Question about Philips DVDR3380/05 DVD Recorder
3370 H player is 'blocked' cannot eject disk
We inserted new disk and tried to play but,display read 'blocked' also cannot eject disk, have tried switching power supply on/off no luck
  • Bowzarky Jan 01, 2009
    I have the Model 3455H and it has the very same problem! I just keep hitting the eject button and it eventually does eject. I really think that the DVD tray needs lubricating underneath/inside and is hanging because it is dry?
  • sergiun_ska Jan 12, 2009
    on DVDR3380
    "Blocked" on display...
    i cannot eject
En la parte inferior del aparato hay una ranura alargada. hay que mover el switc e inmediatamente se desbloquea.
araceli
Posted on Mar 28, 2009
  • 4 Answers
Hi there, try tapping it lightly with your hand just above the tray and then press eject button!! It works everytime with my one!! Hope this helps!!
Posted on Jan 31, 2009
@Hello - whenever I try to insert a disk to play it starts reading it (display reads READ...READ and then it stops and displays HO7 and won't play the disk at all. I've had the unit a few years but have...
H07 is a common error code for Panasonic DVD players. It means the traverse unit (spindle motor/laser assembly contained in one block) has failed. Usually it is the spindle motor part of this unit which fails first, (i.e. it doesn't spin the disc at all) causing the problem, but sometimes the laser can also fail as well. Because the motor and laser are contained in one device block, the whole part has to be changed, and this can only be done by an authorised service centre. The only trouble with that is the cost. Many DVD drives experience this (different brands giving different error codes) so it's not just confined to Panasonic.
There are only 2 ways to go here; either be prepared to spend a fortune in a workshop service to have the traverse block replaced/aligned (which would include a brand new laser), or simply buy a new player - which would give you a new remote AND an optional extended warranty if available; this would be considerably cheaper than repairing the old one.
Don't be put off from owning Panasonic - they are generally good products.
Feb 24, 2011 | Panasonic DVD-RV32 DVD Player
When I insert a dvd the player tries to read the disk and then comes back and displays no disk
try playing a disc that you know it has played before. if it does play other dvds then your problen is that it cant read the format in wic dat specific disc u are inserting in there. if it doesnt ready any dvds then insert a music disc in there, if it does play it then u got to change the lens. there is also the possibility then the motor spinning the disc might have gone bad as well so when changing the lens, it is advisable to change the whole lens mechanism.
Aug 23, 2010 | LG BD370 BLU RAY PLAYER
Have the Samsung DVD-AR650. When I insert a blank
My last recommendation, before seeking a replace or repair; would be to run a cleaner disk. Optical drives can be affected by dust on the optical block lens or dust on the disk itself. Sometimes a dirty lens can even cause your drive to eject the disk when you try to read it. It is recommended you clean your lens every 3 months in an office environment, or once a month if you use the drive in an industrial environment. They range in price from $3 to as high as $130. In such an
Jan 01, 2010 | Samsung DVD-AR650
The eject motor drive may be weak. I find that lubrication does not solve the problem.
Oct 16, 2017 | Televison & Video
Dvd disk won't eject???
this is device do not play dvd-video, onli dvd-rom with maps for gps-navigation.
Apr 28, 2008 | Eclipse AVN5495 Car DVD Player
Playing recordable dvd
My Emerson won't play anything except DVD Movies, never has, wasn't suppose too. Make your movies in DVD Video format and it will read them fine (unless it's broke). I make movies all the time and play them back in mine. It reads DVD-R, DVD+R, and in duel layered. It will not read RW disks!
Man I've every problem you can imagine with DVD Players. I've found when the disk gets stuck, as long as it's not jammed. You can turn the unit off or unplug it. Plug it back in but DON'T TURN IT ON! Instead hit the eject button and the drive should open the drive without trying to read the disk.
Feb 24, 2008 | Emerson EWD7003 DVD Player
Philips DVDR3380/05 DVD Recorder Logo
541 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
