Shredder problem Hi I have a home paper shredder which has stopped working. The motor appears to be working and is very noisy, but there is no movement of the actual shredding parts. There is no paper stuck although when I have lifted the top of the shredder there is a noise of something moving inside the actual machinery (a staple (or two) possibly??) Also when I try pressing the reverse button (just to see if that would help) a blue fuzz of electricity is seen at the back so I have been scared to touch the shredder and have switched it off from the plug instead. I have tried the forward shredder button several times now but nothing has changed. Please advise on what I should do. Many thanks. S
  • ktsheldon Nov 19, 2008
    My shredder seems to have stripped the forward gear. The shedders no longer rotate in forward, and the motor is very loud and seems to be rotating faster. The reverse still works.
    This happened when I fed too many sheets into it. It bogged at first and finally just stopped shedding.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 185 Answers
May I respectfully suggest that you do not attempt any repairs on anything that creates a "blue fuzz" of electricity.It is not worth the risk. I am a retired electrical engineer and over the years have developed a healthy respect for faulty electrical devices. Sparks anywhere near paper is a disaster waiting to happen
good luck
Loringh
Posted on Nov 01, 2008
My shredder won't shred
If the motor will not run, then probably there's paper clogged in the shredder. Turn over the shredder, after unplugging the power cord, and remove the papers.
If the motor will run but not shredding any paper, then the drive gear has broken teeth. This is not usually worth fixing.
Hope this helps.
Mar 27, 2015 | Shredder Office Equipment & Supplies
Red light and green light on but motor will not come on
Check the Power Ensure that the shredder top is firmly placed in the shredder basket if the unit will not operate. If the top is not in place the feeder will not work and accept any paper. Make sure it is firmly plugged into the wall outlet and that the outlet is active. Rest the Shredder Let the shredder cool down if the shredder has been running continuously for a long time. It may have overheated and needs to be left in the off position for at least 30 minutes to reset. Verify the basket is empty or not too full as that will cause the shredder to deactivate. Clear Paper Jam Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Auto Mode Not Working Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Sep 13, 2013 | Fellowes PS60-2 Shredder
My jaws shredder appears to get overheated every now and then and just stops running, is this normal? also, when I shred alot of paper sometime it will gets jammed and I have to go back and forth on the...
Remember this is a "consumer" shredder NOT a commercial shredder..... if you shred for 5 minutes you should give the machine 10 minutes for the motor to "cool-down"...it will not hurt if you also shred some paper with shredder oil poured onto the paper so that the oil lubricates the cutting blades...lastly; if the shredder is rated to a Max. of 10 sheets(as an example.)..you will have fewer problems if you only shred about 70 % of that number. ***Think of your car...it will go 100m.p.h.....but how long will it last if you drive it at its maximum speed all the time.????
Jul 17, 2010 | Royal Jaws Shredder
Shredder does not pull paper in anymore, it makes noise, does not shred
Add some paper shredder oil. A shredder needs oil to function properly, oil should be applied every month or more depending on how often you shred. Learn more here: http://hubpages.com/hub/Paper-Shredder-Oil
Jun 13, 2010 | Fellowes DM8C Cross-Cut Shredder
Royal 85x crosscut shredder stopped working
Some shredders aren't designed to shred anything more than paper. Credit cards, staples, paper clips and the like could have jammed it up. Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 25, 2010 | Royal 85X Shredder
It will not grab the paper; need to press forwared
May 24, 2010 | Quartet gbc Shredmaster 6550X...
My paper shredder stopped working
First things First...UNPLUG THE UNIT. It sounds like it has been fed too many pages at one time. You may also want to dump any shredded paper so there is plenty of room for the shredder blades to pull in the paper. If the paper catcher is too full the blades can grab shreds from the bottom and stop the blades movement. Just be careful. Shredders can be dangerous.
Jun 01, 2009 | Office Equipment & Supplies
Shredder
Check for stuck paper and remove if any. Then check if motor is ok with a multimeter and also main switch.
May 20, 2007 | Aurora Global AS501X-MS Shredder
185 people viewed this question
k24674
jasbo
jasbo
