Question about Symantec Computers & Internet
Usb virus hello to you..ahm i have a problem about my usb flash drive i can't format it they have a file exist every 3sec.i format it then it appear again wat i nid to do to use it again without virus or i use it normally..???this is my email add..dice_aidrian@yahoo.com
  • 4 Answers
There are 2 posibilities:
1. It's probably that your computer has been infected by a virus, try to format your flash drive on another computer.
2. The file probably a software to autorun portable apps on your flash drive, such as U3. It's not a problem
Hope that helps :)
Posted on Nov 15, 2008
How to remove the virus from my mobile memory card?
Insert your USB drive in the appropriate USB slot in your computer. If the Autoplay dialog box appears, select "Take No Action" and click the "OK" button. Launch your anti-virus program, such as AVG Antivirus or Anti Malware. Select the USB drive for the program to scan. Click the "Start Scan" button or option. Open the scan history for the USB drive when the scan is complete to see a list of viruses and warnings identified by the antivirus software. If desired, select the options to "Heal All Infected Files" or "Move the Infected Files to the Virus Vault" to ensure these files are quarantined from your system. Highlight each infected file in the scan history. Write down the file name of each infected file identified on the USB drive. Minimize the application's window. Select "Run" from the Windows "Start" menu. In the Run window, type "e:/" at the command prompt to switch to your USB drive (or type the drive letter for your USB drive). Press the Enter key. Type "attrib -s -h -r -a *.*" at the command prompt to remove the system, hidden, read-only and archive file attributes. Press the Enter key. Type "del ####.+++" where "####" is the file name of the infected file and "+++" is the file extension, at the command prompt line. Press the Enter key. For example, "del terriblevirus.exe" will specifically delete the Terrible Virus executable file. Repeat for each infected file on your list identified in Step 4. Close the command prompt window; that is, exit the Run utility. Maximize the window for your anti-virus program (which is still open) and repeat Steps 2 to 7 until no virus is detected on your USB drive. Exit the anti-virus application.
or Click start click on my computer you should see your usb drive right click then select format. another way is to control panel administrative tools computer management disk management Right Click on your drive select format
Hope this helps
Jan 12, 2013 | PNY 4GB microSD High Capacity Mobile Media...
When file is copyied in pendrive ,file gets corrupted,so what can i do?
hi...
This is because the pen drive contiains viruses. scan the pen drive and computer with the proper antivirus.after scanning delete all the viruses from it.
Then if the viruses are not deleted from the pen drive please format the pen drive. you cn remove the viruses by formatting.
DONOT connect your pendrive with the computer having viruses in future or else again you wil get the same problem
Jul 18, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How 2 delete file autorun in my system without appearing in futur
When your computer automatically creates a "autorun.inf" or "autorun.exe" file on your pen drive, you have a virus. This is the way it multiplies itself in order to infect other computers. First, do a virus check and disinfection procedure on your computer (use a strong antivirus, like Kaspersky - they have 30-day free trial). After that, plug in the device, and now try to format it. It should work, if your computer is not too affected.
Feb 21, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Computer says destination is full but the flashdrive is empty. 7.46gb free. transfer of 4-6.5gb files
may be the pen drive is infected with virus Just backup the existing file of flash drive to another drive and format the flash drive and try to copy the files.
Have a nice day and do not forget to rate please...!
Feb 13, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I can't write files to my kingston 2gb usb flash drive.
Hello.
If you are getting a message that the disk is full, erase some of your existing files.
If there are no files on your flash drive, I'd suggest formatting your drive. If there are files, note that any existing files will be erased.
If your flash drive is drive "G" for example, enter "format g:" (no quotes).
Hope this helps.
Nov 07, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My w760a does not recognize my memory stick micro
it may be a problem of virus so check your card foe viruses, show all hidden files and folder if there existe a dublicate folder then your card is affected by virus so copy all files then format your card.
Oct 13, 2009 | SanDisk 1GB Memory Stick M2 Memory Card
I have a 8GB Kingston USB and I'm trying to copy an mpeg video file about 5GB into the USB, but it's not working. The message keeps saying the disk destination is full and insert another disk. The USB is...
Hello
I know this might sound dumb, but have you tried formatting the drive?
Something else you can try is to assign a new drive letter to the drive and this is how you do it.
Control panel
Computer management
Storage
Disc management
Then you must see your flash drive in the bar chart at the bottom
Right click on the flash drive
Change drive letter
The other thing might be that the file is corrupt. Try this, it should resolve your problem.
Please rate this
Best regards
Sep 25, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Pen drive does not open
Your pendrive is affected virus and do the format both pen drives and first cheak with your usb port also once and when you are pushing the pen drive in the pc should be smoth dont press just push some times light is appear but data cabe is not connected to pc
Jun 17, 2008 | Computers & Internet
Computers & Internet Logo
Top Symantec Computers & Internet Experts
Lisa
Lisa
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
