Question about Minolta Office Equipment & Supplies
Konica Minolta Bizhub c-353 has an error code c-1183 which will not clear for me It's Saturday and I have a HUGE project with lots of people coming to help.
  • Minolta Master
  • 6,359 Answers
The finisher output trays hit something like a trash can or boxes stored under the trays. to fix must remove the rear of the finisher reset the elevation drive assy. Be careful don't let the trays fall down tech would be good on this project
Posted on Dec 28, 2014
5 Suggested Answers
micromatikal
  • 2777 Answers
SOURCE: Konica Minolta Bizhub 250 copier/printer
When it loads through the ADF there are little springs that are supposed to press the document down onto the platen glass... It sounds like those springs have worn out and just aren't pressing it down far enough. This is extremely difficult to repair, pretty much impossible to do on your own. However it is not all that uncommon, and is fixable. But you will want someone that is authorized to work on the machine to come out and replace those springs. That will definitely get it to scan / copy just like it was on the glass itself...
That can really be all that would cause this, otherwise it is identical to an on the glass copy.
Thanks,
Tim
Posted on Oct 27, 2010
  • 7 Answers
SOURCE: need written instructions on how to reset Ip code Konica bizhub C451
there are two ways you can rea\set the ip address you can press utility counter administrator password is 12345678 the go to network ip address and you can chane it there if you know the ip address you can browse to the machine and log in as administrator and go to network and reset there
Posted on Aug 22, 2009
  • 24 Answers
SOURCE: I am using a konica
Press this button in same order and sequence UTILITY-STOP-0-0-STOP-0-1
Where 0 mean zero of keypad then you see the msg "service mode" press down key and go to ADJUST and press OK press down key and go to ATDC and press OK check the value and increase some higher point again press OK press reset switch off and after some seconds switch on perform above actions until you get machine in ok condition or other otherwise you must be change the developer powder. but be sure to run atdc auto adjustment which is in SERVICE MODE-FUNCTION-ATDC AUTO ADJUST then press ok and leave the machine for complication his process,
Posted on Jan 27, 2011
SOURCE: I cannot tell what steps
The machine will scan to SMB as standard, scan to email would require the optional IP424 controller. Your service company should be able to set this up.
Posted on May 11, 2011
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
I have documents hung in que that has machine not printing
need details - what OS, is it hardwired via USB or connecting via network or wifi - could be port is blocked in your router's firewall, could be port is blocked in the PCs firewall, could be lots of things. Not sure what you mean by going online to clear documents - online where? is this a "cloud" printer? try shutting off printer for 20-30 sec then restart it - that may clear docs stuck in it's internal memory. going to need more details if you expect anyone to offer more detailed troubleshooting.
Dec 10, 2014 | Konica Minolta Bizhub C 353, Bizhub...
Konica minolta bizup c550 printing black copy what will i do?
The corona housing for the back drum need to be replaced. Get a new black image unit drum and developer units
Aug 15, 2014 | Konica Minolta Bizhub C 353, Bizhub...
Errore Trouble code C-C172
Refer to Konica Minolta Bizhub C451 Printer/Scanner/Finisher's User Manual or Call Service Center.
May 01, 2014 | Konica Minolta Bizhub C451...
Where do I find the motor connector in the bizhub c-353
for which motor and which connector there are about eight motors and about 70 conectors
Mar 24, 2014 | Konica Minolta Minolta Bizhub C353 Copier
C 172 on minolta 353
is that a c353 or a bizhub 353, code normally have four C-XXXX
Jan 30, 2014 | Konica Minolta bizhub C450P Laser Printer
Konica minolta bizhub c450 error code c- d370
I have minolta c450 show error c d370... how can I solve this problem... plz reply me with solution.
May 14, 2013 | Konica Minolta Bizhub C 353, Bizhub...
Machine showing error D370
when machine waqs working atonce power failure occurred and after that it showed error D370
Oct 26, 2012 | Konica Minolta Bizhub C 353, Bizhub...
Error code c2152
good to
Imax Konica Minolta C451 Bizhub
I have a problem is the cod C2151 what to do Thanks
Sep 24, 2009 | Konica Minolta bizhub C450P Laser Printer
209 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
