuit is toggled at 1.0 Hz with a 50 percent duty cycle. This message is also displayed if the instrument panel cluster (IPC) does not see an alive and well signal at key on. When this message is displayed it indicates a problem with the SBA and should be serviced or replaced.
How do the power brakes work ? Good .?
Service Brake Booster Message Displayed
Step
Action
Yes
No
Schematic Reference: Brake Warning System Schematics
Did you review the Brake Warning System Description and Operation and the Brake Assist System Description and Operation and perform the necessary inspections?
YES - Go to Step 2
NO - Go to Symptoms - Hydraulic Brakes
Start the vehicle.
Is the REDUCED BRAKE POWER message displayed for 1 minute before the SERVICE BRAKE BOOSTER message is displayed?
YES - Go to Step 3
NO - Go to Step 4
Perform the Brake Assist System Diagnosis
Did you find and correct the condition?
YES - Go to Step 12
NO - Go to Step 11
Disconnect the Supplemental Brake Assist connector.
Test the ignition 1 circuit for an open or a short to ground.
Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES - Go to Step 12
NO - Go to Step 5
5
Test both ground circuits for opens.
YES - Go to Step 12
NO - Go to Step 6
6
Test the engine on signal circuit for an open or a short to ground.
YES - Go to Step 12
NO - Go to Step 7
7
Test the vehicle speed signal circuit for an open.
Did you find and correct the condittion?
YES - Go to Step 12
NO - Go to Step 8
8
Test the supplemental brake assist signal circuit for an open or a short to voltage.
YES - Go to Step 12
NO - Go to Step 9
9
Connect the supplement brake assist connector.
Disconnect the instrument panel cluster connector.
Connect a DMM from battery positive voltage to the supplemental brake assist signal circuit.
Turn the ignition to the RUN position while observing the DMM.
Did the DMM flash battery voltage?
YES - Go to Step 11
NO - Go to Step 10
10
Replace the Supplemental Brake Assist pump motor assembly Refer to Power Brake Booster Auxiliary Pump Replacement .
Did you complete the replacement?
YES - Go to Step 12
11
Replace the instrument panel cluster. Refer to Instrument Cluster Replacement in Instrument Panel, Gages and Console.
YES - Go to Step 12
12
Start the engine.
Does the Service Brake Booster message stay on?
Go to Step 2
System OK
Dec 25, 2016 | Cars & Trucks
Yellow triangle with exclamation mark permanently showing
This is the master warning light. It is a warning that another light is lit or a condition has occurred that requires review by the driver. If there is a driver information window a message may be displayed.
Example of other conditions depending on the car is:
  • Low tire pressure
  • low window wash
  • Low fuel warning
26143099-cuwo5vs5donv5atj0gwaggyx-3-0.jpg Hope this helps?
Mar 27, 2016 | Cars & Trucks
96ChryslerCirrus: 'door' warning vs odometer miles, Dome light stays on.
In the Ford Ranger, the light switch can be found in the door, right by the latch. You may need to use some WD-40 to get to work properly. -------------------------------------------------------------------------------------
zed bull
Nov 28, 2012 | 1996 Chrysler Cirrus
Service tire monitor on what is the problem? how do you reset the system?
TIRE PRESSURE MONITOR SYSTEM
The Tire Pressure Monitor System (TPMS) uses radio and sensor technology to check tire pressure levels. If your vehicle has this feature, sensors are mounted on each tire and wheel assembly, except the spare tire. The TPMS sensors monitor the air pressure in your vehicle's tires and transmit tire pressure readings to a receiver located in the vehicle.
The TPMS is designed to alert the driver, if a low tire pressure condition exists. This system also allows the driver to check tire pressure levels using the Driver Information Center (DIC).
When a low tire pressure condition is detected, the TPMS displays the "CHECK TIRE PRESSURE" warning message on the DIC, and at the same time illuminates the low tire pressure warning symbol.
You may notice, during cooler weather conditions, that the tire pressure monitor light, located on the instrument panel cluster, and the "CHECK TIRE PRESSURE" message will appear when the vehicle is first started and then turn off as you start to drive the vehicle. This could be an early indicator that the tire pressures are getting low and need to be inflated to the proper pressure.
