Question about Broksonic SC20145 20 in. TV/VCR/DVD Combo
No screen, no power on light, but high frequency squeal
I have a Broksonic SC-20145 TV/DVD/VHS combo. when plug the power cable, there is no screen, no power light on, but a high frequency noise continuously. What's the problem? it's something wrong in power supply or other parts? Please email: zhaohanq@msu.edu Thanks
  • simajara Nov 01, 2007
    yo tengo un Broksonic SC20145 y emite un sonido constante el VCR y el DVD encienden pero la pantalla no, espero que algun amigo que sepa español este leyendo esto y me ayude, gracias
  • Anonymous Aug 30, 2008
    TV will not turn on by pressing power on button. Has power to receptical. I feel it is a low voltage board problem.
    Problem Solver:
  • 19 Answers
C1720 ,c1728, d1719 replace
Posted on Nov 16, 2007
    Sergeant:
  • 337 Answers
You have a very good idea of what is happening,the power supply is likely being pull down by a shorted component,it could be a regulator or the output transistor.The power supply provides about 5 or 6 different voltages to be use for the different circuits,I gave you two ideas but it could be any of them.Be safe and take it in for service.
Posted on Sep 19, 2006
I have a apex tv and a dvd/vhs recorder, with a cable from wall only, how do I install
If you wish to record (VHS) off cable :
First connect the co-ax cable from the wall to the input on the DVD/VHS , then connect a second from the output of the DVD/VHS to the input of the TV.
You will need to match the channel (3/4) output and input. There should be a switch on the back of the DVD/VHS.
Tune the TV to channel 3 or 4 to match, To watch DVD/VHS .
Channel selection will be with the DVD/VHS when it is powered on.
TV will tune to channel when the DVD/VHS is off.
Jul 06, 2012 | Televison & Video
I have a rf modulator i dont no where any thing goes i tryed i just dont understand it i just brought a dvd and vhs to gether
alot of DVD/VHS combos have a built in RF modulator. Look for a coax (screw threads) output on the unit and it should be labeld either DVD/VHS OUT or just VHS OUT. If it does not have a combo out then you will need to use the seperate RF modulator.
Your combo unit should have a set of yellow red and white jacks that are labeled DVD & VHS OUT. Connect these yellow red and white to the yellow red and white on your RF modulator, then connect the coax (screw threads) out on the RF modulator to the coax jack on the back of your TV. There is also typically a swich for channel 3 or 4 on the RF Modulator, make sure you TV is on which ever channel you have that switch set to. If your RF modulator has a power light on it, it will usually not come on until your DVD/VHS is sending a signal through it and it is connected properly.
If you have an antenna or cable box, your RF moudulator should have an Antenna or Cable input jack on it that you can use.
May 05, 2011 | Magnavox DV220MW9 DVD Player VCR
I can not seem to find out how to run my cable line through my DVD/VHS combo and into my TV. I have to use the DVD/VHS combo to run cable to my TV because the coax input on my TV broke off and I have to...
Dear hugoreyes456,
On the rear side of your DVP3345VB you should find a bunch of RCA connectors. There is a column on the right side with the title VCR - AUDIO IN - VIDEO IN.
May I ask you to try plug your cable box to this connectors and the DVP3345VB to your TV.
Before trying it, may I ask you to check that you get video directly from the DVP to your TV when playing a DVD or a VHS tape?
Regards,
Eddie Knight
Dec 28, 2010 | Philips DVP3345VB/F7 DVD Player/VCR
I have a broksonic sc-20145 and the dvd player drawer will not open/close. could it be a bad motor?
With your ear next to tv do you hear the sound of a motor trying to open the dvd door. If so probaly a plastic gear that has failed that opens the dvd door otherwise could be the motor. Just go buy a $30 dvd player and connect to the tv input. not worth repairing and stay away from tv/dvd combos in the future for this reason that your having to expierence now.
Aug 15, 2009 | Televison & Video
I have a HD TV with cable and a go video DVD/VHS player hooked up. I went to change the time and accidentally changed the setting on the DVD player from auto scan (I think) from off to on and now when I...
It sounds like you may have enabled the progressive scan output on your DVD-VHS combo. This is a correct setting if your TV support it. However most DVD players that support progressive scan will not support an interlaced signal and a progressive signal at the same time.
It would appear that you are using a composite type cable (3 RCA ends. 1 for video and 2 for audio) for this hook up. This means you have two choices.
#1 Look in the manual for the unit for the FACTORY Reset option. Its usually a combination of plugging the unit in while holding the power button or something similar to that. Without a model # I can't help any further with this option.
#2 Use a component video cable (3 RCA red/green/blue) to plug your DVD/VHS player into a compatible input on your HD TV. Your TV will pick up the progressive scan output from the unit and give you back your on screen display. At this point you can go back into the menu and disable progressive scan. And now just reverse the process to plug the DVD player back in using the composite cable.
It should be noted that if you have a progressive scan TV which HD TV's support you will get a better picture if you use the Component video cables instead of switching back to the composite cable. If you decide to use the component cables you will still need to run audio cables though.
Best of luck.
Trevor
Aug 11, 2009 | GoVideo Go Video DVD/VCR Combo
Sc20145 television broksonic television dvd vhs combo
Buy universal remote for $10-$20 at radioshack, mcm.com, box stores, etc. Check to make sure your model is listed and/or ask if its returnable if it doesn't work with our set.
Jun 26, 2009 | Broksonic SC20145 20 in. TV/VCR/DVD Combo
Broksonic dvd/vhs combo
how do u get the dvd part for a broksonic dvd/vhs combo i need to replace the dvd part it doesnt work and how much does it cost
Feb 15, 2008 | Broksonic DRVCR900 DVD Recorder/VCR
Broksonic SC20145 20 in. TV/VCR/DVD Combo Logo
117 people viewed this question
Top Broksonic Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
