Question about Samsung RS2630SH Side by Side Refrigerator
The ice is working fine. However, the water will not flow. Water was working fine. I was out of town for about 4 weeks and the filter light was on when I returned. I changed the filter and now water will not flow.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 185 Answers
Remove the drawer containing the Ice cubes , and blow a hair on the pipe where the water come in. If it wasn't used for 4 weeks perhaps the nozzle in the inlet pipe froze. Then put the empty drawer back in so the ice maker thinks it needs to make ice and see if it will work
Hope this helps
Loringh
Posted on Nov 01, 2008
Kenmore model# 106.9547651 ice maker has stopped working; water dispenser works.
A valve controls water flow into the ice trays. It is a common source of the trouble you describe. You may be able to get an overhaul kit for just the valve
Dec 26, 2012 | Kenmore Side by Side Refrigerator
Water flow to ice maker has been reduced to
Pull the line off at the icemaker and check for a filter at the inlet...often **** builds up there and stops off the water...
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 11, 2010 | General Electric GSS22JET Side by Side...
Automatic ice maker won't make ice
Turn off water.
Disconnect the line after the filter.
Turn water back on. If there is no water flowing, replace the filter.
If there is water flowing, the feed valve is probably defective.
Aug 02, 2009 | Kenmore Refrigerators
Amana Refridgerator won't dispense water or make ice.
  • Hi: You did your homework and checked everything. You said you checked the water flow to the refrigerator, and it was fine. Although what you described sounds like no or low water flow to the solenoid. I'm referring to the valve the water line is connected to. When they "rattle" it means there is not enough or no water pressure keep them open. These valves usually have a gravel filter. As you say it's a scratch and dent. The filter may clogged with gravel, or mildew (as it sat unused as a scratch and dent for who knows how long.) You sound handy. Before I replace that valve I would remove it and look where the inlet water is attached. Usually there is a screen behind a cap you will have to unscrew the size of an garden hose cap. See if there is a screen that can be cleaned. I'll lind the Sears parts direct page to you with the part no. #10 on the diagram. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=AFD2535DEB&productCategoryId=0161000&brandId=1268&modelName=AMANA-REFRIGERATOR&diagramPageId=00012&componentDescription=CABINET BACK&documentId=M0705005&backToLink=Return to Sub Components list The clogged screen would make the valve vibrate like you described. I hope this helps, Jeff
Jun 26, 2009 | Amana SCRATCH&DENT 25 Cu. Ft. French Doors...
About a week ago, ice making slowed way down.
changed the water filter. cost $43 for a new one. crazy.
Jun 17, 2009 | Aspen Refrigerators
Ge Profile bottom freezer, french door refrig, water filter
Just replace GE's filter with a standard inline filter that hooks to 1/4" water line tubing. Sounds like their filter has no flow rate either...
Here's a popular one:
http://cgi.ebay.com/AICRO-GAC-IN-LINE-FILTER-2-X-10-X-1-4-FNPT-JG-FIT-/390180520853?pt=LH_DefaultDomain_0&var=&hash=item99ab36a9be#ht_500wt_721
Jun 27, 2008 | GE Profile PSW26P Stainless Steel Side by...
Water/Ice Dispenser is not working
at the very least replace that water filter.clogged water filter will reduce water pressure to the line.
Feb 24, 2008 | GE Profile PSW26P Stainless Steel Side by...
Superba ice maker stopped working, door water still dispensing
Use a cup of water and just fill the ice cube maker with enough water for the first batch and the sensor will then begin making ice again.
My ice cube maker stopped working after I changed the filter. After reading countless posts about wiring and defrosting and using a blowdryer into the fill line I emptied my freezer and fridge, then unplugged it. I got no results after two days. I finally just put some water in the ice cube maker (the metal ice cube tray below the white plastic fingers that forms the cubes) plugged it back in and closed the door for a few hours and it worked. I wonder if I needed to defrost the unit at all. It was working before I changed the filter, then the filter was full and stopped water from flowing (or decreased the flow dramatically anyway).
Good Luck
Barry Eager
Apr 30, 2007 | KitchenAid Superba Architect KSCS25INSS...
Samsung RS2630SH Side by Side Refrigerator Logo
90 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
