Question about Haier HDN655E Dehumidifier
No lights on control panel. Plug is powered.
My dehumidifier was running great. The tank was full. I removed and emptied it. When I stuck it back in, the control panel went dark and now it does nothing. The cord is plugged in to a powered recptacle. Is there a reset or something? Where might I find an owerns manual? Thank you.
  • Anonymous Apr 05, 2008
    I used my dehumidifer all last year now plug it in and nothing no lights no nothing?
Independent of the bucket switch, the control panel should light when the unit is plugged into a powered receptacle and the on/off switch is depressed. The problem is likely the 12 amp. fuse located inside of the unit.
Posted on Mar 25, 2008
    President:
  • 878 Answers
Trader, there was a service flash out on this model. The problem is that the bucket is not making the switch. The solution is to bend the end of the bucket switch with a pliers until it makes contact and starts. Date of the flash was June 2005. Should be an easy fix...Catriver..post back.
Posted on Sep 19, 2006
We have two Danby Premiere Dehumidifiers. Both have stopped picking up water. The filters are clean, the fans run and there is alot of moisture in the air? Any ideas on how to fix them?
I assume that you have already:
  • Emptied the water buckets.
  • Are sure the buckets are properly in place.
  • Are sure the bucket switches are not stuck in the full bucket position.
  • Cleaned the cooling coils.
  • Verified that the controls are set for a low humidity
  • Verified that there are no trouble lights or codes,
  • Know that the area to be dehumidified is well above freezing..
It sounds like they are both stuck in defrost mode or the compressors overheated and need to cool off. "Both" is a bothersome word. Both might imply a power surge that wiped out the controls. I would:
  1. Unplug them and let them cool off 36 hours.
  2. Check your manual for a control panel reset.
  3. Take off whatever covers I could, to let me touch the cooling coils to be sure they get cool.
  4. Plug in # one and reset the panel.
  5. Let it run and see if the coils get cold.
  6. Plug in # two and reset the panel.
  7. Let it run and see if the coils get cold.
And then decided what to do next. Hopefully the cool off and reset did it .
Good luckl.
Jun 07, 2015 | Danby DDR60A1GP 60 Pint Dehumidifier
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Aug 19, 2014 | Dehumidifiers
Power s on unit doesnt run no fan nothing
Mosr dehumidifiers have a switch that shuts the unit off when the water tank is full check this float to make sure it is not stuck in the off position also empty the tank if it is full.Hope this helps.
Dec 10, 2013 | Friedrich d70bp dehumidifier,70 pt.,115v
The bucket is empty, but when I plug it the full
I thnk your tank is askew. Adjust the osition of the tank until the light goes off ...
Oct 10, 2009 | Maytag M7DH65B2A Dehumidifier
My DeLonghi DEM10 wont power on any more - like fuse gone
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
Sep 03, 2009 | DeLonghi Dehumidifiers
I have 580.53509300. Was working fine until I
There is a float switch down there that shuts the machine down when the tank gets full, look to make sure it isn't stuck in the up position.
Aug 31, 2009 | Kenmore Dehumidifiers
FULL LIGHT FLASHES
An automatic overflow switch and Container “Full” indicator light are provided to turn the
dehumidifier off before the container overflows. When the indicator light on the control panel
glows, the water container must be emptied. If the light remains on and the dehumidifier does
not begin to operate make sure the float is attached to the water container.
When the condensate water container is full, the indicator lights up.
1. Turn the power off before removing container. Wait 3 minutes for
any remaining water to drain into the condensate container.
2. Tilt the container forward then lift carefully by the handle.
3. Empty and gently re-insert the container.
Important:This water is not suitable for drinking.
Please rate and god bless:)
Apr 24, 2009 | Fedders A7DH45B2A Dehumidifier
Newair ADS-300 Dehumidifier
Nov 12, 2008 | NewAir ADS-300 Dehumidifier
Haier HDN655E Dehumidifier Logo
360 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Bill Long
Jim Thurston
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
