Question about GE (PSS26MSRSS) Side by Side Refrigerator
Temperture will not stay at 37 degrees ,cannot set it.
I have a ge artica profile model # pss25ngmdbb everytime i open up the fridge the inside led read out is always different. i adjust the temperture to 37 but it doesnt stay. any clue on how to set it and make it stay
Thanks
  • 1 more comment
  • jlsteele Dec 21, 2008
    Exact same problem only mine is always below 37 and freezes food constantly.
  • Anonymous Jan 23, 2009
    I have the same issu --
    1. Refridge temp won't acknowledge the temp I've set. I set to recommended 37 degrees but registers at 34 degrees.
    2. Fresh produce and custom cool drawers freeze my food - especially toward the back of the drawer.
    3. Water dispenser on front works / stops working intermittently.
    Model PSS25NG MD CC
    Built in Louisville, KY @ GE Appliance Park
  • Anonymous Jan 25, 2009
    We have a PM26M and the every once in a while the water line stops working, the vegetables freeze and the temperature goes to plus 3 0r 4 in the freezer and 40 to 47 on the right side. There is major ice build up in the back of the fridge. Any suggestions.
5 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: GE Artica SxS Model #PSS25NGMD: Food on fridge
So long as the fresh food side stays 36-42 degrees you are OK.
Posted on Feb 22, 2009
  • 61 Answers
SOURCE: Refrigerator does not maintain 37 degrees
i have seen this problem before its the control board in the back the board is about 150 dollars and it goes every DING DING 5 years lol horrible design of the one that comes on the fridge every ge side by side has this problem  its very easy to replace but have to "ground" yourself before you touch the new control board meaning rub you hands on plumbing pipes, not pvc or copper
good luck if you got questoins let me know
Posted on Jun 08, 2009
Sea Breeze
  • 4654 Answers
SOURCE: GE Profile Artica side by side stainless steel wont get cold
The Profile and Artica are good refrigerators. the problem may be the defrost element, defrost thermostat or the mother board. Let me know if you want help on this one. Thanks Sea Breeze
Posted on Jun 18, 2009
Sea Breeze
  • 4654 Answers
SOURCE: I have a GE Profile Artica S/S, model # PSS25NGMD
With temperatures like that the water tank is frozen stopping water to dispenser. This could be thermistors in fresh food section going bad or a combination of thermistors and motherboard. I can assist you if you have not already called for a technician. Sea Breeze
Posted on Mar 23, 2010
marka19
  • 1430 Answers
SOURCE: Refrigerator is too cold (28 degrees)
this is likely one of the thermistors on the fresh food side has failed. They are usually located under a small cover inside the fridge. They should have a reading of 15.5k-16.5k ohms at 72 degrees. They are easy to check and replace. Here is a link that should help. You can also enter your model # for diagrams and illustrations of your specific model. http://appliancehelponline.com/sxsfreshthermistor.html
Posted on Jul 16, 2010
All of a sudden my GE Profile Artica's freezer is at 25 degrees and the fridge side is at 43 degrees. I've forgotten how to "set" the temperatures but I'm afraid that's not the problem. Any ideas?
I would clean the condenser coil. This coil is located under or in back of the frig. When they get dirty the frig can't pull down the temp.
It's a common problem.
I hope this helps.
Aug 23, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Jul 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
WATER FLOWS TO ICEMAKER BUT NOT TO WATER DISPENSER,TEMPERATURE ON THE FRIDGE SIDE WILL NOT STAY AT 37
if the tempt gets to low it will freeze the water blater and you know what ., the control will have to be repl to stablize tempt . m m
Nov 20, 2009 | GE Profile PFS22 33" Artica French Door...
Jun 18, 2009 | GE Profile Arctica Stainless Steel Top...
Everything in the refrigerator is freezing
The 37 degree reading you're seeing is the temp. setting, not the present actual temp. When it jumps back to 22-25 its telling you what the actual temp is inside the refrig....simply wait about 24 hours. It should then read about 37...that is, the temp you set it at 24 hours previously.
Nov 23, 2008 | GE Profile PFS22 33" Artica French Door...
GE Profile Artica won't drop temp past 52 degrees
Dear FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
YOU NEED SERVICE FOR THIS PROBLEM!! SORRY!!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS.PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OUT!
Aug 26, 2008 | GE Profile PFS22 33" Artica French Door...
GE side by side (purchased 2005; don't know exact model)
Defrost timer issue is my guess. It is generally located behind the rear inside panel in the fridge section. I'm guessing about $150-200 or so to fix it.
Jul 24, 2008 | GE Profile PFS22 33" Artica French Door...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
48 people viewed this question
Top Refrigerators Experts
KJ4QOB
Alan Moore
Level 1 Expert
Gerardo Ahuactzin
Gerardo Ahuactzin
Level 1 Expert
