My computer does not show my D:/drive, so it does not work
  • erwinroyo
    erwinroyo May 11, 2010
    Is your drive C was partationed? Or drive D is a separate hardisk?
    So that we can figure out the cause of the problem.
    Thanks
    Scholar:
  • 32 Answers
I would assume that your D drive is your CD Rom Drive. If you go into My Computer and the drive isn't there, Lets assume first that there is a problem with the Drive. If you have power to it and the drive does open to let you insert a disk, then our next step is to see if your data cable running to the drive is connected. Make sure that all power cables are unplugged before you open up the computer. Once opened look at the back of the CD Rom drive to check that the power plug is connected. Its the first set of 4 wires closest to you. The next cable next to that is the CD Rom Data IDE Cable. This cable must be plugged in all the way. Most of the IDE Cables will have a red stripe on one side. Make sure this red stripe is closest to the power cable for the drive. This will insure that you have this plugged in correctly. If you follow the IDE cable from the CD Rom to the mainboard (Motherboard) , you can make sure that this end is also seated firmly to the board. If all this is as it should be, go ahead and plug all your cables back in and restart your computer.
If this still doesnt solve your problem you might want to check your bios and insure that the CD Rom is recognized. It will show up in there if it sees it. If any of these solutions dont solve your problem, I would be leaning toward a bad CD Rom Drive.
Joe < Data Miner >
Posted on Nov 01, 2008
I have a verbatim external hard drive, model usb500 and my computer does not recognize it. I have it plugged into a working usb port and the blue light on the drive is on, but my computer isn't...
You need to assign a drive letter for it to show up in Windows.
Right click on My Computer, click Properties. Then go to disc management, and right click on your external hard drive, and click Assign Drive Letter, and choose a letter and it will show up in My Computer.
May 08, 2011 | Computers & Internet
I put the flashdrive into the port but I do not understand how to get the work onto the drive? It said that I connected it right but it did not show me how to copy or download work onto the flashdrive.
A flashdrive shows up in Windows as a new drive letter un Windows Explorer.
If you right click on My Computer (XP), Computer (Windows 7) you can select explore or open.
The dialog box that opens is split in half. the left side shows the "drives" and corresponding letters. Typically, you will have a Local C:\ for your Primary hard drive, CD Drive D:\ for a CD/DVD and the flash drive will show as Removable Drive E:.
To copy work to the new flash drive, you can select save as from your program and select the drive letter that you saw the removable drive named in Windows explorer.
You can also, from the folder named My Documents, copy the file by right clicking on it, then selecting the flash drive letter and pasting into the empty window associated with it on the right side of the divided Windows Explorer screen.
Apr 16, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
My san disk 2gb pen is canot open but light is blinking &showing remuvabal disk on my computer
USB Pen or stick drives usually use the letters "F" or "G" drives on your computer. If these drive letters are being used, the USB drive will not be available. Also, if this is the first time you are using the USB drive, it is possible the drive is not formatted. Although this is unlikely.
I will outline instructions below to use the Disk Management tool in windows to see if the drive shows all the drives connected to your computer. If your computer is recognizing the drive as you describe. I am confident USB Pen drive will show up in disk management. You may be able to assign a drive letter and make the drive visible in you my computer window.
The directions for using disk management are listed below. A note of caution, do not make any changes on you Disk 0. or "C" drive, as this is you main hard drive that starts your computer.
Right click on you “My Computer” Icon
A menu will open
Chose “Manage”
The Computer Management window will open
The Computer Management window is broken down into 3 sections. The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu. The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have no disk will not show as active drives on the top section, but can be seen in the lower section.
The lower shows each drive, their drive letter and status. The left section will have small boxes showing drive numbers. Drive 0 is usually your main hard drive. To the right of the smaller section is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show “healthy”) This is the area you can right click and get a menu that will allow you to: open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition.
In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows. A drive this is having a problem may show that it needs to be formatted. This can be done from this window as described above.
Please follow these directions and see if you can make your drive visible. If you have any questions about the instructions or need further assistance, feel free to reply to this message and I will assist you further.
Brian
Jan 29, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My problem is with the HP Personal Media Drive
> When I unplug the media guide, then it doesn't show up on my computer.
That makes sense -- when _not_ physically connected, then it will not show up within "My Computer".
Try a different USB-port on your computer.
Or, connect it to another computer, to see if Windows will detect it, and will assign a drive-letter. If not, then try a third computer -- it could be "dead", if 3 computers cannot detect it.
Dec 14, 2009 | HP Computers & Internet
USB HDD not showing in My Computer
It could be that the USB port on that computer is not delivering enough power.  Will your Drive accept external power?
May 12, 2009 | Computers & Internet
Disk management does not see working hard drive
Are the Hard drives setup as master & slave ? (plastic jumper on Hard drive at cable)..... is the Hard drives connected on separate ide cables... if they are ide drives ?
Mar 30, 2009 | Seagate Barracuda 7200.7 160 GB Hard Drive
No drive letter
When remove the drive do this steps properly first when you want remove the drive remove safley than remive it
Jul 13, 2008 | Western Digital My Book Essential Edition...
No Drive on Connection
Hi, When i connect my sansa e200 mp3 player with my computer..it showing CONNECTED on the mp3 player screen, but does not show any disk drive in my computer. No problem with computer, my pen drive is working fine with it. can someone help?
Dec 08, 2007 | SanDisk Sansa e200 MP3 Player
Computers & Internet Logo
David Payne
David Payne
