Question about Gigabyte GA-K8NF-9 (890552602964) Motherboard
Location firewire input port
I cannot locate the firewire input port at rear of motherboard
There isn't one on the back panel. You must connect the USB/1394 bracket that's included with the board to an empty slot on the rear of the computer and hook up its connectors INSIDE the computer to the appropriate headers on the motherboard: the purple firewire connector would connect to the purple header (DUH!) on the RIGHT in the pic below, it's a DOUBLE firewire header and it's the only place this bracket will fit. The yellow USB connector would go to any open USB header on the board (guess what color...) Very simple, really.
Optionally if your computer case has a built-in firewire port on the FRONT panel, as most do nowadays, you can connect that to the appropriate header on the board using the already-installed cable that's connected to that front firewire port (connect this one to the purple header on the LEFT, it's just a SINGLE firewire port.)
However, this header's pins will NOT match up properly with almost all case's front-panel firewire connectors. You would most likely have to switch around 2 or 3 of the little wires that go into the connector so that it matches the motherboard's pin-out.
It's clearly labled in the manual for the board, and isn't really all that difficult to switch the wires around, but I would recommend just going with the first option and connect the included bracket to the back since it was designed to go with this board and requires no modification.
Posted on Dec 13, 2008
Need a wiring diagram for a rs780m03g1
http://www.ebay.com/itm/FOXCONN-RS780M03G1-8EKRS2HM0D-DDR2-HDMI-PCI-MOTHERBOARD-/250896178535
1) http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rnv.shtml
2) Product Views;
http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rtc.shtml
B - Processor Core Power Connector;
is the connector on the motherboard for the 4-pin ATX +12 Volt power cable.
Located close the motherboard top edge, left side. Yellowish 4-socket hole square connector.
General example of connector, and power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
2) D - CPU Fan Connector,
The Processor fan connector is white in color, 3-pin, and above the processor socket.
3) F - Main Power Connector,
The 24-pin ATX main power cable connector on the motherboard, is to the Right of the Ram Memory slots
4) N - Front Audio Connector, (Front Panel audio ports)
Red in color, 9-pin header, and is located below the white No.2 PCI slot, at the bottom of the motherboard.
5) P - System Fan Connector, (System Fan = Computer case fan)
White in color, 3-pin header, located below the No.2 PCI slot, at the bottom of the motherboard.
6) Q - IEEE 1394 Connector,
For the front panel Firewire (1394) ports.
Black in color, 9-pin header, located at the bottom right corner, of the white No.2 PCI slot
7) R - USB Connectors, ( Front Panel USB ports )
F_USB 1 through F_USB4.
Located at the bottom of the motherboard, and these four separate headers support TWO USB ports each. Yellow in color.
8) S - Front Panel Connector,
located at Bottom/Right corner of motherboard.
Pin 9 is N/C also.
Not Connected. Used for +5 Volt power for the factory.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 27, 2012 | Gateway E-4300 PC Desktop
I bought my camera used online. The DV cable input does not work. (Unfortunately I was not told about this problem.) I cannot pass the tape to my computer now because of the DV input problem. Does...
I recommend you, test the cable, the Firewire ports. test connection.
Plug the firewire into the camcorder BEFORE turning it on,
You must use a Firewire cable and FW ports (Firewire to Firewire) NOT USB port
Check the cable no bend.
1.- Try with other cable
2.- Try connect a different Firewire port on your PC (or connect to other PC)
3.- To test the FW port on your PC connecting other devices by example external hard drive
If the Hardrive work fine the problem is with your camcorder
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 21, 2011 | Panasonic DVX-100 Camcorder
How do I connect this to my t.v.
Locate the Input panel on the rear of the TV and find the "Composite In" or "Video In" ports. These are small, circular ports that yellow, red or white. Locate the "Output" panel on the rear of the DVD player and the "Composite Out" or "Video Out" ports. Hook the cables up accordingly.
Jul 10, 2011 | Toshiba Televison & Video
Can a GA7-VAX motherboard support a flat panel montior and firewire? Can I just add the two cards? What about broadband? Or do I need to upgrade the motherboard and CPU to allow functionality? Please...
Socket A motherboards aren't going to support any real impressive processors. I'd recommend upgrading anyway, but yes, you can just add a firewire card. I like Zonet, they are affordable reference boards. You can use a flat panel monitor either with a analog adapter, a monitor that actually has an analog input (Most acer displays currently available either have the option, or only support analog.)
May 08, 2011 | Computers & Internet
I want to connect to my PowerBook G4. Have the unit. Where is my firewire port?
On your Behringer Sound Sytem, the firewire port is at the back, the firewire ports are actually labeled. On the PowerBook G4, it is usually located right next to the ethernet port and it has like the Y symbol above it.
Jun 07, 2010 | Behringer F-CONTROL AUDIO FCA202 External...
FRONT AUDIO PORT
If you are familiar with electronic parts you can fix this with your own. Open you CPU casing and locate the wire connected to your front audio. At the end part of the wire from your front panel you need to plug the end part to your motherboard. You can see the audio port at the lower part to the motherboard. You can read there a label audio input so you plug at this port
Mar 30, 2010 | Mercury P4VM800M7 Motherboard
FoxConn 661MO3-G-6EL is suuposed to have 2 1394 Firewire ports installed, 1 in the rear panel and 1 accessible on the board from a front bus connector, but mine seems to be msssing these, whcih does not...
Return the motherboard to the place where you bought it, and have them explain the differences that you have observed.
Are there any wires running from the FireWire port on the front of your computer's case to any connector on your motherboard?
May 30, 2009 | Foxconn 661M03-G-6L P4 Socket 478/SiS...
Case front firewire port to motherboard connection???
Yeh dont plug it into a USB header...
yes if you buy a PCI firewire card they will have 1 or 2 headers on the card so you can fit your front Firewire port to it...
[Belkin cards 99% of the time have headers on the card]
Let me know...
Matt
Jan 22, 2009 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
Firewire cards
Why do you need to use another firewire card? The firewire port located on the right of the machine between the card reader and USB ports should work fine with most devices. I use mine frequently with a Sony Firewire camcorder and have never had a problem.
May 13, 2008 | HP Pavilion dv6000z Notebook
Gigabyte GA-K8NF-9 (890552602964) Motherboard Logo
1,130 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