Each tire, including the spare (if provided), should be checked monthly when cold and inflated to the inflation pressure recommended by the vehicle manufacturer on the vehicle placard or tire inflation pressure label. (If your vehicle has tires of a different size than the size indicated on the vehicle placard or tire inflation pressure label, you should determine the proper inflation pressure for those tires.)
As an added safety feature, your vehicle has been equipped with a tire pressure monitoring system (TPMS) that illuminates a low tire pressure telltale when one or more of your tires is significantly under-inflated.
Accordingly, when the low tire pressure telltale illuminates, you should stop and check your tires as soon as possible, and inflate them to the proper pressure. Driving on a significantly under-inflated tire causes the tire to overheat and can lead to tire failure. Under-inflation also reduces fuel efficiency and tire tread life, and may affect the vehicle's handling and stopping ability.
Please note that the TPMS is not a substitute for proper tire maintenance, and it is the driver's responsibility to maintain correct tire pressure, even if under-inflation has not reached the level to trigger illumination of the TPMS low tire pressure telltale.
The "CHECK TIRE PRESSURE" warning message and low tire pressure light (telltale) will appear at each ignition cycle until the tires are inflated to the correct inflation pressure.
The Tire and Loading Information label (tire information placard) shows the size of your vehicle's original tires and the correct inflation pressure for your vehicle's tires when they are cold.
Your vehicle's TPMS can alert you about a low tire pressure condition but it does not replace normal tire maintenance.
NOTICE: Do not use a tire sealant if your vehicle has Tire Pressure Monitors. The liquid sealant can damage the tire pressure monitor sensors.
RESETTING THE TPMS IDENTIFICATION CODES
Each TPMS sensor has a unique identification code. Any time you rotate your vehicle's tires or replace one or more of the TPMS sensors, the identification codes will need to be matched to the new tire/wheel position. Each tire/wheel position is matched to a sensor, by increasing or decreasing the tire's air pressure. The sensors are matched to the tire/wheel positions in the following order: LF TIRE (left front tire on the driver's side of the vehicle), RF TIRE (right front tire on the passengers side of the vehicle), RR TIRE (right rear tire on the passengers side of the vehicle), and LR TIRE (left rear tire on the driver's side of the vehicle).
You will have one minute to match the first tire/wheel position, and five minutes overall to match all four tire/wheel positions. If it takes longer than one minute, to match the first tire and wheel, or more than five minutes to match all four tire and wheel positions the matching process stops and you will need to start over.
The TPMS sensor matching process is outlined below:
  1. Set the parking brake.
  2. Turn the ignition switch to "RUN" with the engine off.
  3. Turn the headlamp switch from "OFF" to the parking lamps setting four times within three seconds. A double horn chirp will sound and the TPMS low tire warning light will begin to flash. The double horn chirp and flashing TPMS warning light indicate that the TPMS matching process has started. The TPMS warning light should continue flashing throughout the matching procedure. The "SERVICE TIRE MONITOR" message will be displayed on the Driver Information Center (DIC).
  4. Start with the driver's side front tire.
  5. Remove the valve cap from the valve cap stem. Activate the TPMS sensor by increasing or decreasing the tire's air pressure for 10 seconds, then stop and listen for a single horn chirp. The single horn chirp should sound within 15 seconds, confirming that the sensor identification code has been matched to this tire and wheel position. If you do not hear the confirming single horn chirp, you will need to start over with Step 1. To let air-pressure out of a tire you can use the pointed end of the valve cap, a pencil-style air pressure gage or a key.
  6. Proceed to the passenger's side front tire, and repeat the procedure in Step 5.
  7. Proceed to the passenger's side rear tire, and repeat the procedure in Step 5.
  8. Proceed to the driver's side rear tire, and repeat the procedure in Step 5.
  9. After hearing the confirming horn chirp for the left rear tire, check to see if the TPMS warning light is still flashing. If it is, turn the ignition switch to LOCK to exit the sensor matching process. If the TPMS warning light is not flashing, the five minute time limit has passed and you will need to start the process over beginning with Step 1.
  10. Set all four tires to the recommended air pressure level as indicated on the Tire and Loading Information label.
  11. Put the valve caps back on the valve stems. The spare tire does not have a TPMS sensor. If you replace one of the road tires with the spare, the "CHECK TIRE PRESSURE" message will be displayed on the DIC screen. This message should go off once you re-install the road tire containing the TPMS sensor. The "SERVICE TIRE MONITOR" message is displayed when the TPMS is malfunctioning. One or more missing or inoperable TPMS sensors will cause the service tire monitor message to be displayed.
