My Lacie 500GB desktop hard disk was bought half a year ago, it's broken now, however I never droped or damaged it, but now it just couldn't be identified by my computer, I have changed the USB 2.0 cable, and the problem is not with my computer either, the disk still doesn't work, what can I do? help!
  • babysayno Nov 02, 2008
    Thanks! However I tried but still, nothing happened.
    The disk is an external, it got a power wire itself, but i'm sure the power is fine, there's no problem with the usb input either...
  • Anonymous Mar 27, 2009
    i have the same problem... computor show a usb has been attached but nowhere does it recognise that a lacie is attached... hmmmm.
    Brigadier General:
  • 3,614 Answers
Change the wire and try testing it into another input.
also for clarification:
  • is the drive was connected internal or external?
  • did you got a power coming on your pc.?
Posted on Nov 01, 2008
  • micromaster
    micromaster Nov 02, 2008
    try a different cables. theres no way the drive will be damaged unless you stored it not properly/
I bought today a lacie hard disk 500GB and instead of 500GB has only 9.99 MB space.What's the problem?
Sounds like your have a 9.99mb partition on your drive with the rest being free space.
If you are running windows goto the Computer Management program and check under storage> disk management to see if your 500gb drive is there. if it is delete the existing partitions and reformat the entire disk to NTFS
May 21, 2011 | LaCie Big Disk 500 GB Hard Drive
I bought a few years ago a Lacie d2 safe hard drive with AES Encryption (with biometric fingerprint sensor). Currently not my Toshiba desktop or IBM laptop pick up the hard drive when I switch it on. The...
Hi... Problem with your external hard drive, pc don't recognize it...
it possible you have bad sector in your disk drive, or your usb cable is not responding.... the best way to find out open your box then take off our hard drive and install it into a pc and see if the hard drive work... or you box it self the controller inside our external box maybe damage,
Oct 20, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
Hello! I dropped my Lacie Brick (300GB, the blue one, bought in 2006 - that's all I can remember, I don't have it here right now) and now, of course, the HD is broken. I lost my data, but I've been...
If the disk-drive was LARGER than 500GB, it definitely would be a SATA drive; nobody makes IDE disk-drives larger than 500GB.
How about getting your friend to help you open the case?
Given that it is four years old, it probably pre-dates most SATA disk-drives.
Or, take it to a computer-store, and have them open it, and sell you a brand-new (and thus more "reliable") disk-drive?
Oct 17, 2010 | LaCie BRICK (301063U) 300 GB Hard Drive
LaCie Big Disk 500GB not showing up
1. the usb connector in the PC may have a broken board contact needs soldering or replacement.
2. there may be a broken USB cord to the external usb drive
3. the electronic controller in the USB case may not be working.
4. A new case may be needed with a new controller.
Jul 08, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
Lacie do not start
If it still is under warranty, then exercise the warranty, and get it repaired/replaced.
If it's out-of-warranty, then disassemble the case, and disconnect the disk-drive from the USB-to-disk-drive adapter.
Connect the disk-drive as a "slave" disk-drive in a desktop computer, and see if the disk-drive still works.
If it's dead, it's dead, unless you pay mega-dollars to a professional "Data Recovery Service" to rescue your files.
If it is dead, then buy another disk-drive that is compatible with that USB-to-disk-drive adapter, and reassemble the unit, and you'll have a brand-new external drive that you can use.
May 29, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Hi I have a Lacie External Harddrive 500gb, when I connect my hard drive to my computer it does not open, instead it gives me a message saying that " disk is not formatted"?
The disk was probably dropped or jolted. You can consider the drive bad now. The arm is broken inside. You can format the drive but most likely it won't work after that. Getting the data retrieved can cost up to $2500-$5000.
Nov 30, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Not recognised by computer
You gotta partition it first. http://windowshelp.microsoft.com/Windows/en-US/help/d9a4d35e-efdf-406c-a049-0860180129a71033.mspx
Except don't format the ones that already have a Letter (or u screwed urself there)
Sep 27, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Isn't receiving power. Ports seem "loose" in back.
Couple of things. Lacie power supplies are notorious for their failure rates. Don't buy a new one just phone lacie and they will send you a new one no questions asked (that's how bad they are!)
Second, the circuit boards in some are pretty poor and the FW sockets can actually break off.
I used to recommend lacie to my clients - but not any more.
Sep 10, 2009 | LaCie Big Disk Extreme 500 GB Hard Drive
Need manual for lacie desktop 500gb hard disk
http://www.lacie.com/support/index.htm?rid=10033
Aug 02, 2009 | LaCie Computers & Internet
XP doesn't recognize 500GB external Lacie after almost 2 years
try it on different usb ports on your system
try replacing the cable which connects the hard drive with the usb port
if this does not works the problem lies in the portable hard drive and i think it would be under warranty period so get it checked
Jul 09, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
