Question about Toshiba e-Studio 161 Copier Copier
Toshiba e studio 166 like printer dont work
I want to connect e studio with my pc with usb ,i have install driver pc knows the printer like com1, the icon in printer and faxs dasent show,what can i do,pl halp me
  • 1 more comment
  • djjoska Dec 04, 2008
    Hello!
    I have the same problem. I connect the toshiba estudio 166 to Pc, on the USB port, it was recognise on the com3 port, but I can't print anithing. Whwn I send a file to print thel Data led on the printer is on for 10 seconds and thats all. Please help me. Mayme I need another driver? I use the original CD that come with the estudio166 an I have Windows Xp Pro. 32 bit.
    Thank you.
  • lisa_farhana May 16, 2009
    i can'nt print from network printer
  • Anonymous Mar 28, 2014
    Devo sostituire il kit manutenzione ma non so resettarlo
  • 849 Answers
Connect the copier to computer through USB cable, turn it on, then re-install software it will recongnize the port and machine itself.
Posted on Nov 03, 2008
    New Friend:
Here I would like to share features of toshiba printers:
1) user friendly, tilting, color, WVGA control panel is section 508 compliant with increased visibility
2) versatile paper handling options
3) department code enforcement
4) internet fax
5) trayless automatic duplexing unit. and many more.
Posted on May 07, 2014
I have a copier toshiba e studio 166. i want to connect it to the computer to use as a printer
locate the usb printer port at the side of the machine.If u have a driver cd then run and connect the machine to pc when asked for through usb printer cable.That's it.If you dont have the driver cd then go to toshiba website and download the same for your operating system specific.
Apr 19, 2012 | Toshiba Office Equipment & Supplies
To get the driver for e-studio 166
Toshiba e-Studio 166 drivers are available Toshiba Official Support
Click 'Support & Drivers'
Choose B/W Copiers
Choose e-Studio 166
Select the drivers
according to the operating system on your PC and download the drivers
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 20, 2011 | Toshiba e-STUDIO166 Printer
I want to install toshiba e studio 166 printer but I don't have driver so please assist me how can i install on xp os.
Choose B/W Copiers
Choose e-Studio 166
Select /
download the Full Installer
Direct Link for drivers download
CreativeTECH
Jul 06, 2011 | Toshiba e-STUDIO166 Printer
I want toshiba e-studio 206 driver for win 7 64-bit or any working solution
Toshiba e-studio 166/206 drivers are available Toshiba Official Support
Choose B/W Copiers
Choose e-Studio 166 (NOT 206)
Select the Complete drivers and download/ Install the required Drivers(
This package supports Windows 2000, XP, Server 2003, Vista, Server 2008, Windows 7 in 32 and 64 installations.)
You may also refer to the product manual
CreativeTECH
Jun 15, 2011 | Office Equipment & Supplies
I am having problem in taking printout from TOSHIBA E STUDIO 166
You are trying to print to paper size that is not installed in the machine. Check what paper is installed in the machine then set your software application default paper size to the same value and then print away!
Sep 10, 2009 | Toshiba e-Studio163 Copier
I don't know what port to use on my toshiba L300 to print from a e-studio 166 toshiba copier
Hello my friend,
Can you still rememeber the connector of your e-studio 166 toshiba copier? Usually the connector cable uses either parallel port the one who has like the picture below. you can find the port at the back of your Laptop then plug it 20b53e6.jpg or a USB connector the one with the flat head.
Also don't forget to install the driver of your printer.
Hope this solution i post will able to help solve your solution. If you need more assistance just reply to this post. Thanks.
Jul 09, 2009 | Toshiba Satellite Pro L300-EZ1501 Notebook
E-studio 163 coppier - I cannot connect it to pc
hi frnd do one thing
go to printers and faxes
select toshiba e-163,
right click
select properties
select port
select com 3
try to give print
OR
select com 4
and give print i may be ok.
pls up date me
regards
san
Aug 17, 2008 | Toshiba e-Studio163 Copier
USB port
Hi-
Make sure you are using a direct cable, not an adapter( usb to serial or vice versa) if you are using a serial cable, make sure your printer is the only one using the com1 port, this should be free...
check and go to command prompt- click on start then on RUN put in cmd then press enter, on black window type dir >com1 then press enter. it should print if its free. other wise go to device manager, delete com1 or uninstall then reboot computer so that it will reinstall the com1 driver back to computer.
keep me posted
Toshiba e studio 163 drivers for XP
Try looking here:
http://www.eid.toshiba.com.au/
You need to know if it uses the GDI print system or the optional print board.
Browse the driver section and you should get there.
Nov 12, 2007 | Toshiba e-Studio163 Copier
Toshiba e-Studio 161 Copier Copier Logo
1,849 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
