There are a number of reasons that may cause the issue but generally two factors: outdated hardware or poor system maintenance. For hardware part: you can get more RAM, higher CPU etc. For system part: there might be a lot of junk files, caches, errors etc out there, about 80% slow HP issues are caused by this reason, in this case you can rely on http://www.speeduphp.com/ to free detect and fix related issues.
Disconnect the usb printer and than start the system
but this problem will come up again ... i will tell you what was happening
when u start the system, up it looks for boot devices and you system was trying to boot with the help of usb printer and by the time it comes to know that its booting from the wrong place it passes a lot of time and so u need to disable the usb emulation in the bios to correct this issue
The problem appears to have fixed itself! It could be that you were on to something as the PC would occasionally make a noise suggesting that a USB device had been plugged in/unplugged and then the printer would go through some kind of diagnostic routine even though it wasn't switched on. However, I used the printer and after that the PC has restarted/started up without a hitch so I was unable to test your fix. Thanks anyway and I will bear it in mind if the problem resurfaces.
MY HP boots up slow as all get out too.
Except mine takes about 7-8 min to actually get to the boot screen.
It does this even when no software is added or anything.
