Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
We have a electronic garage door. Yesterday- when I pressed the button in the garage to close the door, it would lower but then go back up. I played with it about 15 minutes, trying to get the garage door to close. Do you think the sensor needs to be cleaned....why would it do that....
  • ktm_1 Nov 06, 2008
    It happens to me when the weather turns cold, I think the metal is condensing. I don't know how to fix this problem.
  • 30 Answers
Well you little tips to tell if it is your sensor if your opener is a liftmaster/sears/chamberlain then you will hear clicking about 5 times or so coming from your opener also your lights on the opener will flash. If it is doing that then it is with out a doubt you sensors clean them make sure there both looking at each other. both lights should be solid not flashing or off. you might have to move them a bit to get them aligned. If thats not your problem and you door works well by hand you need to up the force on the way down for genie you need to take off the light cover and turn the nob toward the bigger number clockwise just a little. For lchamberlain products the force till be in the back you will need a small flat head screw driver to turn the screws. They are blue dont not turn any other ones. if you have to turn the pressure all the way up to make it work you should have your local garage door guy take a look at it.
Posted on Feb 10, 2009
  • Doorguy27
    Doorguy27 Feb 10, 2009
    Also for ktm_1 it just the force chamberlain products tend to do that in the cold. just turn your force up a hair as well.
Garage door will not close when using the remote or garage door button. it will open, however. it can be forced closed by holding the garage door down. i have had this problem before . i have...
Check to see if your child/animal security beam is working correctly. It is an "Electric Eye" mounted about 12 in off of the floor on two mounting points and one side shoots an infra red beam across to a receiver. These points must be reasonably aligned to flash a beam (cannot see) from one point to another. This beam keeps the door open if it is interrupted . If it is not aligned, then the door opener sees a problem and will not close the door electrically. You must aligned the beam by bending the transmitter or receiver untill you can close the door by the remote. Also check to see if something placed in the garage is not blocking the beam first.
Jan 06, 2011 | liftmaster Garage Door 1/2 Hp
My mom has a 1/2 hp chain opener that was installed in 2000 or so. It had recently begun overdriving both closing and opening (so button had to be pressed once to stop it). I tried adjusting the raise...
Remove the cover from the motor unit and you will see the limit switch assembly. If you watch the operation I think you will understand it and be able to adjust it properly.
Nov 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remote and my keypad remote both stopped working as of today
CHECK TO SEE IF THE LED ON THE WALL BUTTON IS BLINKING - IF IT IS SOMEONE HAS PUSHED THE VACATION LOCK BUTTON.
PRESS THE LOCK BUTTON TO MAKE THE LED STAY CONSTANT AND IT IS FIXED.
HOPE THIS HELPS
Nov 17, 2009 | liftmaster Chamberlain Garage Door Opener...
Door will move maybe a foot or so but goes back to original spot
You may have a fairly cheap problem that can be found by nearly any electronic tech in possession of a couple of instruments; specifically a decent multimeter and maybe a capacitance meter.
It is apparent that either some passive component or low-level transistor in the timing/sensing circuit has bit the dust.
Jul 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster pro 1/2 hp wont shut in one button press
You have a door sensor problem. Either your main light bulb is burned out or you don't have one in your opener. The clicking sound you hear is the relay for the light. Both of the door sensors should have a small light that is lit. Tweak them until they are.
Jun 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Pressing remotes the door won't go u[
It sounds like you have the lock enguaged. When it is flashing it locks out all remote access. Hold the lock button for 3 seconds. The green light should go solid. On the issue of closing, it is most likely a safety eye issue. Hold down the wall button. If it closes it is the safety eyes. Holding the button overrides the safety eyes. Make sure that thelight on both eyes are both lit.
Jan 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
LiftMaster 1/3 HP- Garage Door Opens but will not close
I have had a similar problem related to my doors when they get cold-soaked. The tracks actually warp a little throwing the sensors off and causing the door to bind. The door will go down a bit then come back up. I overcame this be resetting the force that the motor puts out to lower the door and it works fine now. If you can wait for things to warm up, use the manual release lever and lower the door by hand and then reset the lever so the door can't be opened manually.
Jan 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opened, won't close
If you can press and hold the wall button and the door will go down, you have a photo eye issue. Check the photo eyes at the bottom of the door.
Jan 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
100 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
