Question about IBM MicroPortable IL1210 Multimedia Projector
Color Red does not Display
The color red displays as "black" and there does not appear to be a way to adjust either the color or tint. Both color and tint are grayed out in the "display" menu. Other colors do not appear crisp while they are adequate. The lamp shows 185 hours on it but the projector was serviced about 18 months ago and I am not clear if the "lamp hours used" was reset at that time. My estimate is that there may be ~1200 hrs on the lamp if it is the original lamp. I had to purchase a lamp at $400 - $500 unless there is a high probability that the lamp is the issue. Any suggestions? Thanks in advance, Tom Moser
  • buhdda316 Aug 25, 2008
    I have the same issue too, anyone know what the problem is?
SOURCE: r52 onscreen display issues
What ya need to do is enable the "system utilities" this is software that administrates all ya settings like those ya talking about.. below is a link for ya drivers etc. perhaps it is still in Control Panel and it;s just been disabled somehow.. else DL and install them. www-307.ibm.com/pc/support/site.wss/MIGR-58931.html
Posted on Aug 17, 2007
Marrie
  • 563 Answers
SOURCE: CHANGING COLORS
Hi there
Try using a different cable .....should solve the problem
Posted on Apr 02, 2008
  • 230 Answers
SOURCE: double display with my IBM think pad T43
have you tried Function F7/F8 ?
Make sure that your display driver is installed correctly.
I had the same Laptop as you did and was able to have dual monitor.
Also check your Display driver in your control panel and make sure it set to dual monitor.
Posted on May 12, 2008
avsantos
SOURCE: color problem
Hi, it is more likely from an open green and/or blue picture tube's electron gun transistor driver.
If you have an experience on electronics / or use of solder gun, you can just open your monitor and look for the electronic board at the back of the picture tube. Take a look in all transistor ( components with three legs) and solder / check if their legs are not fully soldered to the board. Note: just be careful on the high voltage diode / line ( the one with a thick (like the car distribution wire cable) single wire going to the tube). good luck
Posted on Dec 19, 2008
chanddra2009
  • 615 Answers
SOURCE: Thinkpad R40e has no display
Dear Sir,
According to your post it seems to be a deffinately problem with RAM.Just Remove the below small panel where RAM is located (you can identify the panel at which where small curved indication showing RAM exisitance beneath that panel)Remove the RAM clean it twice and reinstall it in same place.Now turn on the laptop deffinately your laptop shows display. If it is not check with another RAM.This solution deffinately helps to solve your problem.If you have any query come back with more information.
good luck
Fixya Customer Support
Chandrashekahr
Posted on Jul 29, 2009
The image color on projection is not the same as shown in laptop. There's is no red color.
It could be a broken connection in the computer lead for the red signal, or a fault on the projector that the red panel doesn't work any more.
To diagnose, bring up the projector's on screen display. If there's white in the menus then the problem is the cable. Replace it with a new one. If the menus are affected too then it's a projector problem. This requires the attention of a service engionner.
Aug 20, 2014 | Toshiba Tdp-s25 1080i 720p Hd Dlp...
F31672et rca tv
Is this a projection/plasma/CRT?
Oct 03, 2008 | RCA F31672ET TV
Red Tint on Screen
This is normal and is a color calibration issue.
For correct color, NEVER use the "WARM" setting. Why? Too red. You cannot get REALISTIC or ACCURATE color using the "Warm" setting.
Since we are speaking of Samsung, first avoid the "Flesh Tone" adjustment. When things are set correctly there is no need for this adjustment. It is a quick fix and not for the "discerning eye".
1. First, access the "Color Temperature" menu. From here select "Cool2" or the coolest temperature setting.
Note: For Samsung use "Cool2", or if not available, "Cool1". Samsung has inadvertently increased calibration confusion by issueing TVs that have just "Cool1", and TVs that have both "Cool1" and "Cool2" :0[
For other brands, use "Cool", or "High", or "+6500k". Anything lower artificially reddens the picture and compromises detail.
2. Now return to the color settings and reduce "Color" to between 30 and 40 (on a 100 scale). The sweet spot is just near the place where the color rapidly washes out.
3. To round out the color palette, move to the "Tint" adjustment and ADD a couple (3-5) clicks to the GREEN.
Adding the touch of green is what is needed to take out the last bit of "pink" and will make all the tones and all colors display properly.
I hope this helps!
To further increase the quality of your picture visit
http://www.wowvision.tv/main.htm
Highdefjeff :0]
Jun 15, 2010 | Samsung LN46C630 TV
Viewsonic VP930b color problem - Red tint
Go to the setup menu on the LCD panel by pressing button 1 on the front. See if there is an option to reset the lcd to factory settings. Reset it and report if it helps not.
Jul 29, 2009 | ViewSonic VP930b 19" LCD Monitor
My display has a red tint to it
Try adjusting the color properties of the monitor using the controls located on the front of the monitor.
If you can't correct the color, then it's a problem in the color circuit. As an ex tv repair guy I can tell you it may cost more than the monitor is worth to fix it unless it's still under warranty.
Jul 13, 2009 | Dell Computers & Internet
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
Red picture toshiba model 50h71
try to turn down the screen control and see how the tv reacts.
Apr 10, 2008 | Toshiba 50H71 50" Rear Projection...
Sanyo Tv color problem
I would check the green signal all the wat to the display screen to determine is this is a signal problem or a system short. I would recommend that you take this set to a qualified electronics technician
Sep 10, 2007 | Sanyo DS27910 27" TV
A constant red tint problem (AV-56P787)
This is an indication that the red gun is being driven too hard. Have you tried to adjust the red color control? If not try this first and if the control can not adjust the color then you will have to find out if the control grid on the red tube is working and has the proper voltages present. Which you will need the following equipment to do. Multimeter Oscilloscope Along with these you will need a schematic to show you what the signals and voltages should be. And I might also suggest having a pattern generator and using the color bar signal since more then likely that is the one being used in the schematic as the reference signal.
Mar 11, 2007 | JVC AV-56P575 56" Rear Projection...
IBM MicroPortable IL1210 Multimedia Projector Logo
90 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
