Question about Motorola Mobility RAZR V3
Help..formatting when i am typing message it eoll automatically stop..it was hang..help pls?
    Guru:
  • 167 Answers
Motorola problem' HAng In typing Msgs.
press menu
select setting
intial set up
master clear enter security code'
default is (000000)
after re-boot
same procedure
initial set up
master reset
enter security code again'
wait until tha phone re-boot
your phone is already formatted'
all media,phonebook entries, will be lost or deleted.
and make sure you are fully charged.
Posted on Nov 01, 2008
My 8gb kingston usb falsh automatically canged to skymedi and also not formated ,no copy , write protected error , plz help me wht to do ????
no need to worry friend first you need to active the usb port and then fix the pendrive to usb
follow bellow steps
---> ctrl+R
----> in this tyoe " cmd "
-----> in command prompt type usb drive name
examle : if drve is H then type like H:/ or F:/ etc
----> format H: or format F:
-----> if any question ask then u aswer yes press "Y"
----.> your problem is solve
in case failure then you can try this another operating system or another computer
Feb 22, 2011 | Kingston Technologies 512MB DataTraveler I...
My nokia 5300 i hanging lot. so i want to formate it..................pls help
go in the menu
then open settings
then go to the last option i.e "Rest. factory sett."
type in your security code and it will format your phone .
this will format everything but not your personal information such as contacts, language selection or calender notes
Jan 06, 2011 | Nokia 5300 Grey Cellular Phone
Hello my nokia 3110 mobile got hang and switched
my nokia 3110 mobile got hang and switched off automatically. to restore factory setting i put the code 12345 or 00000 but i shows code error. i think there is virus in my mobile. now i dont know the exact code to format my mobile. pls send me the procedure to format my my and give me the right code to format it. follwing is the information of nokia3110c: Email Id :- yogeshkumar5555@gmail.com
Aug 07, 2010 | Nokia 3110 Cellular Phone
Hang and restart
how to be format nokia 3110c
Jun 29, 2009 | Nokia 3110 Cellular Phone
How do you remove a recorded answering machine message
Settings:
In Settings dialog you can set the following options for Best Answering Machine:
* Greetings - allows setting up the greetings played on pick-up;
* Active in profiles - defines in which profiles the application will pick-up the phone and record messages;
* Storage - allows selecting on which disk the records will be saved;
* Pick up after - sets the time after which the call will be answered;
* Record time - maximum amount of time the message is being recorded;
* Format - message file format (amr,wav);
* Icon - configures the visibility of the icon displaying application activity and presence of new messages; depending on this parameter, can be shown in standby screen only (Phone application) or in any application;
* Play volume - play volume for the greeting;
* Records lifetime - automatically removes old messages;
In this view you can listen to new and old messages, delete unnecessary messages, send the recorded messages and call the person directly from this view.
During the call:
When Answering Machine is processing an incoming call, you will see a dialog showing the application's progress with the ability to stop it:
* Answer - when this command is chosen during a call, it stops greeting playback or message record and you can continue talking to the caller;
* Hang up - stops greeting playback or message recording and terminates the call; hope this will be helpful...
Jun 23, 2009 | Nokia Cell Phones
System error
it generally hangs when u install new new softwares in it, which is sometimes not compatable with ur mobile platform.
now what u have to do is u have to format ur phone to factory settings that is the only way which is to be done in regard to make ue phone run smooth
sometime when u talk for long hours on ur cell fone , it gets heat up and ur call get automatically disconnected.
u have to reset it which is sometimes dangerous to ur cell phone, it might cause some harm to it.
There r two ways to format ur Cell Phone
1. Soft Core Format
2. Hard Core Format
1. In Soft Core Format u have to dial *#7370#    or   dial  *#7780#     this will format ur phone memory and u have to manually format ur memory card
2. In Hard Core Format ur mobile gets formatted as a tough format,     u have to keep on pressing the three buttons simultaneously(at the same time) for a long period unless u get a screen on ur phone when it asks for the region(ur country).
what u have to do:
1. switch OFF ur mobile
2. u have to press three keys at a time
    Call Button (green key) + * key + 3  at the same time
3. now dont get ur fingers off those buttons , ask someone to switch ur mobile ON (if possible make       ur cell phone placed on some table for stability) (please dont move ur fingers off those three keys       unless u get the screen where u r asked for ur region)
once u got that screen ur cell phone is formatted
NOTE: Formatting the phone with HARD CORE FORMAT METHOD may be harmful if not done in the correct way
Pls Vote for me if this solution works for u
Thank You
Vinay Ramani
India
Sep 02, 2008 | Nokia N73 Cellular Phone
Pls help with template problem
when you go "new message" in the messages menu it should give you an option of text message as well as multimedia message and other things. If the problem is when replying to messages it should automatically send in text format and if it doesn't then it should once you have sent some "text" messages from the "new message" option. Hope this helps :-)
Nov 05, 2007 | Motorola Mobility RAZR V3
Run slow
format it by removing memory card and pressing calling+3+star button until appear ((formating))
Jan 15, 2007 | Nokia 6600
Motorola Mobility RAZR V3 Logo
73 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