Nov 23, 2010 | 2006 GMC Yukon
LIGHT WARNINS ON DASH
this is the low tire pressure warning
Mar 12, 2010 | 1995 Mitsubishi Diamante
Pop up flash Pops up but does not flash
Sounds like the internal flash is broken. I have seen used cameras advertised with this condition so it is not uncommon.
Aug 23, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Why won't the flash on my e500 pop up when the correct button is pressed or when I try to take a picture that requires a flash?
When you take pictures in AUTO, Portrait, Macro or Night scene mode, the built-in flash will automatically pop up in low-light or backlit conditions. If you want to control the flash pop-up, set this function to OFF.
1 Menu [AUTO POP UP]
2 Use control dial to select [ON] or [OFF].
3 Press the Ok
button.
If you are in any other mode the flash will not auto pop up.
Apr 16, 2009 | Olympus EVOLT E-500 Digital Camera
2005 ford freestar reset light on
Vehicles Without Message Center To reset the system, press and hold the odometer reset button and wait for the "TIRE PRESSURE SET" light to illuminate. Continue to press the button for 3 seconds, then release. After 3 seconds, the low tire pressure warning lamp will flash 3 times, indicating that the low tire warning system reset procedure is complete.
Vehicles With Message Center To reset the system, press and hold the SETUP button and wait for the message center to display "REST FOR SYSTEM CHECK". Then press the RESET button and wait for the message center to display "HOLD RESET TO RELEARN". Press and hold the RESET button for 3 seconds. The message "HOLD RESET TO RELEARN" and the low tire warning lamp will flash 3 times, indicating the reset procedure is complete.
Mar 12, 2009 | 2005 Ford Freestar
I have a 2003 GMC Savana Van. The brake light came on and the brake alarm rings continously but will stop if I hit a bump (and then start again if I hit another one). I'm thinking a loose wire but several...
If someone took the time to look at the electrical schematic you will see several grounds in the circuit My first place I would go would be to check all the Grounds and Connections for the Brake Fluid level control, Brake Warning Indicator
The Instrument Panel Cluster (IPC) illuminates the brake warning indicator when one or more of the following occurs:
  • The body control module (BCM) detects that the park brake is engaged. The IPC receives a class 2 message from the BCM requesting illumination.
  • The electronic brake control module (EBCM) detects a low brake fluid condition. The IPC receives a class 2 message from the EBCM requesting illumination.
  • The electronic brake control module (EBCM) detects a closed brake pressure differential switch. The IPC receives a class 2 message from the EBCM requesting illumination.
  • The EBCM detects an ABS malfunction which disables dynamic rear proportioning (DRP) . The IPC receives a class 2 message from the EBCM requesting illumination.
  • The IPC detects a closed power brake booster alarm switch and closed power brake booster fluid flow alarm switch. The IPC illuminates the brake warning indicator and sends a class 2 message to the radio requesting the brake warning alarm.
  • The IPC performs the bulb check at the start of each ignition cycle. The brake warning indicator illuminates for approximately 3 seconds before turning OFF.
  • The IPC detects a loss of class 2 communications with the BCM or with the EBCM.
Driver Information Indicators and Messages
The following indicators are used to inform the driver of several different factors.
The Instrument Panel Cluster (IPC) illuminates the brake warning indicator when the following occurs.
  • The Body Control Module (BCM) detects that the park brake is engaged. The IPC receives a serial data message from the BCM requesting illumination. The brake warning indicator flashes at a rate of approximately twice per second when the park brake is engaged.
  • The EBCM detects a low brake fluid condition or base brake pressure differential and sends a serial data message to the IPC requesting illumination.
  • The IPC performs the bulb check.
  • The EBCM detects an ABS-disabling malfunction which also disables Dynamic Rear Proportioning (DRP) and sends a serial data message to the IPC requesting illumination.
Here is a description of how the system works But i would check my Grounds and connections
www.aceautomotive1.com
Contact me if you need any more information Ill be glad to help
Aug 01, 2008 | GMC Savana Cars & Trucks
Nikon Coolpix 5700 Digital Camera Logo
145 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
