Question about Dell UltraSharp 2005FPW 20.1" LCD Monitor
LCD Monitor doesn't work!
My monitor won't come on. I have a Dell 2005WFP that won't power up. What happens is, if I reseat the power cord, the on/off switch blinks slowly along with the number 2 on the LED panel. This will go on for about 5 or so minutes before it goes black again. I also can see the slightest flicker in the video as the lights below are blinking. Also, while this blinking is going on, pressing any of the buttons does nothing; the only thing the monitor "responds" to is pulling out and plugging back in the cord.
I also tried reseating the video cables, both analog and digital, but again that did nothing.
Is the monitor toast or is it repairable (at a cost lower than simply buying a replacement)?
Thanks!
  • 3 more comments
  • Elmos Woods Nov 01, 2008
    Sorry, Eagle, I closed it by mistake and wasn't sure I'd get double-billed by reentering.
    Thank you for your response; I'm glad it's a matter of replacing a part. Unfortunately, I have zero experience with monitor repair, so I guess I'll have to look for a shop.
  • Anonymous Nov 07, 2008
    una parte del el monitor no funciona
  • danielpoling Nov 08, 2008
    I have the same problem, and would very much like to fix it.
  • secb Dec 02, 2008
    I more or less have the same problem. When I turn on the monitor the display scrolls for 5-10 minutes while the screen warms up and makes a shrill high pitched whine. Once it's warmed up the display works fine for 30-45 minutes and then the power starts flickering on and off.
    Where can I find a new inverter board and what's involved with replacing it? Simple soldering or just unplugging an old card and connecting a new one?
  • quintonvl
    quintonvl Dec 05, 2008
    also looking for an invertor board as mine has also gone **** up!... ;-)
  • 4,889 Answers
Hey why did you disconnect the live session? Anyways what you have is a faulty inverter board.. You can get a replacement easily. I got one from ebay last week for 35$. So if you just tell me the part number I can get you the best deal..
Posted on Nov 01, 2008
Monitor doesn't turn on
1ST CHECK POWER CORD.
2ND CHECK CONNECTION ON BACK OF PC
3RD HAVE YOU INSTALLED, DELETED OR REMOVED ANYTHING FROM YOUR PC PRIOR TO THE MONITOR SHUT OFF ON YOU
Feb 17, 2013 | Dell ST2420L 24 inch LCD Monitor
Dell E177FPv, 17" TFT LCD Flat Panel Monitor will
I think you might have the same problem I did with my E178FPb. I made a video on how I fixed it.
Apr 04, 2011 | Dell E177FP LCD Monitor
Dell UltraSharp 2001FP (Gray) 20.1"
This monitor uses a power supply not just a cord . You can get one on e-bay very cheat . Just type out 2001fp an choose the person you want to get it from .
Feb 09, 2011 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell e137fp monitor flashing green...
Below you will find my recommendations for troubleshooting this issue:
1. Reseat the power cord and verify a good power source.
To reseat the power cord, follow the steps below:
1.1 Power down the system.
1.2 Unplug the power cord.
1.3 Wait approximately one minute.
1.4 Reseat the power cord.
1.5 Verify that the power cord is plugged directly into a known good power outlet.
2. Verify that the monitor is receiving power from a known good outlet and bypass any power strips.
To test the power outlet, perform the following steps:
2.1 Unplug the monitor power cable from the power outlet.
2.2 Plug in a different device, and verify that the device is operational.
2.3 If there is no power try another outlet. Remove any power strips and try plugging directly into the main power outlet.
3. Verify the monitor is powered on and the power button is engaged.
Ensure that the monitor is powered on and that the power button is fully engaged. To do so, check the power LED on the front of the monitor; it should be lit.
NOTE: There are two types of power switches:
A mechanical switch characterized by a long travel. You have to push it further and you will hear an audible click.
An electrical switch that has a short travel and almost no click.
A lit monitor LED can be any of the following:
* Green
* Blinking green
* Yellow
* Blinking yellow
* A combination, such as alternating green and yellow
Any of these states indicate the monitor is receiving power and that you should proceed.
4. Swap power cables.
To try a known good power cable on the monitor, follow the instructions below:
4.1 Turn off a working monitor.
4.2 Unplug the cable from the back of the working monitor, and unplug the cable from the wall.
4.3 Unplug the cable from the monitor in question.
4.4 Plug in the cable that came from the working monitor.
5. Run the monitor self test.
To run the monitor self test, perform the following steps:
5.1 Power off both the computer and the monitor.
5.2 Unplug the video cable from the computer or video card.
5.3 Reseat the power cord to the monitor, ensuring it is plugged into a known-good outlet.
5.4 Power on the monitor.
NOTE: The monitor self test will move around on some monitor models. If the monitor self test moves, allow it to move to the affected areas of the monitor to check for the problem described.
If the Self test failed, it's possible that the monitor is faulty. Contact dell to check if it's still under warranty so they can replace it.
Jun 15, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Monitor not working after adding drivers
1. turn off your computer
2. turn off your monitor
3. Unhook the power and video cable from both
4. Reseat them both on both ends.
5. Turn on your monitor
6. Turn on your computer
If its still doesnt work after all 6 steps, your monitor is bad, sorry.
Apr 02, 2009 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
19" Dell Monitor
some of the AC plug for dell monitor need to force little more than others. make sure the plug on the button is fully seated. (pull it out and reseat it).
the power button is the first one on the lower right hand corner.
Oct 22, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
My screen has gone black
try to reseat the vga cable of the monitor,reseat at the back of the computer and on the monitor,if the cable is disconnected,make sure that you can see the power on self test with different colors in it,if you cant see it then your monitor went bad,try to connect another monitor to your computer,see what will happen,try using other cables as well
Jul 05, 2008 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Power supply
it is not the power cord you should chk for th video cord. it mean there is no siginal coming from the CPU.
Thanks for using fixya. Hope this solution may have helped you.
Jun 17, 2008 | Dell E156FP 15" LCD Monitor
Dell E151FPp LCD Monitor
Next time you reset, check both the monitor settings and your BIOS settings for wake up
Feb 24, 2008 | Gateway FPD2275W LCD Monitor
Lcd monitor
Hobo, The chances are good that it?s the monitor; however, there are a few things you can check: -Try connecting the monitor to another computer, if the problem follows. If it doesn?t try the rest of these suggestions, if not skip to the bottom. -Remove the VGA connector from your PC and inspect the pins to make sure none are bent over or corroded. -Try replacing the VGA cord that connects the LCD with the computer. -Try opening your PC, removing and reinstalling the video card assuming it isn?t built into the motherboard. This monitor has a three year warranty from Dell so I wouldn?t try opening the monitor case until you call them. Even if you suspect it is call them up anyway, on more than one occasion I?ve called Dell about a problem with an out of warranty PC only to find out there was a unadvertised replacement program. So call it can?t hurt. If its out of warranty then depending on your comfort level you can either try to fix it or take it to the local repair shop. Usually they will do an eval for about $35. Let us know if you have any other questions and please don?t forget to rate this posting.
Mar 18, 2007 | Dell E196FP 19" LCD Monitor
Dell UltraSharp 2005FPW 20.1" LCD Monitor Logo
810 people viewed this question
Alun Cox
