Question about SanDisk SDMX1 MP3 Player
Won't start up
Ok when i press the on button it shows the hour glass thing and then it says SANDISK 512mb welcome! but it stays like that and i can't acces my music and the only way i can turn it off is to take the battery out. help please!!!
Not the same problem but close: when starting the player states "low battery don´t booting" and shut down. USB connection still ok.
the solution is about the same as written before here:
- erase all files by computer connection.
- make sure you have a ful baterry on the player.
- on the first try after this is still said the same thing. Trying again (holding for a little while the start button) the player recovers for this error.
Posted on Mar 26, 2009
I had that today. Seemed to have some corrupt files on it. My solution was to attach the unit to a PC's USB port, find it as a drive in Windows Explorer, then right-click the drive and select format. Obviously it erases everything but works fine afterwards. klaasbil
Posted on Feb 19, 2007
Ge hour glass screen
Press f8 on start up, enter safe mode
click start or on round circle with windows logo
type msconfig in field at bottom of box that just opened
hit enter
click on the "start up tab"
uncheck all boxes
click apply
click save
press ok to reboot
reboot computer
click "ok" for pop message.
Still hour glass?
Dec 20, 2013 | Acer Computers & Internet
Water won't drain
Do the diagnostic test:
SHU 53 MODELS
To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show “88′ when REGULAR WASH button is pressed and “8h” when Delay Start button is pressed.
To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4).
0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault
1 = Aqua Sensor (“Sensotronic”) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), display will show fault code “4′ and unit will continually fill and drain where testing won’t be completed. If flow switch (e5) has failed (opened), display will show “0′, water won’t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code “8′ immediately and testing will end shortly after water has started circulating.
The dishwasher not draining is most probably faulty drain pump or drain hose is got bit loose.It has to be checked and confirmed
.You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 27, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
Hour glass show... as like a hang status.. plz help me...
Is it detected in itunes? You're supposed to press menu & ok button only after the following steps- 1.turn off your ipod if its on. 2.slide the hold button on and off a couple of times and then when hold is in off position,press and hold centre and menu buttons till a silver apple appears on screen.then connect to itunes and restore.
Sep 02, 2009 | Apple iPod nano
The dishwasher has been running for 3 hours and seems to be stuck on 1 minute left. Upon opening, there was sudsy water remaining in the bottom, but the dishes looked clean. The washer just won't go to...
SHU 53 MODELS To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button. To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show ?88″ when REGULAR WASH button is pressed and ?8h? when Delay Start button is pressed. To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4). 0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor (?Sensotronic?) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test) To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty. If water level switch (f1) has failed (opened), display will show fault code ?4″ and unit will continually fill and drain where testing won?t be completed. If flow switch (e5) has failed (opened), display will show ?0″, water won?t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code ?8″ immediately and testing will end shortly after water has started circulating.
Aug 01, 2009 | Bosch SHU5315UC Dishwasher
The screen of my mp3 is always showing a hour glass it doesnt procced to menu it just stuck to the hour glass. help what should do?
If you have an iPod, Press the Menu and Center buttons until the ipod reboots..it should be ok.
If it is not, repeat the above and when you see the apple come up, switch your fingers the the center and play/pause buttons. this will put it in disk mode.
hook it up to itunes and restore it.
May 25, 2009 | Audio Players & Recorders
MP3\MP4
I just leave it until my battery runs out, then I charge it again. So far thats the only thing I can do about it.
Oct 27, 2007 | SanDisk Sansa e250 MP3 Player
Problem
Maybe cause by a corrupt boot loader in the device, upgrading the firmware will help resolve this issue. Perform Recovery mode on the player. Enable Hold Switch + Press and hold record button + Press And hold menu or power button until it says on the screen welcome to recovery mode. Then download the sansa firmware updater on your computer and perform the update.
Oct 13, 2007 | SanDisk Sansa e250 MP3 Player
I need to disable my ovens auto shut off
The control is automatically set to turn off the oven after 12 hours baking or 3 hours broiling should you forget and leave the oven on. If you want to remvoe this feature do the following steps: 1. Press and hold, at the same time, the BAKE and BROIL buttons for 3 seconds, until the display shows "SF". 2. Press the DELAY START TIME button. The display shows "12Shdn" for 12 hour shut off. Press the DELAY START TIME button again. The display will show "no Shdn" for no shut off. 3. Press the START button.
May 21, 2007 | Kenmore 33464 / 33465 / 33469 Gas Single...
Mp3 player 512mb wont open all the way
try re-intsalling the progam disk that came with it, than format the whole mp3 player & it should work
Jan 02, 2007 | SanDisk SDMX1 MP3 Player
SanDisk SDMX1 MP3 Player Logo
251 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
