Hi, I have an Epson EMP 500, when i plug it in the orange power light comes on and is a steady light and a fan runs on the front, when i press the red on button the power light turns green and flashes on and off then stays a steady green and the projector starts working with a good picture. then after about 15 seconds the unit then shuts off instantly with no warning of lights flashing. I then have to unplug the power supply and wait about five minutes before i plug it back in for it to power up again and it then does the exact same thing. hope you can help.
Comments:
Nov 01, 2008
- The fan is running and it is at room temarature 17*C
Nov 01, 2008
- The light does not flash red, it is a steady orange, which according to the handbook is normal operation, it then flashes green which acording to the handbook is the projector warming up and then the steady green is normal operation in working order, and it does all that, but it just suddenly shuts off with no warning or flahing lights. it does it after approx 15 seconds.
Nov 01, 2008
- I have tried all of the above, no difference, i find it strage that it was working ok, about two months ago, now it is faulty and there are no warning lights to tell me what is going on.
Looks like the lamp is failing and you may have to have it replaced. The ON button green means that the system is functioning properly. Have you cleaned out the air filter on the underside of the projector? You can use a small computer vacuum cleaner to do this. It could also be indicative of a circuit failure. I recommend contacting Epson tech support before trying anything further. They can be reached here: http://www.epson.com/cgi-bin/Store/support/SupportContactsEmail.jsp?BV_UseBVCookie=yes
Most likely an hardware fault, see if the projector works fine with the cover opened, in this case is one of the fans that is not cooling enough because it is defective and runs too slow.
Do the following:
Unplug power cord.
Wait 5 minutes.
Plug cable back
If that does not work try holding the power button while you connect power cable back.
If still no luck, that means that the unit has an hardware fault, probably the main pcb, or a fan, otherwise it would not shut down.
Hardware problems that can cause shut down on a projector are:
Defective fan
Defective motherboard (heath sensor, CPU)
Defective lamp (uncommon)
in this case call the number listed on the printer owner manual to get it repaired.
The projector must be connected to a computer or a video source such as a video tape deck, camcorder, digital camera or laser disc player before it can project any images. You may also want to set up the projector for one or more of the following: • Connect the mouse cable to use the remote control as a wireless mouse. • Provide audio for one or both image sources. The audio source can be the computer, video source, or another device such as a stereo. • Connect to an external speaker or PA system to amplify the audio.
1. Place the projector on a sturdy, level surface within five feet of the computer or video source. 2. Place the projector at a correct distance from the screen. 3. Turn the projector so that the lens is at right angles to the screen. If the projector is not angled correctly, the screen image will be crooked. 4. Connect one end of the power cable to the projector’s power connector. Connect the other end to an earthed electrical socket. The projector should be in sleep mode, indicated by an orange power indicator.
Please follow the procedure and after that please inform if problem persists
Since your status light is Orange and red flashing. This means that the projection lamp needs replacing.
If its steady red then the projection lamp has burned out. Replace the lamp
There may also be a problem with the lamp power supply, lamp fuse or projector circuit.
You need the projector to get checked by some technican.
I bought the ELMO presenter ev308 from eBay. I hooked it up to my tv and my tv says ''no signal''. I...
(More)
I bought the ELMO presenter ev308 from eBay. I hooked it up to my tv and my tv says ''no signal''. I tried three different cords and three defferent tv's but still cannot get a signal. The hookup is pretty basic - signal ''out'' from presenter to ''Input'' on tv.
How do I get the green button on a xr-10x dlp projector to stop blinking and for the projector to...
(More)
How do I get the green button on a xr-10x dlp projector to stop blinking and for the projector to work
I have a Panasonic Projector but when I connect to power it show the red light on Switch on/off...
(More)
I have a Panasonic Projector but when I connect to power it show the red light on Switch on/off button and when I do switch on but never get start why? Solution please?
