Question about Ricoh Aficio 1035 Copier
Sc322 i got this error sc322, this is the 2nd time happened..i just called the ricoh tech in my area..the solution is to buy the new laser unit..can anyone give a me a good advice ..coz this is 2nd time happened..whether i have to buy a new laser unit or i just throw away this machine..and buy a new machine ..if i have to replace this laser unit can anyone give me an advice how to take care of this machine..from my observation before this sc322 error coming out got a lot of problem..for example ,,the toner is start to dripping out ..as a result the machine look very dirty..
  • 162 Answers
For the care of its machine it tries to use to toner of good quality if he is possible original. Toner of low quality produces infinity of problems in its machine. One of them is that it damages the laser unit. Faults in the feeding of paper, among others.
The laser can be clean but, It must do it somebody specialized.
Posted on Aug 31, 2009
  • Ricoh Master
  • 2,794 Answers
1st laser synchronization error.  It is an expensive part to replace and in most cases its cheaper to by a used Ricoh.  There are some 1035s and 2035s out there that run around $700 in American dollars.  If you can find them.
It's possible there could be something going on with the power supply.
The toner spill can vacuumed as well as the optics and the rest of the machine can be cleaned simply with cleaner.
Posted on Nov 02, 2008
How do i clear code sc322 on nashua aficio 2016
Code SC322: Laser synchronization error
The main scan synchronization detector board cannot detect the laser synchronization signal for more than 5 consecutive 100 ms intervals.
Causes:
• Poor connection between the LD unit and the BICU board
• Damaged cable between BICU and LD unit
• LD unit out of position
• LD unit defective
• BICU board defective
Error Codes Ricoh Aficio 2016
Jan 04, 2015 | Office Equipment & Supplies
Sc 322 error
The first this I would do is remove the the front access door, and then the panel that is behind the access door to gain access to the laser unit. Most likely what you have is a bunch of toner and/or developer all over the laser sync board. Use a toner vacuum to clean this up, and your problem will most likely go away, unless there is something wrong with the board itself, but this is rarely the case. It's almost always buildup on the sync board.
Below are the details of the SC322.
SC322: 1st laser synchronization error
The 1st laser synchronization signal
cannot be detected by the main scan
synchronization detector board even if
the laser diodes are activated.
• Poor I/F harness connection between the laser synchronization detector board and the LD unit.
• Laser synchronization detector board out of position and angle of reflection not correct
• Laser synchronization detector board defective
• LD unit defective
If you don't know what any of this is, call a professional, as you could mess the MFC up even more by messing around with it.
Jun 13, 2013 | Ricoh Aficio 2035 Copier
Sc322
Sounds like the laser unit has failed!
SC322 - 1st laser synchronization error - • The 1st laser synchronization signal cannot be detected by the main scan synchronization detector board even if the laser diodes are activated.
Poss causes:
  • Poor cable connection between the laser synchronization detector board and the LD unit.
  • LD unit defective
If switching the machine off/on doesn't cure it you probably need a new laser unit. Has it been extra noisy before it failed? Whining/screeching/rattling?
Jan 18, 2011 | Ricoh Aficio 1035 Copier
After sc326-00 my copieur ricoh aficio 350 put on his screen sc322-00 and not work, how cold i resolve this problem
Laser Synchronization Error(1 & 2)(sc322 & sc326)
· Laser synchronization detector board out of position
· Laser synchronization detector board defective
Also check if any cables are loose and also if the laser unit is dirty.-Clean it.
Feb 09, 2010 | Ricoh Aficio 350e Printer
I HAVE AN ERROR SC 322 WHEN i GO TO PRINT RICOH 1035
Error Code SC322:
Possible Causes:
+ Poor I/F harness connection between the laser synchronization detector board and the LD unit.
+ Laser synchronization detector board out of position and angle of reflection not correct
+ Laser synchronization detector board defective LD unit defective
Not sure what your expertise is on this, but unless you know how to service the machine yourself, this one is going to require a service call...
There have been instances where toner drops onto the LD Unit and creates problems like this. About a month ago I replaced the Laser Synch. Detector Board in a 1045 for this exact problem and error code.
I'd start by cleaning up any toner on the LD unit, and re-seating all the electrical connectors on the laser unit. If that doesn't clear things up, it's probably one of two things, the LD Unit or the Synch. Board. I'd lean more towards the Synch. Board myself, but you never know...
Nov 18, 2009 | Ricoh Aficio 1035 Copier
I need solution to aficio 200 error code sc322
sc322 is a Laser synchronization error:
Means that the laser synchronization signal cannot be detected by the main scan detector board.
Possible causes:
Poor connection of the interface harness which connects the laser synchronization detector board and the BiCU board.
Laser synchronization detector board out of position or is defective.
BiCU board is defective.
Unfortunately,unit needs service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 19, 2009 | Ricoh Aficio 180 Laser Printer
Lanier 5645 SC322 Error
It's most likely your Laser diode (LD unit). You're going to require a tech...see the posts the following link for the same problem. It's for a Ricoh model, but your machine actually is a Ricoh Machine (Ricoh owns Lanier), and is virtually identical to this one -just a generation older.
http://www.fixya.com/support/t1936988-sc_326_322_329_in_af2045
Apr 07, 2009 | Lanier Office Equipment & Supplies
SC322 on Ricoh Aficio 2035
forget the laser unit your developer is shot... machine cant detect vsp and vsg... therefore gives a laser error... replace developer run developer initialization in sp mode copy sp drum... should solve the problem
Feb 16, 2009 | Ricoh Aficio 1035 Copier
Ricoh AP2600 printer gives an error message of SC322
1st Laser synchronization error signal error. The 1st Laser that turns on inside of the printer can't synchronize properly to print out documents which is why this message comes up and nothing is printing. Probably is going to need to be replaced but a qualified service tech is going to need to look at it further.
Feb 10, 2009 | Ricoh Aficio AP2600 Laser Printer
Ricoh Aficio 1035 Copier Logo
773 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
