If you want to insert your sim card into your mobile, open the back cover, remover the battery and insert the sim into the slot provided. Put back the battery, close the back cover and then use the mobile.
1. Power down the Nokia cell phone before inserting the SIM card. If the phone is on when you insert the SIM card, it may not detect the newly placed device. 2. Insert a SIM card from your specific wireless provider. If you are attempting to insert the SIM card of a different company, your Nokia phone may not properly detect or use the equipment. 3. Slide the SIM card completely into the SIM card port on your Nokia cell phone. If the card is not pushed in all the way, your phone will not detect the information.
Insert sim error happen if the phone is not acknowledging the existence of sim card inserted in the phone.
1. Check if the sim is properly inserted. 2. Turn off mobile phone 3. Remove battery 4. Remove memory card 5. Remove sim card 6. Check the copper pins of the sim if there are dirts stucked on it 7. Ure clean cloth to wipe sim gently 8. Wait for at least two minutes 9. Gently and properly insert the memory and sim card 10. Insert the battery 11. Turn on mobile phone 13. Check if you will still recieve insert sim error 14. If you still recieved the same error you need to call your service provider and check the status and availability of your sim card.
Maybe your sim card is not well fitted on your sim card port. If you thinks it is well firtted, based from my experience, just insert your sim card as usual to the sim card port and then do that 5 times. (rubbing slowly). and then try to power it on. Just try it. Hope it will work for you..
Hi, when a phone displays an insert sim message, it means that either the Sim card or the Sim tray where the sim card is inserted in the phone.
First, You can use the sim card on another phone to be sure that the sim card is still working properly. If the sim works with another phone, that means the sim tray where the sim card is being insert into the phone is bad and will need to be replaced.
This problem arises sometimes because the mobile is unable to read the SIM. May be you should fold a small piece of paper in the same size of the SIM and keep it on top of the SIM and then insert the Battery. I think this will solve your problem.
Hi,when a phone displays insert Sim, it means that the phone's Sim tray where Sim card are inserted in bad and can't make the Sim card display again .You'll need to replace Sim tray.
Obviously your sim card reader is bad or the metal clasp that holds your sim card firmly against the reader is warped. This would prevent the phone from reading your sim
ok you a good..
