Unlock code for Phillips Dvp3200v, DVD player
Hi
can anyone please help me to get my DVD Player from Phillips region free.
Its a DVP3200v, please please please
2 Suggested Answers
jaffa012001
  • 376 Answers
SOURCE: Hi i need to find
1. Open the DVD cover
2. Press setup
3. Type 9 6 5 3
4. Press the Arrow Key up or down and select 0 for region free
5. Hit OK
Posted on Aug 29, 2008
SOURCE: AWA DS-A331 DVD PLAYER REGION CODE
(1) Open tray with remote
(2) Enter 0,5,2,0 on the remote
(3) Press up, down, left then right
(4) Press 0
(5) Close tray
Posted on Feb 07, 2010
I bought some DVDs at amazon.com, but I live outside the region code area witch the DVDs are supposed to work. I live in code area 4. I need someone to find a code to region 1. I have a Phillips home...
This player is relatively easy to change to region free. Please complete all of the steps below to unlock your DVD player.
Please note: Unlocking any DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
Unlock sequence for the Philips DVP 3020:
1. Switch on your TV and DVD player;
2. Make sure the TV is set to the correct input for the DVD player;
3. Remove any disc from the DVD player and close the disc tray;
4. Press the "SETUP" button on the DVD player remote control;
5. Use the LEFT/RIGHT arrow keys to highlight "PREFERENCE";
6. Enter 1 3 8 9 3 1 using the numerical keys on the Philips DVD remote control;
A pop-up menu will appear on the TV screen.
7. Use the UP/DOWN arrow key and choose "0" for all regions;
That's it. You should now be able to watch DVDs from all regions on your player. It is also a good idea to switch the player to standby and then switch it back on before trying any discs.
This is a verified unlock sequence for the Philips DVP 3020. If it doesn't work the first time, switch the power off and start again at step 1. If it still doesn't work, it is likely that you have updated your Firmware to a new version and this unlock sequence does not work with your firmware version
If you need further assistance, please reply to me from within this page and let me know which firmware version you have installed in your DVD player.
Regards,
BElectric.
Jan 28, 2011 | Philips Televison & Video
(4) Press 0
(5) Close tray
Dec 30, 2008 | Televison & Video
Hi i need to find a region free unlock code for the phillips dcp851/37 portable dvd player, can anyone assist?
TRY THE DEFAULT CODE 0000 OR 1234 IF THAT DON"T WORK IM SORRY THAT I CANT HELP YOU WITH THIS
Jul 01, 2008 | Televison & Video
Phillips dvp1013
Hello Canada416,
Check the following link to the regional code data base for codes you can enter through the handset to unlock region codes. Let me know if this helps you or you need further assistance.
Jun 30, 2008 | Philips DCP855/37 Portable DVD Player
Funai HDR-D2835 or HDR-B2735 region unlock
i think the codes from phillips machines work.
try at your own risks tho
Jan 29, 2008 | Funai PY90VG DVD Player/VCR
PERMANENT UNLOCK REGION CODE FOR philips DVD PET714
I boght PET714 DVD portable DVD player.
but I couldn't watch Japanese DVD.
I'd like to unlock code.
Please tell me how to get unlock!!
Jan 12, 2008 | Televison & Video
UNLOCK REGION CODE FOR PHILIPS DVP3140 DVD PLAYER
Hi guys,
I cant play any dvd or cd with my philips 3140 player...it simply says ERROR.
Can someone please help?
thank you,
H.
Jan 05, 2008 | Philips DVP3140
7" LG Portable DVD Player DP271
Hi
I have tried to unlock the DVD DP271 player using following methods, But it is not unlocking. If any body knows any other code. Please help me to un lock my DVD DP271 player.
Thanks
Sekahr
1. Power up and press setup
2 Scroll down to LOCK
3 Press '0' (zero) seven times
4. A message may now appear with saying that the player is region free.
5. Power down then power up.
or
1. Remove any discs and power up the DVD
2. Press PAUSE
3. Enter 314159
4. The hidden region code menu may now appear.
5. Set code you want- 0 for multiregion, 1 for region 1 and so on
6. Press PAUSE
7. Power down then power up
Nov 02, 2007 | Insignia NS-PDVD8 Portable DVD Player
Televison & Video Logo
275 people viewed this question
Top Televison & Video Experts
Electro Med Services...
