Question about HP Office Equipment & Supplies
HP Photosmart C4400 I connect power cord and adaptor and Press ON THERE ARE NO HELPFUL MESSAGES. NO PROMPT but I choose English and press OK NO PROMPT TO INSTALL CARTRIDGES
My Photosmart C4400 series prints from the computer and also from paper copies in very small type. How do I enlarge the type?
Posted on Jun 12, 2009
How can I change the language from Japanese to English on my HP C4400 printer?
Follow these steps to resolve the issue.
  1. Unplug the power cord from the back of the product.
  2. Press and hold the Cancel and Color Copy buttons simultaneously on the control panel.
  3. While still pressing the buttons, reconnect the power cord to the back of the product.
  4. Continue pressing the buttons until the display goes blank or Reset shows on the control panel display.
  5. If the product automatically turns off, turn it on.
  6. When prompted, select the correct language and country/region, and then press the OK button. Press the OK button again to confirm the selection.
http://h10032.www1.hp.com/ctg/Manual/c01416570
Dec 22, 2016 | HP Office Equipment & Supplies
Reset factory settings
Hi Harold,
Here is how to reset the HP Photosmart 8250:
Performing a full reset
1. Press the Power button ( ) to turn on the product.
2. With the product turned on, disconnect the power cord from back of the product.
3. Disconnect the power cord from the wall outlet.
4. Wait at least 15 seconds.
5. Connect the power cord into wall outlet.
6. Connect the power cord to the back of the product.
If the product does not turn on by itself, press Power button ( ) to turn it on.
Try to print.
Regards,
Sean
May 28, 2013 | HP - HP Photosmart 8250 printer
I have a HP photosmart c4280 printer. I need to reset the language to english because it is in spanish and I do not have a manual.
The manual can be found at http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&lc=en&dlc=en&document=&product=3192753
Apr 16, 2011 | HP Photosmart C4280 Aio Printer
Tried to fix a paper jam and now I get this code C2FE0100 and the printer won't print. Unplugged it and still nothing
Found this link to reset an HP Printer:
http://www.out-of-warranty.com/how-to-reset-hewlett-packard-hp-all-in-one-printers/
Good Luck!
Mar 01, 2011 | Office Equipment & Supplies
Align to align your new print cartridge ? problem ?? hp officejet 4212 All-İn-One .
after the printer has printed the alignment shoot, Place is face up on the document feeder and press OK button,
If this does not work, Disconnect power cord from printer ( while printer has power ) and Press and hold # and 6 button and connect the cord back.
Follow the process to align the printer
2nd Solution Is :
Press Menu ( setup ) button on printer
Scroll to Tools ( press ok )
Choose Align Printer/Cartridge ( press ok)
Jun 18, 2010 | HP OfficeJet 4255 All-In-One InkJet...
Photosmart 7360-ink Ink System Failure error
1) Press * and # at the same time
2) Press 1, 2, 3 and “support R0632M” should display
3) Press > and “information menu” should display
4) Press > and “configuration menu” should display
5) Press OK and “hardware failure status” should display
6) Press OK “failure status: clear”. Press OK to clear
7) Press CANCEL
8) Press CANCEL
9) Press CANCEL
10) Turn printer off, unplug power cord for 2 minutes, and plug cord back in then turn printer back on.
And Thanks.
Mar 11, 2010 | Office Equipment & Supplies
0xc18a1002 error message on HP Photosmart C-7180 Printer
Resetting HP Photosmart C6180 & C7180 "system failure" errors:
(might work on other similar models as well)
1) press * and # at the same time
2) press 1, 2, 3 and “support R0632M” should display
3) press > and “information menu” should display
4) press > and “configuration menu” should display
5) press OK and “hardware failure status” should display
6) press OK “failure status: clear”. Press OK to clear
7) press CANCEL
8) press CANCEL
9) press CANCEL
10) turn printer off, unplug power cord for 2 minutes, plug cord back in then turn printer back on.
Feb 03, 2010 | HP Photosmart C7180 All-In-One InkJet...
My HP photosmart C4200 all in one won't print anymore. The button option for 'printer' just says scan. I cannot find the alignment page...is that the reason. What can I do?. We were able to print a photo...
For products with keypads on the control panel:
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold “# and 6′ keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
For Box-type models:
1. Unplug the power cord from the printer.
2. Wait for 30 seconds.
3. Plug the power cable back in the printer and turn it on.
Jan 21, 2010 | HP Photosmart 2610 All-In-One InkJet...
HOW DO DELETE FOUND NEW HARDWARE WIZARD
OK I had theHP PHOTOSMART C4400 any error code problem and here is the conversation I had with the tech...
James Cowan: HP error code 0xc18a0001
Earnest: I will assist you in this regard. I understand that a error code with 0xc18a0001 with "Ink System failure" is displayed on the front panel of the All-In-One printer. Am I correct?
James Cowan: Correct
Earnest: May I have the model number of All-In-One you are using?
James Cowan: c6250
Earnest: Please let me know the room temperature in which printer is replaced
James Cowan: 67 degrees F
Earnest:: OK. Please perform the below steps on the front panel of the printer to resolve the issue
James Cowan: OK
Earnest:: Press and hold the "left arrow" key. Press the "Setup" key and release both keys, display should say "Enter Special Key Combo". Press and release the "OK" button
Earnest: Please ignore the above steps
James Cowan: OK yes nothing seemed to do anything
Earnest: Please perform the below steps on the front panel of the printer. Press and Hold the "Print Photos" & "Red Eye Removal" buttons. Release both buttons. Display should say"Enter Special Key Combo". Press and release in sequence"Red Eye Removal", "Print Photos", "Red Eye Removal"
Earnest: Display should say "Support" and display the FW rev (something like R0616R)
James Cowan: COxxFN0723BR
Earnest: OK. Press and release the right arrow button until the display says "System Configuration Menu"
James Cowan: OK
Earnest: Press and release the "OK" button
James Cowan: OK and it says hardware failure status
Earnest: Display should say "Hardware failure status: Clear. Press OK to clear". Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue". Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. Please do not try to print at this stage
James Cowan: OK
Earnest: Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Let me know once you are done with the above steps
James Cowan: OK its unplugged
Earnest: Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message "Use POWER button to shutdown the printer" followed by "Press OK to continue". Press OK
James Cowan: OK
Earnest: Let me know the message displaying on the front panel of the printer
James Cowan: printer preparation occuring - do not interrupt
Earnest: OK
James Cowan: OK its done
Earnest: Let us print a self test page from the printer now
James Cowan: OK deal
Earnest: 1) Load letter, A4, or legal unused plain, white paper into the input tray
2) Make sure that the printer is on and loaded with unused plain, white paper
3) Press Setup. The Setup menu appears
4) Press the down arrow button to select Tools and then press OK
5) Press the down arrow button to select Self-test Report , and press OK. The self-test report prints
James Cowan: OK printing
Earnest: OK, please check whether all the colors pritned perfectly on the test page
James Cowan: Perfect
Earnest: Great... Cheers!!!
James Cowan: Thank you very much
Earnest: Now you can continue using the printer.
Mar 20, 2009 | HP Office Equipment & Supplies
213 people viewed this question
Ben Johnson
