Question about Acer TravelMate 2300 Notebook
Dismantle to resolder coose power socket
Any dismantle instructions and tips to gain access to power jack socket for a resolder to fix loose connection would be appreciated for an acer travelmate 2410.
Thanks
    Scholar:
  • 46 Answers
I would either look on youtube or Acer's website to find some kind of service manual which would help you. Make sure to keep track of your screws. :)
Posted on Dec 15, 2008
The dc power jack will not accept power. I have to wiggle it to get the blue light to show that the laptop is charging. My computer is the acer aspire 5920-6423. I was told it wouldn't have to soldered...
If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.
The laptop needs the motherboard removed to get access to the DC jack so it can be resoldered or replaced if it is faulty.
This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Nov 03, 2011 | Acer Aspire 5920-6727 Notebook
Need to resolder dc jack on S6010 lifebook
This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket to resolder andrepair. If you cannot DIY then I suggest you get a quote first.
Jun 20, 2011 | Fujitsu LIFEBOOK S6010 Notebook
My ac adapter is very loose fitting when plugged into my Dell Inspiron 1525. Any suggestions?
Its worn and therefor loose, only option is to get a new power input socket fitted
Jul 01, 2010 | Computers & Internet
Toshiba L300 Case Repair !
Basically the input power socket need to be replaced. To get at this power socket will require the laptop to be completely dismantled to remove the motherboard to gain access to this power socket. If you find this too dificult to DIY then I suggest you get a quote from a computer repairer before you get this job done.
Jul 03, 2010 | Toshiba Satellite Pro L300 Notebook
Hi i asked for my ibm t40 laptop dc jack to be replaced and i have looked in my profile but all i can see is dc jack for a printer my problem is changing the dc jack on my ibm t40 LAPTOP
Problem with power socket on the laptop, it may caused by a dry solder joint and needs to be resoldered or the power socket may be faulty and needs to be replaced. Either way to fix this, it requires the laptop to be dismantled to get at this power socket. Get a quote to repair, as it could cost a few dollars.
If it is a faulty cord/plug on the power adapter, this can be checked with a multi-meter. When you connect the multi-meter probes to the power plug the voltage should be steady and the reading should be slightly higher then the voltage that is printed on the label on the bottom of the power adapter. If the voltages fluctuates as you wriggle the plug then you have a broken wire in the plug. Replacing the plug would not cost much.
Jun 20, 2009 | IBM Computers & Internet
My HP nx7300 will not power up. The LED doesn't even come on when I plug it into the AC supply
You could have a faulty power adapter or the power input socket on the laptop is faulty. Check the power adapter plug that plugs into the laptop with a multi-meter. The voltage reading should be slightly higher that the voltage that is printes on the label on the bottom of the adapter. If you get a zero or low voltage reading then the adapter is faulty and needs to be replaced. If the adapter is OK then the power socket on the laptop is faulty, it may only need to be soldered due to a dry solder joint or replaced if faulty. To check if it is a loose connection, wriggle the plug in the socket and observer the charge LED, if it flickers on and off, then the power socket may oly needs resoldering. This requires the laptop to be dismantled to get access to the power socket.
Jun 11, 2009 | HP Compaq nx7300 Notebook
M2352 Power issue
There is no quick fix other than tapping or glueing it into a position that works. This is not a permanent fix and will fail again sometime.
The laptop power connector is either loose or faulty, the laptop needs to be dismantled to access the plug to resolder it (if loose) or replaced if faulty.
Jan 09, 2009 | E-Machines M2352 Notebook
Open cover to resolder power jack
You will need to remove the system board to gain access to the power jack. Here’s the link for the Inspiron 2200 service manual: http://support.dell.com/support/edocs/systems/ins2200/en/SM/index.htm
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 10, 2008 | Dell Inspiron 2200 Notebook
Computers & Internet Logo
173 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
