Question about Cisco ASA 5510 Anti-X Edition (ASA5510CSC20K9) Firewall
CIsco ASA 5510 fire wall problem
My 6 client PCs are getting the data from one server through this ASA 5510 firewall. Now i am facing the problem as clients are not failed to connect to get the data. once if i powered off and then power on the fire wall, clients are starting to ge the data, but it last for few minutes. then again same problem. There is no problem with the ethernet cable connecting Firewall output and switch. Could you please suggest some solutions?
    Problem Solver:
  • 7 Answers
Hi Thangaraj_j,
Can you provide the topology of your setup? Can you provide also the following:
- running configuration of the ASA
- ip address of the server (what kind of server is this? what tcp/udp port does it use)
- show xlate
- show con
- show log
Just a quick try, have you tried clearing the translation and the arp table?
commands to do it:
clear xlate
clear arp
clear local
Let me know and if it still doesn't work, try to ping the server from the pc clients and see if ping does work. (you need to allow icmp to pass thru in case you are denying it for testing purposes) Just send me the additional information given above.
Posted on Nov 22, 2008
How can i get into ASA 5510 after lost password
Its simple, you have reboot with console connect, get into to ROM mode and change configuration registry so it will not load the saved configuration. Please refer Resetting the passwords on Cisco ASA 5510 Binary Royale Ltd for the step by step process
Mar 21, 2013 | Cisco ASA 5510 Firewall
How to export log from CISCOASA?like other cisco device logging i want similar kind command in CISCO ASA
ASA's log is usualy stored localy on ASA itself, so easiest way to export that log is to go with telnet/ssh/console on it, do a command : show logging and copy/paste output into a new file.
but beware - this log is really short and as soon as ASA is rebooted - it's gone.
you could set asa to log to a syslog server (free on linux/freebsd or for windows use KIWI app).
that way all ASA log output is stored on pc/server running your syslog server.
Jan 03, 2011 | Cisco ASA 5510 Firewall
I have cisco asa 5510 firewall and i have dialup internet connection i want my asa 5510 between my LAN and my dial up internet
Your best bet is to place the ASA into 'transparent' mode, and letting the traffic pass through it and be inspected on the way through.
To do this you need to first do the following command:
firewall transparent
Once in transparent mode, the firewall will no longer look like a hop in the packets journey, and you can set rules to allow/disallow traffic using access lists on the inside and outside interfaces, plus you can perform packet inspections using policy-map and inspects.
Hope that helps!
Feb 12, 2010 | Cisco ASA 5510 Firewall
Block websites on cisco asa 5510.
All websites or specific ones?
If you want to block all web traffic, a straightforward rule preventing HTTP traffic (TCP port 80) as well as HTTPS (port 443) will block any and all web access.
If you just want to block specific sites, I'd recommend an access control list (ACL) configured to deny traffic to those specific site's IP addresses.
Feb 10, 2010 | Cisco ASA 5510 Firewall
New cisco asa 5510 setup
connect your laptop to the asa5510 using a cross over cable
Oct 07, 2009 | Cisco ASA 5510 Firewall
Restart Cisco Asa 5510
Yes. The firewall will restart. Just be sure to save your running config to memory before turning off. For that you must issue the command: write memory.
Best Regards,
Apr 18, 2009 | Cisco ASA 5510 Firewall
Installation of cisco asa 5510 firewall
Hello kuniksh,
Look at the below link for all configurations
Do rate this solution!!!!
Mar 21, 2009 | Cisco ASA 5510 Firewall
Export and import all configuration in Cisco ASA 5510
Hello ,
the Steps which u want to export and import configuration in Cisco ASA5510
1- connect yourself to your Cisco gateway by IP
2- Get TFTP server to your PC like( solarwind , Tftp server , ... ) any tftp download and upload program
3- now u need to copy running configuration to your pc by order
#copy run tftp , then follow the steps
NOTE: u should be in the same network or u need your pc and cisco box both have publick IP
4- if u want to put prepair config files to your gateway , you will need to type order
#copy tftp run , then foloow the steps
If u need anything else please let us know by leave your completely request or join us with
Dec 17, 2008 | Cisco ASA 5510 Firewall
Upgrade firmware on a cisco ASA 5500 firewall
This is for the pixes, I haven't upgraded an asa yet...should be close or the same
* find latest version of code, these are usually *.bin files located on
* confirm the flash and RAM requirements of the PIX OS software versus what the PIX has (”sho ver”)
* make sure you have a backup of the old PIX OS and PDM to the tftp server (or at least confirm the software is there)
Note: You cannot back them up from the PIX, so you will need to download them and put them on the tftp server * put in a change control form
* once change controls confirms date/time do the upgrade:
wri mem*** only if you save your configs via tftp wri net conf t ca save all copy tftp://your tftp server ip/pix635.bin flash:imageskip this if you don't use pdm copy tftp://your tftp server ip/pdm-304.bin flash:pdm *** if this is a failover pair, upgrade the other pair reboot
Sep 06, 2007 | Cisco ASA 5500 Firewall
If you can't get the manament working initially I suggest the following
Setup a console connection
Type "enable" and press enter to access priveleged exec mode on the ASA
Type "config terminal" and press enter to access configuration mode
Type "configure factory-default" and press enter to load default settings.
Assign a static IP to your PC of and try to browse to (PC is plugged into management interface)
You should be prompted to begin using ASDM
Jul 30, 2007 | Cisco ASA 5510 Firewall
Cisco ASA 5510 Anti-X Edition (ASA5510CSC20K9) Firewall Logo
909 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
