STRONG SMELL OF DIESEL INSIDE MY CAR
SOURCE: Grand am smells like gas inside the car
Remove the vacuum hose from the fuel pressure regulator have some one turn the key on but dont start the car if gas leaks out the regulator is bad.
SOURCE: fuel leak, strong gas smell inside and outside of car
when you look for a fuel leak, make sure the engine is running. the fuel lines will be pressurized and you are more likely to spot the leak. if you see fuel squirting, be careful since it under a lot of pressure. it might look like a single strand of a spider web. also, you should wear eye protection since gas in the eye would be a bad thing. needless to say, don't light a match or lighter for light to find the fuel leak. since gas is explosive, you probably should take it to a shop if you can't fix it. it could be dangerous if gas drips on a hot part. fuel vapors are explosive too.
SOURCE: gas smell inside pontiac vibe
for more safe u need to take ur car for a delar or garage but it cuold be leak from the fuel tank or maybe from the evap system
thanx for asking us
I would definatly recheck the regulator to make certain you do not have any leaks.
But to be clear, you are smelling gas and not exhaust?
Also, is you cowl seal in good shape, not missing or damaged in any way?
Let me know.
Regards,
