Question about Denon D-M50S CD Shelf System
Deneon UD M50 - Tray jam
My kids stuck 2 cd's in the draw and this has jammed them. Managed to get the CD's out but now the draws are jamming. Mech error appears as a message . Any ideas
    Problem Solver:
  • 20 Answers
It sounds like the cd tray has been forced shut and has been damaged when you got the CD's out. If it was me I would of unscrewed the casing and retrieved the CD's that way instead of trying to force the try open which I'm assuming you have done.
It could just be a simple matter of just slightly adjusting the internal CD mechanism so that it can open and close properly without jamming. The error message comes up because the tray cant eject properly. The worse case scenario is that the CD mechanisam would need to be replaced. Not a hard job for a service engineer, if you dont fancy taking the thing apart yourself then a service centre is your best bet.
Posted on Nov 01, 2008
HOW TO REMOVE THE PAPER TRAY
To remove the paper tray draw 1 or2 or 3or 4 on the right side of the draw you should see a single screw it holds a small metal lock remove it and the slips all the way out.
Mar 20, 2014 | Minolta bizhub 200 All-In-One Printer
Hw do i fix my minolta dialta di 552 for continuous paper jam
Where is it jamming, which draw are you using have you tried different draws or the by pass tray? Does it jam when copying versa printing? Have the draw rollers been cleaned? jamming in the fuser the hot part or under the drum before the fuser?
Mar 09, 2013 | Minolta Office Equipment & Supplies
Jam in tray 1. Where is tray 1?
Hi, Kindly note that bottom Draw of the printer is the Tray 1. If the printer says Jam in Tray 1, kindly check if there is any paper struck in the printer. Remove the Paper from that Jam & your printer should work fine.
Feb 05, 2010 | Brother HL4040CN Laser Printer
DVD/CD won't open...when I push the open/close button it says it is opening but nothing happens....have turned it off for a while and turned it back on - still nothing
if the disc inside has jammed or there is any damage to the mech for opening this can cause the jam you can open it manually by getting a paper clip ot long needle and look to the front panel just below the draw htere is a small hole insert the paperclip end into this and push the the pin in it should go a way in this will actuat a release lever the tray shoul open for you you can check the inside mech after this it may need some grease on the draw runner. Good Luck A
Oct 16, 2009 | Bose Lifestyle SA-2 2-Channel Amplifier
Why doesnt the cd/dvd stay in the VALOR player?
The dvd drive coud be jamming on something inside, or the dvd tray belt could be slipping or the disk could be jamming on something inside which is preventing the draw from sliding all the way in.
jon
Aug 10, 2009 | Valor Televison & Video
6 CD Changer Jammed (Audi A4)
You may have to remove the unit and disassemble it to remove the CD that evidently is jammed inside. If your unit has a removable magazine that holds the CDs, the magazine probably is stuck.
Oct 22, 2017 | Car Audio & Video
I have an denon ud m50 multi cd player and reciever some one tried to put more than 1 cd in the same tray and it now will not accept any so its a mechanical problem can this be fixed and if possible...
Yes this is fixable by rebuilding the loading mechanism. As long as the mechanism is just jammed and no parts are broken, this should only cost the labor charge at a local service shop. I have done a number of these in the past and while not the simplest of mechanisms, it is fairly straightforward.
Dan
Aug 26, 2008 | Denon Audio Players & Recorders
Cannot get the cd to eject the disc
in under or below the cd tray is a small hole, a paper clip straightened out can be inserted to release the latches and draw out the tray, many times it is just stuck, less often it is damaged, and will jam again
Jul 11, 2008 | Audio Players & Recorders
DENON UD M50 CD PLAYER no longer works
Maybe you accidentally break some contact(s), on display or somewhere else. If that is the problem, soldering iron should solve that. Look for any loosen wires or detached contacts.
Oct 10, 2007 | Audio Players & Recorders
Denon D-M50S CD Shelf System Logo
554 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
