Laptop freezes restarts or goes to a blank screen
My pc freezes or restarts or just goes to a blank screen. tried to restore but the fault stays
  • codemann8 Dec 19, 2008
    I have a similar problem. I have Model: L305D-S5893
    I'd be in the middle of something and the computer would freeze (screen sometimes turns white) and forced to restart. When I restart, the screen doesn't turn on at all, no Toshiba splash screen. I have to open up the memory cover and remove and re-insert the RAM in order for me to get the computer working again. ...Or leave the battery disconnected for awhile.
    I was talking to a few people about this, could this be an issue with the video card using shared memory and the system tries using a part of RAM already dedicated to the video card?
  • 3 Answers
Replace your RAM or try swapping your RAM chips between the slots.
Posted on Nov 01, 2008
2 Suggested Answers
techniwiz
  • 275 Answers
SOURCE: laptop freezes restarts or goes to a blank screen
its not the issue with the system
u have a usb printer connected to the system
disconnect that and start the system it should work
My screen goes blank and you can only hard boot or the computer just restarts itself
Hard dive seems to have corrupt initiation files,try restoring system
Jan 18, 2011 | Acer Aspire One PC Notebook
Laptop powers on but goes to a blank screen and stays there
Your problem could be a backlight problem, it is caused by either a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instruction to determine the fault and possible fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jul 14, 2010 | Toshiba Satellite A45-S151 Notebook
All funcions freeze.have to switch off and start again .crash's screen goes blank' it is only four monts old
Try to start the compute in safe mode, and check if the computer works without any issue, to access safemode, you have to press the F8 key while you get the Acer Logo.
Try restoring the Operating system by pressing Alt+F10 when you get the Acer logo and follow the screen.
Apr 07, 2010 | Acer Aspire One PC Notebook
Laptop won't boot up. All lights come on and stay on, power, harddrive, cd drive, start, stop, play etc. No bios screen or anything. Screen stays completely blank the whole time.
did you try with restore disc? can you go to boot on start up hitting delete?.. if cannot ... i will pull out the battery on mother board (to reset cmos-- or you can do that with jumpers) .. since this is a laptop.. you will have to separate parts.. if it still on warranty go visit service.. in most case restarting cmos helped... it is not easy to clarify the situation you are having this way.. does it produce any sound on startup? (like it is working but no screen?) if it does it might be that the jumper of monitor that is connected to motherboard is unplugged... (rarely bu it might be)
Dec 02, 2009 | HP Pavilion dv6646us (GS687UAR) PC...
My cursor freezes and the screen goes blank. The
Try to update your machine's BIOS. Download it from the internet (search for the Gateway drivers - bios).
Jul 01, 2009 | Gateway M-6843 Notebook
My srceen goes Blank
first try booting the laptop and pressing the Fn key with the numerical ( numbered key ) that has a picture of 2 screens on it. This is for booting to an external monitor. you could also try adding an external ( pc monitor ) this will eliminate any motherboard Faults.
Secondly, the graphics chip driver may be corrupt or not installed correctly. if you have a restore cd, you could try booting the laptop, with the cd in the drive.
you can then try, to see if the settings in the bios are all correct, by booting/starting the laptop and pressing esc or F2 or delete immediately as the laptop starts. ** Be-Careful** what you adjust.
My suggestion is to look for. ** default settings tab** or load setup defaults.
these are the obvious things to try, before assuming that you have a faulty graphics chip or motherboard fault.
Mike @ compurepair.
Jun 12, 2009 | Acer Computers & Internet
Screen going blank and laptop freezes.
One thing that I've noticed about the Inspiron 1000, is the LCD ground is done exclusively thru the hinges. Try tightening the LCD hinge screws (Marked with a (D)) 2 on the bottom of the chassis and possibly 2 on the back. (I just tightned every screw I could find)
Once the ground connection is improved, the LCD may work better
May 23, 2009 | Dell Computers & Internet
Blank light blue screen (NOT blue screen of death)
hi...some times norton uninstallations create this problem, in which norton also uninstalls some system file like virtual driver file, etc.! u can try these things :
1. use systen restore to restore ur previous settings
2. IF it don't works, reinstall window !
let me know if it helps....
Jan 01, 2009 | Compaq Presario 700 470024-192 Notebook
Nov 01, 2008 | Computers & Internet
KDS Valiant no image on on screen
first of all try to start your laptop in safemode
1 start laptop
2 continously press F8 key
3 when you see menyu select "start windows in safe mode"
if your computer starts with same mode and you see the desktop
then you just have to restore your xp with earlier system restore check point
and if you dont see desktop in safe mode also then you must have to install win xp again
steps for restore windows xp
1 start
2 programs
3 accassories
4 system tools
5 system restore
6 chose restore system to earlier time
then select any earlier date in calender at which computer is working properly
and click restore
it restores your xp and restart your pc and your problem will be solved
if still having problem then you must reinstall windows xp
Mar 07, 2008 | KDS Valiant 671DP Notebook
Computers & Internet Logo
967 people viewed this question
David Payne
David Payne
