Question about Nuova Simonelli Oscar Coffee Maker, Espresso Machine
Steam leaking from near temperature control sensor
There is a steam leak from the value or from the value fitting extruding from the steam (or water) heat sensor. This is the place where the temperature sensor can be adjusted using a screwdriver. I cannot tell if this is normal steam release that can be remedied by lowering the temperature setting, or if it is an actual leak. Also, there have been instances where the water being fed into the grouper contains a sufficient amount of steam to force the water out of the grouper sideways. I feel like this could be a symptom of too hot a temperature, but it also might be an issue with a shortage of water resulting from the "steam leak. " Also worth note: There have been some issues with the electricity in the building where the machine is operating that also seem to cause some problems with the water pressure. (The power seems to brown out to about 200V)
    New Friend:
  • 82 Answers
Your machine is over temperature. check your gauge pressure must be 1.2 bar only and you need to check if pressostat is cutting out and tighten the leaking fittings.
Posted on Feb 05, 2018
3 Suggested Answers
  • 3 Answers
SOURCE: espresso machine loses steam than recovers in minutes
It sounds like a heating element issue. Those elements look like a single unit but are actually made up of 2 or 3 independent heating coils - one may not be working. So, you're only getting 1/2 to 2/3 heating capacity, which isn't noticeable until the machine is under heavy steam load.
Posted on Feb 20, 2010
  • 713 Answers
SOURCE: after steaming milk has a metallic taste also
run some vinger and water through it a few times then try it out again.
Posted on Feb 22, 2011
When I turn on the steamer water leaks from somewhere inside the unit. cva 615
The most likely cause is a cracked steam heater - if it only leaks when using the steam function - the 615 has one pump - for coffee, Hot water and steam - so that is all good, but has two heaters - one for coffee and hot water - the other for steam. It could be a faulty valve or fitting but in my experience the heater is the first to go
Jan 02, 2018 | Coffee Makers & Espresso Machines
Rowenta superpress DG 050 leaks water while steaming all over garment. Do I need to Descale the unit?
I've had the same problem with two Rowenta irons. When set to a lower temperature, the iron has a bad habit of leaking water when the steam option is on. I have to either turn up the temperature setting or shut off the steam option.
Feb 28, 2015 | Rowenta Irons
Steam rises from the radiator after car idles for 10 minutes. Replaced thermostat. No improvement. Could this be one of the radiator fans as I noted it does not turn on. The water guage remains wh
If the steam is rising from the radiator and not from the overflow tank or hose then you do have a leak.. in the radiator. check for a cracked tank or fitting where the hoses connect. If it is making steam the guage is probably defective. Find out where that steam is coming from ! If the car is making steam the rad fan should probably be running.. I do not know about your particular car but some times the secon fan only comes on with A/C use or extream heat.
May 10, 2014 | 1999 Mercury Sable
TR 019 STEAM SHOWER leaking water from every jet, body jet , foot massage, shower head, top shower head when in off position
Tr019 is a type of control panel that operates the electrical features in a steam shower cabin, usually found in Chinese products. The issue you have is with the valve, in particular the on/off valve. These can be replaced individually or as a complete new valve . This company in uk sell them http://
Aug 12, 2012 | Home
Mr.Steamer Commercial Steambath CU750A temp is to high it is out of control
There are only 3 likely causes. The first and most likely is the room sensor inside the shower. This is a resistive type sensor that communicates the temperature in the room to the controller via ohm ratings. There is an equivalent ohm rating for every degree of temperature it correlates to and that is how the temperature controller knows what temp it is in the room. Often in commercial steam rooms clients tend to spray cold water on the sensor which causes damage and alters the ohm rating to the point where the sensor is relaying incorrect room temps to the controller, causing high or low temperatures. Normally when the room is hot, it causes the alloy metal of the sensor to be hot. When cold water is sprayed on it, it immediately bring down the temp of the alloy and the thermal shock warps the metal causing the resistance values to change. Set your multi-meter to ohms and remove the sensor wires from the back of the controller. You will do your ohm reading on the sensor wires. Check the actual room temperature with a thermometer. At room temp 77 degrees you should be getting 10,000 ohms, at 100 degrees you should get 5827 ohms, and at 120 degrees you should get 3759 ohms. Note as the temp goes up the ohms go down, this should help you determine if your sensor is good. The other possibility is your steam solenoid valve is stuck in the open position. Simply check if there is voltage running to the solenoid. If there is no voltage but the room is filling with steam your solenoid is stuck open and needs to be replaced. The last is the controller, and by process of elimination if the sensor and steam solenoid are good then the controller may be the issue.
Feb 02, 2012 | Mr Steam Mr. Steam Commercial Steambath...
Water leaking out of iron no steam I have a Hamilton Beach Steam Storm Model 14560 Lost manuel
The Use and Care Guide for the Hamilton Beach Iron can be downloaded here:
If water is leaking out of the iron:
• Do not overfill the water tank.
• If steam ironing, is Adjustable Steam Knob in a steam position that matches Temperature Control Dial steam range? Did the iron have enough time to preheat?
• If dry ironing, make sure the Adjustable Steam Knob is in the DRY IRON position.
Jun 20, 2011 | Hamilton Beach Steam Storm 14560 Iron
Need to know what a E4 reading on the runyes autoclave means
E4 error is a pressure and temperature differential. Check the steam generator solenoid,steam generator water pump and water sensor in clean water reservoir. If any of these components are faulty then replace. If all ok refer to E2 error and check inner temperature sensor or check for steam leaks
Sep 13, 2010 | Health & Beauty
Iron producing lots of water
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
May 18, 2010 | Philips GC 8220 Iron
It leaks water when I iron sometimes staining my clothes with black streaks or water stains.
Hello :
1:Clean your steam iron according to the manufacturer's instructions. Your iron is more likely to leak when it has not been cleaned properly. Plus, the water that leaks from a steam iron that hasn't been cleaned will likely be dirty and stain your fabric. Every steam iron brand is different, so be sure to check the manual that came with your iron or browse the manufacturer's website for instructions on keeping your steam iron in good working order.
2:Use your steam iron on a rigid surface like an ironing board. In a rush, you might be tempted to quickly iron a blouse or pants on the nearest available surface like a bed, carpet or even on a table with a towel draped over it. However, these surfaces may not provide the proper amount of level padding for successful steam ironing, and leaks are more likely to occur. Take the time to set up your ironing board for smooth steam ironing to reduce water leaks on a bumpy surface.
3:Allow your steam iron to heat fully in the upright position before ironing. Because your steam iron is designed to convert water into steam that will easily smooth out wrinkles on bulky fabrics, you can avoid leaks by ensuring your iron has time to get the water to the correct temperature. If you lay your steam iron in the horizontal position too quickly, water that is not hot enough to convert to steam will leak. Give the iron a chance to heat up, and then test your steam function on your ironing board cover or spare fabric swatch before tacking your favorite blouse.
4:Turn off the steam function on your iron when ironing at lower temperatures. Since your iron's steam function is designed to convert the water in your iron to steam at the right temperature, lower iron temperatures can cause water to leak if your steam setting is still activated. For ironing more delicate fabrics, turn off the steam to avoid water leaks.
Apr 18, 2010 | Euro-Pro Shark GI490 Iron
Swan steam iron steam coming out of front and leaking water
the temperature is not set correctly for the fabric.
Sep 17, 2009 | Irons
Open Questions:
Nuova Simonelli Oscar Coffee Maker, Espresso Machine Logo
77 people viewed this question
Top Nuova Simonelli Coffee Makers & Espresso Machines Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Nuova Simonelli Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
