Question about Nikon Speedlight SB-800 TTL Flash
My display has a big back blotch and I can't see a damn thing
The display has a giant black spot on it and I can't see the settings. Where can I get a new LCD or get it fixed without sending it clear across the country (I'm in Dallas, TX)
  • 62 Answers
I can repalce this LCD assembly for you .
Berrie Smith Camera Repair
bbmw@bellsouth.net
Posted on Feb 06, 2008
Black spots tv screen goes away sometimes
Your tv has multiple backlights in it... sounds like one of your inverters are going. Don't be surprised when the tv stops displaying anything at all.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_3e83613ef5f2a68b
Dec 31, 2013 | Televison & Video
I have two black spots on a goodmans GTV27WLCD telly. Can I get rid?
HI unfortunatly they are dark black blotches that no light travels through, they are leakages in the nematic liquid...... you can gently try & massage them away if there still apparent after that then im affrraid Sadly your display is TOAST.
Apr 06, 2012 | Televison & Video
I have a hitachi 50vs69a with 2 yellow spots in the middle of the t.v when powerd on.....black when off. these spots almost resemble states...there is also blue splotches in the middle of these spots. any...
Yes, if the spots are round or teardrop it may be burnt picture tubes.
Easy to confirm this by covering lens of tubes one at a time with set on and see which removes the blotches.
What happened in a lot of these sets is the set arcs and burns a black dot dead center in one or all three of the screens of the picture tubes used--fatal case and permanent.
Mar 14, 2012 | Hitachi 50VS69 50" Projection HDTV
Our printer leaves black spots/blotches all over everything we print. Ive changed the cartrdige and attempted to clean out the printer and these black spots will not go away, what should I do?
I think you'll also have to clean the fuserunit. This is the hot part at the back of the machine. Take of the back covers and you can take it out to clean it.
Oct 05, 2010 | Lexmark Optra T610 Laser Printer
The screen on our gps is messed up! Either it got
You would have to send it to Garmin unless you found a Marine Electronics dealer that had an old display in their shop. They could then replace your display. Good luck!
May 22, 2010 | Garmin Gpsmap 5012 Touch Screen...
Screen has black blotches/spots
This could be due to a bad video card, but is much more likely to be a problem with your screen itself. What you described is likely to be caused by damaged or dead pixels in the screen. The cost of one is usually about half of the cost of the laptop itself, so you may want to consider buying a new laptop and salvage your data and other usable parts from this one.
Apr 26, 2010 | Apple iBook G3 Clamshell (M2453B) Mac...
Rca scenium 50 inch dlp. i now have 3 black blotches in the screen. they look like giant finger print smudges. very noticable on light colored screen.
You have a problem in the light engine portion of the set. Somewhere in the optics. It could also be a build up of dust or a foreign substance. Have a repair shop give it a good cleaning inside. You may want to pull the bulb and make sure there is no foggy places inside of it. Thanks
Oct 28, 2009 | RCA Televison & Video
Dark Blotches
This is probably caused by dust, either on the mirror, lens, or possibly inside the light engine. There is a 5" dia hole on the side of the back of the tv where you can take out one screw and take the door off. this is just big enough for you to put your hand through to clean the mirror and lens. Hope this helps.
Mar 30, 2008 | JVC HD-61FN97 61" Television
Lexmark E320 Printing big black smear
1. Make sure that you removed the entire paper jam and that nothing is caught in the fuser assembly (the part that gets hot so make sure it is cooled off first,also do not use anything to dig at anything that might be there try carefully using a tweezer or needle nose pliers to pull it out.
2.Remove the toner cartridge and with a dry cloth or a pencil eraser clean off the contacts on your left when facing the inside of printer and the roller on the bottom can be wiped off to remove excess toner.
3.With toner cart. still out use a dry cloth to wipe the laser print head area located directly above the roller on the bottom of the printer be careful as the metal edges are sharp.
4.If there is a build-up of toner at the entrance of the fuser try gently removing it with a flat blade screwdriver with care.
5.If this doesn't help it may be necessary to replace the toner cartridge itself.
Best Luck
Mar 11, 2008 | Lexmark E320 Laser Printer
Sony Cybershot DSC-P32 Display screen problem
very easy to replace screen here, just couple of screws, and back cover comes off, exposing the screen. you can buy broken p32 on ebay very cheaply, just look for it to have problems other than the screen
Aug 16, 2007 | Sony Cyber-Shot DSC-P32 Digital Camera
Nikon Speedlight SB-800 TTL Flash Logo
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
