Question about Krups Small Appliances Espresso Machine
Krups xp 7240 cofee machine says error code 06
  • 1 more comment
  • pasin2 Nov 10, 2008
    error code no. 1.....
    please help...
  • Anonymous Nov 25, 2008
    I have error code 6 too.
  • eduma2g Mar 13, 2009
    am getting an error code 06. How can i get over it?
for the error code 06. (this is what I got from a guy on a tech support line)
The issue is with the waterfilter. If you haven't changed it for a long time - change it. If you recently got a new one follow these steps:
- take the filter out
- unplug the machine from electricity
- plug it back in
- install filter (go into prog- service- install new filter)
It should remove the error. Haven't tested that yet, but that's what I got :)
Good luck
Posted on Apr 27, 2009
    Problem Solver:
  • 14 Answers
6
Pump in actuator down phase
The flow has not dropped (> 50ml/min)
after the actuator has been filled to the
maximum (80ml); there is a water
leakage and the actuator does not fill
Look for the leakage source:
hoses, actuator, priming valve?
Switch or distributor switch
control fault: incorrect detection
of cams  error in distributor
position in cylinder descent
phase.
Flowmeter hoses changed over
Distributor problem (leakage at
drain ..)
Faulty connection between the
2 picto boards
If no leak detected, replace
power board V26 with V29
Posted on Jul 07, 2009
Error code 06 on Krups xpt 7240
Look for and remedy any internal leaks. If error 6 remains then expect to replace the distributor assembly.
Aug 20, 2014 | Krups XP Coffee Makers & Espresso Machines
Hello.place for information for KRUPS XP 7240 -ERROR CODE 5
http://www.getvn.com/333/link/Krups+Xp+7240+Service+Manual.html
Nov 10, 2010 | Heating & Cooling
I have a problem with my Krups XP7240, it is
You can just removed the water tank filter (the cylinder inside the water tank) and washed it up. (Actually the filter should probably be replaced). Fix it back in the water tank and tide it safety upon the exit ring.
Don't forget to unplug the machine BEFORE doing this.
Next, restart the machine and let it perform the automatic self testing.
May 10, 2010 | Krups Small Appliances Espresso Machine
Krups XP7200 series date problem
It seems that the dial knob and the electronic opto coupler don't work anu more. You can replace the digital panel by try to find a broken machine on ebay. Unless you are an electronics engineer like me (you can try to replace the optocoupler). See the post on leaking xp7240 for opening up the machine... it's tricky but easy.
Apr 14, 2010 | Krups XP7230 Compact Super Automatic...
Error code 07 on my Krups XP 7220 coffee machine
Error code 07 on my Krups XP 7220 coffee machine what to do? Nick
Oct 26, 2009 | Krups Small Appliances Espresso Machine
Error code 06 on a Krup XP7245
remove calk-filter in watercontainer..
Jun 28, 2009 | Krups XP7230 Compact Super Automatic...
Error code 06
The error 06 happens because one of the services – Rinsing, Cleaning, Descaling or Replace Water Filter is out of date.
Start in a sequence and go through ALL services. Go to “Machine Information” in “Programme” Mode to ensure that “Last” reads zero or a maximum of something below 10 and your machine will NO longer give start up problem. Please report it if this still occurs, because a computer reset can be done.
Mar 13, 2009 | Krups Small Appliances Espresso Machine
I need a manual for krups xp 7240, krups xp 7200, krups xp 7230
I have the manual, send an email to me at inouside@hotmail.com and I will reply to you with the manual in pdf format.
Mar 04, 2009 | Krups XP7230 Compact Super Automatic...
Krups XP-7220 Error code 01
Go to krupsusa.com and click on "instructions" they should have the manual to download.
Jan 02, 2009 | Krups Orchestro Dialog FNF2 Espresso...
Krups xp7420 espresseria automatic
am o proare 01 la un espesor krups 7220/7240
May 11, 2008 | Krups Coffee Makers & Espresso Machines
Krups Small Appliances Espresso Machine Logo
3,889 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
