Question about Samsung Televison & Video
Samsung-falt tv Hi,recently i bought this Samsung flat tv,(normal CRT) and picture is slightly distorted in Bottom right corner, espicially horizontal scrolling text in news channels make it very visible. is it repairable? Joseph Manickaraj,Tamil nadu,INDIA
  • 308 Answers
SOURCE: Can't see scrolling text or sport scores
If the set is still in warranty I would get a shop to fix this. If not and the set is over 5 years old and had a good picture in the past, I would suspect failing capacitors in the vertical circuit. On older sets, you could adjust this out with controls located on the main circuit board. With these newer sets, you would have to adjust it via service menus using both the remote control as well as the video button on the TV itself. For instance, on a model PF2720 which has a CH-16CD chassis (may or may not be the same as yours) you would have to first decrease the volume to zero then press both the mute button on the remote control and the video button on the TV at the same time to get into the service menu then by using the menu select buttons on the remote control go down to where the symbols S2 VAM comes up, and that setting when adjusted would vary the vertical height of the picture. It might also be necessary to adjust the VSH to shift the vertical up or down so there are no lines at the top of the screen and you could still read the bottom. When finished, you would have to press the timer(?) button on the remote the key that looks like an apple with a stick in the center to get out of the service menu. Note that if you try this, do not tamper with any other adjustments, or you may never get the set back to normal again. Since I do not have the instructions for your particular set, you may not even be able to get to these adjustments by using this method. If you have a TV shop nearby, they may be able to do this for a nominal charge as they would not have to take the back off the set to adjust it. If you do decide to do this procedure, write down the values before changing them in case you have to back track to where they were.
Posted on Dec 09, 2006
  • 136 Answers
SOURCE: Picture size won't fit screen. Can't see scrolling text at bottom (e.g. sports scores on ESPN)
hi there,
its probably not the tv but the set top box you need to fix. go to the settings and select the mode you want ie. widescreen 16:9 etc
then go to the tv and select the full mode or widescreen mode at 16:9
that should solve your problem. it takes some time to find the combination between the set top box and the tv to get it right
good luck
Posted on Dec 31, 2007
  • 211 Answers
SOURCE: White lines & inverted picture at top of CRT TV image
This problem is normally the Vertical filter capacitors. You need to have them changed before it burns out the Vertical Chip.
Good Luck
NC Electronic
Mills Wyoming
Posted on Jan 07, 2008
SOURCE: Samsung Flat screen 100hz tv - no power
My samsung flat screen tv have sound coming out but no display...anyway to check/help...
Posted on Aug 11, 2008
  • 5 Answers
SOURCE: rolling horizontal lines on the display of my plasma tv
if u r connected to an ant. it is due to poor signals from the ant so get a booster or amplifier for the ant.
Posted on Mar 05, 2009
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET > Forums > Samsung
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET -
Jun 10, 2015
More results from
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
Sep 2, 2014 - Uploaded by
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
My led samsung tv has a horizontal line and the upper right corner shows a white vertical lines
Not good. You may have a tab failure. A repair shop may be able to diagnose and repair this, but most likely the lcd panel is broken. The panel is the most expensive part of flat tv's. A new panel will cost more than a used tv.
Feb 02, 2015 | Samsung Televison & Video
3 Horizontal lines distorting picture
When you say "distort the picture", are you referring to dark image? double picture
Jan 20, 2013 | Samsung Touch of Color LN52A650 52 in. LCD...
Samsung 50in Plasma tv picture issues.
buffer board needs replaced need to replace both
Feb 04, 2010 | Samsung PN-50A450P Plasma TV
Samsung DLP 56" tv,distorted picture
if you say that your picture gets distorted you mean like it moves to a side? do you see a black middle block?
if it's a yes?
so its probably the light engine. you need to change it!
try this link..
the price is more or less depends on your TV model... $279.00
Feb 02, 2010 | Samsung DLP HL-P5663W 56" TV
32" Samsung TV, No Power or Sound, power LED on, flashes 3 times
Most likely the set has lost vertical sweep or the feedback from that circuit. This will shut the set down to prevent a horizontal line from burning the face of the CRT. This will have to be looked at by a technician.
Sep 11, 2009 | Samsung LN32A330 32 in. LCD TV
Half screen showing
keep tv off.
it will only get wors
if sumon dosent work on it soon
the problem you are having in the vertical section of the tv
hav a repairman resolider all conection on the vertical IC and check the serounding componets for falts.
regards daniel.
PS the repair takes me about 15 min.
Jan 13, 2009 | Samsung TXG2746 27" TV
Horizontal lines across the top 3 inches of picture
what line started? from Left to right? or from top to bottom?
Nov 28, 2008 | Philips 32PT6441/37 32" TV
Durabrand 21" tv picture distorted
To properly diagnose this problem,access to the servicer menu will be important.Also,the service literature for the horizontal and vertical circuits may be needed.Contact a tech who can help you that is familiar with Durabrand.
Sep 25, 2007 | Durabrand DU1901 TV
Televison & Video Logo
37 people viewed this question
Jerry Greenberg
Jerry Greenberg
