Question about Lightning Audio LA1.150.2 Car Audio Amplifier
AMP not workin
Was Driving along and Turned my Fan on and then my Amp blew a Fuse When i replaced the fuse smoke started coming out near my power Terminals on the amp. Amp was running fairly warm. I was also having alternator probs at the time which cant of been helping. Now when i try running the amp it runs for about 2 seconds and then my bass stops Can You help
  • pnews Nov 04, 2007
    I have an Alpine CDE-9852 for my deck, a Solo Baric L512, and a crunch pzi 250.2 for my amp. I had it working fine for a couple months and it sounded wonderful. Then the lights started flickering when the bass hit. And after awhile the sub would just cut out once I turned my deck volume past 5 or so. I was persistant and tried making it stay on and it resulted in my amp smoking. I am still able to get the system to work, but my amp will always end up smoking after a few minutes. I have not the slightest clue what to do. Any advice?
  • _oro May 11, 2010
    Does anyone have a circuit diagram for the MTX 4001 Amp?
    My amp blows its fuses as soon as energized. I've checked the output transistors and they are all fine. There is no sign of burnt components or odour from the circuit board.
    I'd like to check out the power supply circuitry, but I need the diagram, or some expert suggestions.
    Thanks
    Scholar:
  • 98 Answers
Yes defrinately sounds like it needs repair. I would love to repair it for you or possibly buy it as-is. email me at bigmikeselectronic@comcast.net and i will do what i can for you.
Posted on Nov 27, 2006
    Problem Solver:
  • 18 Answers
If you saw smoke something fried, im surprised it still kicks on at all. my best advice is if you kno how to use a soldering iron, see if you can locate the problem, (i.e. melted wires and such), if not best would be to look for a new amp. hope this helps
Posted on Oct 06, 2006
4 Suggested Answers
  • 905 Answers
SOURCE: Amp won't turn on
disconnect audio inputs and outputs and see if one of those are causing it , if it still does it with all audio inputs and outputs disconnected then there is a problem with the power amp
Posted on Oct 08, 2008
darkoh69
  • 77 Answers
SOURCE: Amp runs but then will just turn off and red light comes on
you may have fried the amp pre outs in the head deck, try the amps on another stereo
Posted on Jun 01, 2009
MNfisherman
  • 11896 Answers
SOURCE: I have checked all connections to my amp
Your amp could be in protection mode! Sometimes turning up to high or wires touching will put in protection mode! It will have to be unplugged for a day or two to drain all power out of the memory. Leave accessorie/ignition wire hooked up, just not power and ground wiring. It should reset itself.
Posted on Jan 22, 2010
Testimonial: "Very helpful on many levels! Thanks for the help!"
Amp fuse 30a keep blowing
You have possibly melted a couple of wires together along the radio circuit. Also the radio unit itself has 1 or more protection fuses actually inside the unit that have blown, usually at back of unit in little bay near the wire clusters.
Check your relays too, a blow out through jump starting can do all sorts of little burn-outs.
Oct 15, 2016 | 2006 Lexus Rx 330
Goodman furnace GMT115-5B Turn fan to on on
Bypass the tstat first but that's where I'd be leaning.
Aug 14, 2017 | Goodman GMS90703BXA Heater
Ignition fuse keep blowing in my 2003 cavalier
u have a dead short on main live wire check for overheated wires
Jul 10, 2012 | 2003 Chevrolet Cavalier
I have a 2004 Chevy Cavalier. A couple of months ago, just after starting the car one day, the 'check engine' and 'trac off' lights both came on. I immediately shut off the car, waited approximately 5...
Well it's temping to put in biggfer fuses as the problem gets worse but the size of the fuses are to keep you from burning things up so you've from your probem with a 30 amp smoke test. The raditor fan wire is melted somewhere in the wire harnes to the wire for the trck lock or even key on circirts. the likly place to look is inside the stering collum. It takes the skills of removing the steering whel and the lcok plate and even then thats does'nt have to be where the problem is. You need to look under the dash after you remove the covers and use you nose to smeel for the burnt wiring and open up any thing the smells like it's been hot and anything the appers melted together. once a harness is found melted you need to seragete all the wires in the loom but don't cut the wires justy seaparte them. once you think you've got then all pulled apart so no bear wires touch each other or any meal parts put in the correct size fuses and see if you can connect the battery with out a spark. if you can you may then start checking to see what works and what does'nt.. This all sounds like too much work or too hard to do then you'll need to pay someone theat knows alot about car wiring problems to do it for you. I'll been doing this kind of work for the last 20 years and a'm alawys finding new things that are fried and burnt up. We all charge by the hour to do this work so the most experieced mechanic that works on cars like yours will probly find and fix the problem the fastest. therefore they may charge more per hour but their likly to get it right quicker and it'll stay fixed after they fix it.. This is the most likly kind of work to go sour after it's fixed cause they might miss a circuit that you use and they did'nt try. and as soon as it burns again it's back to the drawing board and if big fuses are use the fire can take the whole car.
Apr 26, 2011 | 2004 Chevrolet Cavalier
Many cars have the cooling fan on a thermostat or time delay, to allow it to run for a short period of time after the engine turns off, to cool the engine off. You may have just never noticed it before. So I wouldn't worry about that.
Your real problem is the blowing fuses, apparently you have a short somewhere in your wiring. Putting in bigger and bigger fuses is a great way to set fire to your wiring harness. It's possible that the wire is pinched or chafed somewhere, and perhaps when you hit a bump just right, it touches and shorts.
You may have to take this to the Chevy dealer or a GOOD independent shop to have them chase it down. Unless someone out there knows exactly what this is, it could be a tough one to find.
Apr 26, 2011 | Chevrolet Cavalier Cars & Trucks
A/C smelled like smoke then blew 30A fuse - Silverado 1500 2004
You may want to change the blower motor as a precaution.
Do all the fan speeds work?
If not .....change the fan resistor board which is right beside the fan at the same time you change the blower fan motor.
Aug 26, 2009 | 2004 Chevrolet Silverado 1500 Crew Cab
Weather King blows fuse in Criterion II furnace
You probably have a shorted wire between the heater and the a/c. There are two wires that conncet the control power to the outdoor a/c from the heater they should be on terminal c & y in the heater. disconect those two wires and try it again if the fuse doesnt blow you have a short in the wire between the a/c & heater
Jun 01, 2009 | Weather King 10AJA2501AH Air Conditioner
ROCKFORD FOSGATE T-3000bd POWER AMPLIFIER
u probley just cooked the amp cant tell u how much and i say that for every body so dont be stupid asking q. and a's like that
Oct 27, 2008 | Car Audio & Video
Lightning Audio LA1.150.2 Car Audio Amplifier Logo
230 people viewed this question
Top Lightning Audio Car Audio & Video Experts
80stech
Tygh Duval
Tygh Duval
Richard Lukszys
Richard Lukszys
Are you a Lightning Audio Car Audio and Video Expert? Answer questions, earn points and help others
